crispy_wafer
Everything posted by crispy_wafer
  1. Hi all, In the process of battening out the Dormer for service cavitys and ensuring a nice level surface to fix the plasterboard sheets to, and somewhere to route cables should it be needed, I'm planning on running the battens from bottom to top on the inside of the truss over the insulation and VCL, do I need horizontal battens at the top, bottom, middle to give something to fix plasterboard to? The battens are approx 600 centres, some at 400, length of the board will be about 2.2m. Ta Marek
  2. anything above dripping condensation?
  3. For our MVHR ducts from outside I used some lengths of Domus Easipipe 2 piece insulation with cable ties.
  4. For what it's worth, With our attic trussed room, I PIR'd from ridge to wall plate, seemed easier in my mind to detail insulation and airtightness running in straight lines from top to bottom.
  5. Currently in discussions with a few companies about installing a multi split of a couple of slim ducted 2.5's and a wall mounted 3.5 unit for the upstairs of the build. Different companies like to align with certain manufacturers, although they can and will install others if asked, as such I've had quotes for a Hitachi based system, a Daikin system and one incoming for Mitsubishi Heavy Industries. Short of looking at and trying to fathom out the micro differences between SCOP and SEER for efficiencies, the visuals of the wall mounts, interface, and initial cost is there much else to consider? Also what brand AC do you have and what swung you towards that manufacturer?
  6. Just looking at your diagram (I know it may differ from reality), but take care with the opposing waste connections.
  7. Mine too is in the loft, on the hanger + a piece of 4*2 bolted to a gable wall, yet to plug it in. I have wondered about noise and resonance and then if suspending like they do with Air con units may be a better method.
  8. Yeah, it's what I did to stop it from flopping around - Stuck to blocks. Butyl tape seems to be less tacky when cold, so I wafted a blowtorch over it just to warm it up then pressed it home.
  9. Butyl tape will hold it in place, you may be using it to bond the dpm together anyway where it overlaps on the floor, so, a couple of blobs on the wall heated up with a blow torch then push the dpm up against it.
  10. We/builder hired a crane, straight off the flatbed onto the wallplate for the joiners to do their stuff. Maybe missed in dialogue or smallprint, frustrating but put it down to experience.
  11. Top tip, added them to my vendor list for price checking in future - thanks @PeterW
  12. Until the buggers get consistent with pricing and stop trying it on, they'll get no sympathy from me. Like every business or persons, they are entitled to make a wedge, but profiteering and the taking the p**s through covid lives long in the memory.
  13. 👍 Nah, go for it. Put what you learned doing the first one to good use.
  14. Morning all, I'm after a bit of a sanity check, or otherwise please, on the planning of an internal stack that will receive from the downstairs WC, and possibly the upstairs bathroom if my ideas pass muster. Initially the drawings incorporated an SVP arrangement to look like this. Pipework out the back, meaning I need to core hole and have pipework running externally like the picture. So sitting at my desk I started procrastinating about whether I could do this better and avoid making holes in the brickwork, or not. I think I can, but I either need a bit of reassurance, or telling to keep it simple and to plan. I have a stack coming up in the downstairs WC Stud wall. My bright idea, consisted of running this stack pipe up inside the wall then connecting a 45 3 branch to avoid the pozi joist then connect into the fall from the Toilet upstairs, I need to tap a 50 into this somewhere as well. Once past the 45 I will run the 4 inch into a void behind a cupboard for an AAV. Is it OK to have multiple bends and whatnot in the this (dry) section? I will need to fix up the studding after I have carved it all up, I'm thinking I may face and join the sections of wall with ply/OSB to reinforce. My plan to vent the stench, is to tee from the soil pipe as it runs to an IC and run a vent up the wall near the chimney breast Would this plan seem OK, or am I going to be causing issues for myself.
  15. 1.2m*1.8 ish basically just an annex off the utility with a door if seeing the cylinder ever bothers me, will only house the cylinder and manifolds for water distribution. MVHR is up in the loft because I didnt fancy mucking about with 6" pipes between the pozi's. Job, jobbed! Heatpumps will be outside.
  16. ours was the same, however, the areas where the water was pooling /gathering was around the edges where the builder hadn't filled in. I know I live in an area that has quite a variable water level, due to slow draining ground more than anything. I figured the water ingress was seepin in between or through the trench blocks and via the openings that had been created for the service ducts etc. I spent a weekend lifting the blocks on the b&b floor, then on the tractor loading wheelbarrows whilst the missus and boy spread MOT under the beams (Looks bloody good, and when I had to go tunneling for a lost hammer, i didnt come out covered in mud, so that was a bonus). The builder thought I was mad for doing so quite honestly, they dont tend to bother with these details. It looks a lot better, and for the sake of a few hundred pounds worth doing and justified in my mind. I've also put in some drainage around the property about 10m away or so from the build over the last year or so, basically 4ft deep trenches wrapped and filled with 4-6" limestone chunks leading off to a drainage ditch. Just to give the water somewhere to go. Logically once your DPC, and DPM is down your habitable area is a damp proof box, and going about things as slowly as I have, I've seen the seasons pass, dry and wet alike and not seen or noticed any issues. All is good, and I have no worries. These was taken after a wet spell, albeit we had no walls or roof at the time, so it was likely to puddle... Lifted them blocks more times than I care to remember.
  17. Hey, yes... I saw your thread, so I'll reply there for you.
  18. +1 removing the render and kill two birds with one stone. Speak to the local planning office and see what feedback they have on you changing the external appearance to something more sympathetic to the local amenity whilst improving insulation levels, energy performance etc.
  19. I'm looking to bring a waste out of a Boss and go vertically ASAP with the least amount of protrusion, so I can keep the 50mm inside a 97mm or so stud wall. I'm looking to see what combination of components I need to achieve this... I'm using floplast solvent weld for this, 1) I've test fitted a bit of pipe into the bend so it sticks out a couple of mm then pushed the assembly into the boss and it fits quite snuggly and with a bit of SW I reckon it would take, but I'm not sure if this is a correct way and I'm just storing up a problem for myself later on down the line. 2) You can get boss plugs to SW pipe into the add a bend, but i'd then be bringing the bend out further than I'd like. 3) And finally you can get a conversion bend that I guess would fit into the boss plug. However screwfix dont have these in at 50mm. Toolstation have some, but these are aquaflow brand, any thought if these are interchangeable? What the best way to go about this.
  20. @joe90 Like placing an extract vent (like bathroom & kitchen) to capture the warmer air?
  21. Depends how accurate or diligent the SAP assessor has been I suppose, mine was done from the BRegs Drawings I had, & didnt ask me anything about any improvements I was making Increased insulation levels in the floor, roof etc, MVHR, window types, Airtightness levels etc So could be accurate or way off kilter. I would get hold of one of the heat loss calculators (I think Jeremy's one is highly though of ????), spend a bit of time and plug in some numbers, that ought to then give you a base figure to work from.
  22. I look at the MF I bought and didn't use (until now!) and smile, I then look over at a pile of timber that is only good for noggins, short pieces the fire because it all twisted up as it dried out. I've only used it for my en-suite but am quite impressed with the speed and ease, once I'd watched a few youtube videos. I used insulationhub for mf
  23. I'm pondering over the run for log flume no2 And I was pondering how to get my 50mm shower, sink and bath water into the soil pipe before the pipes exit the building. The pipes will be dropped between pozi' joists under the flooring and there is not much in the way of a vertical drop where I can tap into before the pipework goes into the main stack outside, I'm not sure I really want to tap into the 110 on the horizontal run. And ideally I only want one pipe exiting the building. I was browsing through threads and came across this thread where a 110mm to 50mm reducer was used to allow a feed into the 110 soil pipe. I've attached a proposed pipe layout below and where I'd like to use the reducer into a solvent weld 135 branch. Can anyone see any issues doing this?
  24. Hopefully someone will know... Build is Brick, FF pir, block. When Measuring distance to combustibles would you take into account the cavity material? Or would combustibles be those that next to the stove and not concealed?
  25. All pipes are pushed well into the stops, and into the downpipe which has a couple of fixings, a couple more to be added when I next go shopping for supplies... There is no movement, other than the bit on the slope which will be fixed down, if deemed ok.
