crispy_wafer
Everything posted by crispy_wafer
  1. I had a Camon C150 for 5 years or so, absolutely brutal that thing was, but very noisy, had two chutes, one for brush like material with flail like hammers, and one for upto 4" material that used blades to create chippings. Fantastic for reducing a big pile of into something useful. Relatively easy to use and self feeding for the most part, most problems occurred when either overloading, or with branches that split into Y shapes. No need to go sticking a hand in, just use another branch to push the obstruction through,
  2. I'd double check with your DNO that it is actually a 3 ph supply. DNO's tend to install these three phase fuse units and only install a single fuse inside the carrier. If it turns out that it is 3 ph then it's your choice, you can get a 3ph meter, or just get a 1ph meter and ignore the extra phases.
  3. So... if you add this to an ASHP A2W system rather than a normal cylinder, then you don't need to interrupt the space heating requirement for DHW generation. Each case is different I guess, but, as a rule is it better to separate the space heating system from the DHW system, or have them combined? At < 2k for a 270l arostor they don't seem beyond the realms of affordability either.
  4. Please can I ask what is an ESHP? I feel that I'm missing some knowledge on something.
  5. So, install the 6 port manifold now, and cap the unused ports and do the rest of the UFH when the time comes. Slide a bit of timber in to the screed to separate the installed pipes from the bit you will dig out later to protect them from kango damage. - Is probably how I'd go about it...
  6. Todays addition to party was a grant 250l pre plumbed cylinder, should be with us next week. I figured this would be a wise choice for us. Got a plumber lined up for some evenings and weekend work to help with the install.
  7. Blygold was what they called the coating...
  8. I think aircon units have been installed in less than favourable conditions for donkeys years. You can buy ASHP's with special coatings applied, I think I saw a daikin one last week - ebay i think coated in something that had some resistance to airborne nasties...
  9. Popped over to Liverpool yesterday to pick up the little beastie. Got it from a renewables firm that had installed a few of these, but the heating calcs system they were provided with had some under sizing errors. They then had to pull these units out at of use and replace, so were selling the small units off. Had about 2 weeks worth of work, comes with controllers and most of the bundled accessories. 1st job on the agenda is sorting out it final position, then putting in the condensate drain and concrete pad. I'm redoing the soil and waste drainage outside as I don't like the builder did. So, any reason I cant feed the condensate into a 110mm which will eventually end up in the WTP?
  10. I'm another with cemfloor, I'll have to check through my previous posts, but 65-80mm thickness over 150mm pir, no cracks and solid. Overall Im pleased with it
  11. Pictures are great, gives me something to work towards, when I pickup the tools up in anger! Your guys have used press fit too, which is cool! I'm looking to snag a tool on ebay at the moment, I think they are amazing bits of kit.
  12. Ta, it's their 6kW unit. I've downloaded the installer guides from Chofu and Grant had a skim read earlier at work, primarily trying to identify the sections for the weather compensation settings. I'm popping out tomorrow to go fetch it. Measured up and it will fit in the back of the Shogun standing up so happy with that. I'll spend the next couple of weeks laying my hands on bits and bobs to do the install. I'll keep updating the thread as I go, hopefully it will serve as a half decent reference point for others in the future,
  13. So, I managed to bag a small Grant ASHP which I intend self installing, as much as I possibly can. It'll be a relatively simple system comprising DHW and UFH, Spark and plumber will be doing the wiring and cylinder for me. So getting stumped at the first hurdle, as I start looking for other bits needed for install... Although I'm a bit hesitant to ask questions as it shows my lack of knowledge somewhat, here goes the first few questions to enter my head.. How would I size the pipework from the ASHP to the UFH manifold, is there a rule of thumb? The UFH has a design flow rate of 16.4 l/min, and the manifold is a max of 10 metres away from the heat pump. 5 bends at the most as the pipe goes up round and down! How do you decide if a buffer is needed? UFH Design volume is about 96 Litres this is a ground floor system, and all the loops are in rooms which will be used frequently so I'm happy to have the system act as a single zone. Pumps? Should I rely on the ASHP pump solely, or wire up the UFH pump too, then would I need to have a LLH, or is this a case of check the pump on the UFH circuit and see if it closely matches with the pump settings on the ASHP? Cheers Marek
  14. Thanks for posting that, quite insightful for a newbie like me wants to know a bit more without overloading the grey cells. I dont have an ASHP installed yet. But have the UFH in. So when the ASHP is installed, I'm getting the message that I should chuck out the not yet installed loop actuators, set the loops to the design flow rates. Just have a single thermostat to monitor air temp to trigger the ASHP? Anything that causes on & off's in quick succession is bad? I've got a bit to learn on this subject but we all have to start somewhere...
  15. Paid 1500 for our building regs drawings, 800 for the SE, 250 for SAP, 250 for a Bird/Bat and tree survey, all from 3rd parties. We felt there was no need to complicate an L shaped Dormer. Internal layout probably changed a few times during construction as we got a feel for the place, so super detailed drawings might have not have helped much...
  16. TBH, I'd ask the manufacturer, or system supplier/designer what they'd recommend for your particular install. Check the ducting aswell, otherwise you may have an issue with condensation.
  17. I think you can get a suitable double sided tape from someone like Tyvek or even a DPC bitumen tape, guess it depends on the application and what you actually want the membrane to do, the only thing I'm not sure about is how receptive the cut ends are to an adhesive tape, the ends may need to be wrapped with something first.
  18. I'd use the space behind the units to be fair, as long as they are 'hidden' from day to day view.
  19. Vaillant Aerotherm models worth a look?
  20. grouting - I did, as there was a slight difference in level between the infill blocks at the top of the beam, meaning that the insulation rocked a touch (of course the screed then weighs it all down and flattens the insulation out, but being green I didn't want to risk it). I mixed it up as a really runny slurry, and poured over the whole lot and used it like a filling/levelling mix. Just make sure the blocks are wet. Cant remember the mix, but think it was in the region of 5:1 ish... I did my grouting after watertight, but that meant lifting the blocks to clean out all the crap that had accumulated.
  21. Great point, our stables that we inherited are built soleplate onto concrete base, albeit, they are probably subjected to a bit more moisture. The soleplates do rot out in time. You can remove cladding etc and knock them out and replace, but it's time and hassle, when really a slight design tweak at the beginning that doesn't cost an awful lot extra can easily mitigate against.
  22. Quick check @ Insulationhub.co.uk would be about the same
  23. I incorporated a bat box in to my build, as specified by planning. Inexpensive, simply slips into a cavity. Might be an alternative.
  24. I use an old vax 51 something cylinder or other downstairs and a karcher thing upstairs, only got 2 because we don't have stairs in at the moment. Both bagged models but they were both very cheap 2nd hand from FB marketplace.
