crispy_wafer
Everything posted by crispy_wafer
  1. Crushed concrete buildup is very deep on that side, all whacked down so didn't bother with anything else under it. Knocked up some shuttering from 6*2, bits of it in the background of that pic, screwed where I could still get to them to undo once the concrete started going off. Sits about 50mm from the wall, with a slight fall to the front. Approx 2 bags of cement used and a 3-4 barrows of ballast. As @Bonner says check the minimum clearances, I got too excited about playing with the mixer and forgot 🤫! But 300mm is needed for mine, which puts it just over the centre line of that slab so It'll be fine.
  2. got to say, I like this - well done.
  3. here's mine, poured yesterday so still green, polythene covered it when it rained so a little rippled in places but itll do. I've got rubber mounting feet for the ashp aswell. Gully in the middle for any condensate to run into, needs an extension/riser piece to make it flush when I get round to picking one up.
  4. our driveway is 12-13ft, delivery drivers reversed in and drove out. as long as there is room to swing the front round as they line up to reverse then jobs a goodun. Our lane is single track too( really old pic for refence) The only two I had issues with was insulation as that came on a curtainsider but they had a nifty little forklift gadget, and insulation from seconds and co, as that too came on a curtainsider, and handballed off. Hope that helps.
  5. Yep, that works, my fingers though are testament to the metal strapping I've got's previous life as prison razor wire!
  6. Colour coded clips and everything! 🤣 Quite pleased with my weekends work.
  7. Guilty, more than once! 🤣
  8. If you need any additional noggins in place for the brackets get it in before the pipework is glued.
  9. Please, whichever vendor you use do your due diligence on them, and use a credit card to purchase for S75 protection. Don't necessarily go to the lowest price.
  10. Guess I'm just trying too hard keep to everything neat, logical, and easy to access should I need to. Combo of B and C I think. Cored out the bathroom stud walls for the pipework last night so should be about ready to start feeding pipework from end to end.
  11. Is there a convention or best practice amongst plumbers as to positioning of pipework in the ceiling void? I'm looking at installing a number of 10mm and 15mm HEP runs along and through pozi joists, the joists are 300mm deep and am wondering where would be best to align the pipework and clips. These are my thoughts below, is there a better... I think towards the top or side (A,B,C) would be better as this still allows me access to the space underneath should I need it, in reality my run only really affects a pair or 2 or joists, D allows me to fly under a UB without thinking!
  12. I recall nick mentioning something at some point about noise issues when water drops vertically from height, so may need some sound insulation. Or you could drop vertically to the floor above then use a couple of 45's to bring it into the horizontal'ish run.
  13. Sketch and plan looks ok to me. I'm not sure you could make it any more efficient. I try to think of a main spine for the heavy volumes of water, then branches for the smaller volumes, but then I don't make a living from this so take with a pinch of salt!
  14. my efforts for the day! overdone the clips as it ended up a bit cut and shut in places. But once the ceilings up I'm not going to see it.
  15. You can use one of these in the 50mm swept T if you wanted FloPlast Solvent Weld Reducing Coupler 55mm x 43mm White - Screwfix Edit: I've been faffing with solvent weld this weekend and am using a couple of the above for the bath waste and basin
  16. Here it comes... No digger required, just ally ramps and slide it off!
  17. if you dont use a chainsaw then hire a log splitter would be the best option depending on size of pile!, cutting 40cm down to 20cm would be a faff on a saw horse, not an awful amount of meat to secure to, and weight/balance issue maybe when trying to pivot the blade through the log... Me: i'd do it on the floor with a chainsaw, cut 3/4 the way through then roll it forwards or back and nip through the rest, not the safest way - but works for me.
  18. @richo106 I had a quick play at this last night, depending on what gaps if any you have at the floor to wall junction, airtight paint may not be suitable on its own. I used some Soudatight paint with their fibre based membrane as I managed to buy 6 rolls of it from Ebay last year, I lapped onto the floor and up the wall and covered with a liberal dollop of paint. I can imagine airtight tape working just as well, depends on what materials you have to hand.
  19. 👍 A 2 port valve to allow flow to the ufh like the schematic or somewhere else not shown on the schematic?
  20. bought one, looked at it and thought feck that, altered the design slightly to escape from having to mess about with it. Bifold door can work in some circumstances, they aren't for everyone though so may or may not work.
  21. Parge as close to the floor junction as possible, squirty foam to fill any gaps around the screed edge to wall. then seal up the junction, I'm using paint rather than tape. Internal walls I'd not bother parging, but the floor to wall junction would need dealing with as air leakage could still happen there. It's a job I need to do too! Ballache of a job in this heat too!
  22. It's from the Grant guide, it's the one that closely resembles the plumbing on my cylinder with a 3 port diverter valve and buffer, I'm not competent enough to draw out my own diagram from scratch, however from what I've seen most are similar in that they work on either the premise of a 3 port valve, or a couple of two port valves with logic to decide hot water or heating. The flow setter, from what I understand is there to ensure an acceptable temperature differential between flow and return. So yes you could adjust the in in built pump via the dip switches and the addition of the flow setter may be to give a more finer control?
  23. Ebay, and patience (which is difficult for me), I don't need to install it 'next week' so am picking up bits as and when they pop up. The caleffi valves I paid 80 ea for. I need to get a zone wiring center. Heatmiser uh4/8 i think. I've got the grant buffer/llh to sell on, and the grant mag filter as the cylinder I purchased has a 50l buffer underneath and a mag filter attached... There's the cylinder. and that's the drg I'm working to, but now without any rad circuit, and probably not a secondary pumpset - we'll see!
  24. Had my smart meter installed by EDF before switching to the octopus! Unfortunately they haven't been able to read from it yet, but EDF could!
  25. Self builders, we cant afford to so blasé. Mistakes cost money.
