bassanclan
Everything posted by bassanclan
Thanks for the update. It's definitely something that I will use based on that. I've got 330sqm of render which I want to put a clear coat on and acres of internal plaster to paint. It's just a case of whether I can get hold of one at the right price second hand or hire one. How is coverage compared to roller etc? Do you waste a lot in cleaning etc?
I used to have a business mowing lawns, cemeteries, parks etc and I would always choose Honda over b&s. Honda Izy is a good shout, if you are looking 2nd hand look at Etesia, they pick up the grass even when wet. I paid £750 for an 18" Etesia mower with the same Honda engine in a £200-£300, but it was the best investment ever. 2nd hand they can be had for £2-300. You can get 2stroke self propelled mowers which are good for steep banks etc
Waiting time for grout and sealant
bassanclan replied to Dbas's topic in Bathrooms, Ensuites & Wetrooms
If there was a days worth of grouting then you would wait, but on a small job, such as this must be I'd get the grout on first thing in the morning, cleaned up and touch dry to be siliconed in the afternoon. I'd not want to have to go back for another half day, nor keep the customer without a bath for that extra day. -
They also do a 7.5sqm kit of that aquaseal, which works out cheaper per sqm
What would happen if you got rid of ensuite 'C' to make the master bedroom larger/walk in wardrobe and made bathroom 'B' into two en suites?
Forget chipboard, bodgit and scarper wouldn't use that in a bathroom. The difference in price of 18mm OSB and 25mm wbp ply is probably £15 a sheet (8'x4') cement board will be more work (as its 2 lots of glue and screws) and money, marine ply more money again, but less labour
I assume you are putting porcelain/stone tiles on the floor. In which case surely some wbp plywood (or whatever it is called nowadays) would be ideal for the job. Or Marine ply if you want it to be bombproof, belt and braces. You can get 22mm ply, but will take a lot of phoning round and probably cost more than 25mm which is widely available. You might even appreciate the 3mm when you come to fix the wetroom former in to place
Payment using a credit card - loophole?
bassanclan replied to RandAbuild's topic in General Self Build & DIY Discussion
What about payment by debit card? You can use Visa chargeback, although not a legal right they do offer protection -
An esbe valve is included in the quote. This sort of thing... http://www.stovesonline.co.uk/wood_burning_stoves/ESBE-LTC-load-units.html (not a recommendation of the product or retailer btw) My concern is the noise of the pump in a living room and locating it in a already tight fireplace opening. No schematic was provided and all schematics I have seen put the loading valve near the thermal store/tank as I imagine the insulation around such valves is flammable to some extent.
So I got a quote from a local Hetas registered shop, supply and fit Dunsley Yorkshire boiler stove, flue, loading valves, controls, 750l thermal store & external exhanger...£18500+vat!!! One thing which is mentioned in the quote is the pump for the boiler stove needs to be within 1m of the stove, but I can't see that in any regs. Can anyone help me out with that? I got a quote from Mark at Newark cylinders which I'm happy with so thinking of going down the route of getting all the gear, doing the manual labour etc and finding a hetas plumber on a day rate for the important parts, or just getting building control to sign it off.
http://www.ebay.co.uk/itm/Hudson-Reed-Prophecy-2-RRP-199-Shower-Panel-Black-/162565727080?hash=item25d9ac2368:g:ZckAAOSwN2VZT8e1 Something fancy for SWMBO and easy fitting, but only suitable for larger shower cubicles
3m is way too small for a double door, why not make it 5m?
No need to leave time in between grouting and sealing, you can do both on the same day. -
Are you sure that a replacement shower valve is going to solve the problem? "Piddly" suggests a lack of flow, which might not be solved by a new shower valve. If demolition is an actual prospect why not get something good and use it in the "new house"
Double, large door is surely much easier all round. If you are worried about parking cars side by side, then paint a couple of lines. Think supermarket car park. Single doors just restricts your options. What happens when you get a Rolls Royce? You'll never get it through a single door.
Steel lintel with granite heads
bassanclan replied to DeeJunFan's topic in General Structural Issues
I'm not sure of the construction method, but if it is a brick/block build with a cavity, you could put a catnic lintel/ single skin L shaped lintel OVER the granite, meaning the load is not on the granite lintel and say a concrete lintel on the inside skin. -
Ideally you would tile directly onto the plasterboard (no skim). Paint means you are sticking tiles to paint, to skim, to plasterboard. Do you know what sort of tiles you are having? If you have chosen something like 20mm natural stone, you might want to think again!
Have you considered using imitation slate or does it have to be the real thing?
It is more of a pain with 600 centres, rather than say 400 centres, but the savings on 50% less trusses should more than make up for the extra time.
Safe Zone for wiring on vaulted walls.
bassanclan replied to MikeSharp01's topic in Regulations, Training & Qualifications
It has to be B -
Reducing The Potential for Error
bassanclan replied to ToughButterCup's topic in Project & Site Management
I chalked it on, but there's no substitute for being there walking round making sure everything is happening as you expect it to -
I like MacPherson's paint. Its better than most, but not as good as the likes of Dulux trade, but half the price!
Socket and switch holes in plaster work
bassanclan replied to Jimbouk's topic in Plastering & Rendering
Whoever fits the plasterboard surely has to cut out the holes for the back boxes etc. I can't see why they wouldn't. The only exception might be lighting where there is access to the area above (e.g. loft) or lighting where there are hole cutouts- 25 replies
- swtich hole
- electric
(and 2 more)
Tile bumper or bumpa is like a conveyer belt to carry tiles up/down. Let your builder arrange the scaffold, then there can be no disputes and he will get exactly what he wants. If the extension is only over the garage I would suggest it would be worth your while just emptying the garage and letting the rain get in rather than wasting time and money with a temporary roof. Now would be time for a good clear out!
