bassanclan
Everything posted by bassanclan
  1. To get sand and cement off I tried soaking in hot soapy water, WD40, many specialist cleaners, but the thing that worked was Cellulose thinners, but try and get it off less aggressively first
  2. It's difficult to tell whether the planners objections are reasonable without more information, however I would prepare a more detailed design and access statement disproving the planners complaints and laying out your permitted development fallback position, which by the sounds of it may be "worse" looking.
  3. If you have not had the refusal letter delivered through the post (just a chat on the phone) then immediately or sooner withdraw your application. By doing so you can make revisions and resubmit without further fees
  4. I had similar issues with pinch points, so decided to run one hot and one cold to each bathroom and teed off for basin/shower. After all you aren't likely to be washing your hands at the same time as having a shower.
  5. Can you post up a picture of the overhead view of including the porch and proposed porch please?
  6. Oh yes, I agree. Choose between wall mounted or floor btw (knowing the benefits of both) and then make the decision of the cistern/frame
  7. If you are having a btw loo which sits on the floor you could get away with just the cistern (rather than the frame too). It is a more tricky fit as the wall mounting brackets are a bit flimsy, but if you are building a box around anyway they are fine and offer a good price saving.
  8. It will be white cement and some sort of yellow sand, but you will never be able to match it. It's not my taste of fireplace, but if you are keeping it I would use a diamond blade on an angle grinder to take all the old pointing out, re-point it and then it will all look the same
  9. I would anticipate that there will be a lot of damages on a holiday let, I suspect that you will need a new to buy a new kitchen and a new bathroom, you might need new carpet, to redecorate etc all these costs will reduce the profits. If you have a receipt use it!
  10. Yes you can, I would inform the case officer that you intend to make revisions so he doesn't waste his time.
  11. 25p per m I paid is for treated laths (with a little negotiation), 4.8m per length in a 48m bundle. The size was 19x38mm, which is probably not within new build building regs, but is what is used on most old roofs. This was collected from DA Brockwell near Nuneaton, but have had similar from other sawmills. Obviously if you need delivery/small order etc then that cost has to be factored in.
  12. 25p per metre for treated batten, I wouldn't bother ripping it down, I imagine that you would be able to use the other timbers elsewhere.
  13. I would pi $$ about trying to fix it, waste a day messing about with this that and the other, then realise a Macalpine trap was the answer and fit it in 10 mins
  14. Wooden sheds will be classed as temporary buildings and not really part of the dwelling or living space. He's saying if you want to replace/keep these sheds & outbuildings and build a 66m^2 replacement dwelling that might be acceptable. One approach you should consider is what size is the house after you have maximised permitted development? E.g max rear and side extensions + loft conversion (even if in practice you wouldn't want to) and use that as a basis for your arguments.
  15. Am I right in thinking the white Sika goes yellow if used instead of silicone to say seal round a bath etc?
  16. If it is being boxed in then don't even consider flexis. Ideally it will all be soldered, with your isolation point somewhere else (more accessible) as once it's boxed in you can't use the isolation anyway.
  17. You are obviously allowed to put the boards up yourself, but I wouldn't start until you know the cost of getting an approved contractor to do it. (I just means they have done a days free course) as you will have the peace of mind of a warranty. You can see one possible issue by not having sufficent gap in this thread.
  18. If you are hoping for a warranty on the eender you will want an approved contactor for that brand of render to fit the boards and put the render on
  19. I thought I was the only one on here not loving plastic plumbing, I must count up the cost of the copper pipe I have used!
  20. Have you looked at Benchmarx and Howden for the sizes you want (not MDF)
  21. What if you swapped flipped the stairs over, move WC into the utility, made the sliding doors more central or larger?
  22. I would lose the door out of the kitchen. You have sliding doors to get out for hanging clothes etc. It will save money that can be spent on a larger window and/or more cabinets. 5 bed house could do with another reception room. Is the garage really needed? It would make a better xnug/playroom/office etc
  23. You don't usually include dimensions on a planning application drawing, they must be to scale, which is usually 1:50. The "do not scale from this drawing" is to prevent a builder using it to build the property. The architect always wants to sell building regs drawings with proper measurement's etc. You need to view the plans "on paper" at the council office with your scale ruler. Ideally before meeting the officer so you know what dimensions you might object to.
  24. Is 4x2 the size of your joists? It seems small
