If you are going to go through this delivery drama a bit, can you do it American style and forget the mesh and buy 12mm straight bar and use this as slab reinforcement. They normally put it at 450 centres. Could be easier to collect 12mm bar. Just a thought.
Having lived in a country where a lot of houses use tank water, then I think your tank choice is wrong. I’ve never seen a clear tank used. do you not get algae build up. I thought they needed to be completely dark.
32mm Waste Pipe in Metal Frame wall
Russell griffiths replied to MortarThePoint's topic in Waste & Sewerage
It’s a closed cell foam, not open cell. So the resulting dried blob is like a firm rubber ball as opposed to the rice crispy like texture of the cheapo screw fix rubbish. -
Brickwork will be too weak, a stack of bricks is strong in compression so will take the weight, no problem, but a good knock on a corner will have it tipping over. I would use 50x 50 angle iron. or just get a 2000 ltr round tank. I had a 3000ltr round tank and the pressure from the tap at the bottom was incredible.
Your buying the wrong stuff. i changed to the illbruck brand a couple of years ago and haven’t used any of the high expansion air leaky rubbish since. if you buy it in a box of 12 it’s not a lot dearer. get a can, it’s like chalk and cheese. -
@MortarThePoint why are you avoiding using expanding foam ?? i use it absolutely everywhere. -
Many ways to skin this cat. If going with a hanger, no notch needed, just a saw cut for hanger to slot into. If going with a batten I would add a 150-175?? Construction screw through each rafter into the ridge. Restraint strap does not need to be thick. The thinner the better as it can play havoc with your roof tiling. Its in tension so doesn’t need to be thick, I think mine are only 1.5 —2mm.
Those screws are fine. But I would go 18mm, 9 is just floppy and will fall to bits if fixing close to the edge.
Everything Simpson is over priced. Can you just replace these with a simple wind post. 75mm box section. I bet the reason they specifically said Simpson is they have the calculations readily available and don’t need to do their own.
Have you seen his site ?? i can fully understand the need.
Do it Australian style. I had multiple groups of this as I built in a semi cyclonic area, wind load was horrendous. Ive never seen anything built like it over here. So so basically they make a racking wall using threaded rod and plywood. Bottom plate is fixed to concrete raft with an anchor bolt that has a female thread facing upwards. This bolt has a length of 12mm threaded rod that goes up through any noggins and up through the top two head plates. Theses are fitted every 1200 mm along the wall, directly inline with the size of plywood sheets. The ply is fitted with full head nails, nailed every 150mmm. In effect it creates a 1200 x 2.4 box. Start at the corners and work up to reveals. Full sheets on all corners and reveals. If your interested i will will do a little sketch. All materials readily available of the shelf.
Best Subfloor for UFH with Suspended Timber Floor?
Russell griffiths replied to hammerandnails's topic in Underfloor Heating
How about more insulation, loose the screed and fit a board that takes the pipes on top in grooves and tile directly onto it. -
What is stopping the heat going downwards out of the bottom of the screed. -
No hangers needed for uplift or downward movement IMHO fit a 25x 50 batten the full length of your ridge, do a plumb cut on the rafter end including a notch for the batten. Fit rafter and secure with a 125-150x8 timber fixing. All you need then is restraint straps, these will go over the top of the ridge and fit to the top or side of the opposite rafter.
I’ve just driven past a very similar building, it’s got a rail system being fitted and external insulation then metal sheets on top.
Conditions on material for new driveway for new build
Russell griffiths replied to Bullseye's topic in Driveways
The first section of drive I believe has to be non movable. IE a solid surface not stone, not gravel. I believe it is to stop loose stones being spread onto the road surface, dangerous for motorbikes and stuff. I don’t believe it has to be to any specific spec, just a sealed surface. -
Well you have started with a more or less free plot, so winner winner chicken dinner.
You will want 1-4-5. depending on what you are doing. 1 for fixing osb to wall if you are adding racking boards or just a stiffening for plasterboard. 4 for nailing 38 to 38 and 5 for most stud to sole plate, top plate stuff.
Timber Cladding over render detail
Russell griffiths replied to Kernow's topic in General Construction Issues
I would go aluminium trim, with a little kicker at the front, the cladding should sit 3mm off the trim so water doesn’t wick up the cladding. -
Durisol - in administration
Russell griffiths replied to PeterW's topic in Insulated Concrete Formwork (ICF)
All the videos @FM2015talks about are readily available on YouTube, if people do the hunting. Anybody picking an icf product should have a good hunt on YouTube, if you cannot find it on there chances are not many people are using that product. -
@MakoIm trying to find a reason why not to build using concrete with external insulation. a fairly big reason would be getting somebody to do it. You would need a very competent concrete contractor, probably found in the civil engineering world rather than house builders. A friend has a 90% concrete house and they really had to go to an industrial scale to get the appropriate contractors. If you have the budget then then that’s fine but for a standard size house it would be hard to get a contractor interested. Million pound build not so much of a problem.
