Things not going to plan
Russell griffiths replied to nod's topic in General Self Build & DIY Discussion
And this is why I do everything myself, I just cannot put up with the moaning and winging. -
Buying a Kitchen: Nobilia, Stormer or Schuller
Russell griffiths replied to revelation's topic in Building Materials
We recently looked at Schmidt. it made all the other German stuff we looked at fairly plain. quote was similar to the others. -
I’m wondering if your a bit confused. why would you want a vapour open material, that would allow vapour( moisture) into your roof void, if you don’t know the make up of the roof then how do you know that vapour will escape. better to not let vapour into a roof space.
That could be a plan, could have the tubby welsh bloke here as well.
Still not understanding. If it is to construct the fall on a flat roof, then how will it be breathable if you then put a waterproof covering on it. What am I missing.
Ooh Er, that’s good to know.
Board lifter is cool, however it needs to go up 4m, I’m thinking of adapting mine, but haven’t put that much thought into it yet.
Should we set up a build hub extra muscle hot line. I need 4 lads to help soon fitting some plasterboard. Im more than happy to help anybody out. Im in Cirencester Gloucestershire. Any thoughts admin gods.
What for, for the slope on a roof ?? if you have found pir available, then what’s wrong with that ?
Durisol - in administration
Russell griffiths replied to PeterW's topic in Insulated Concrete Formwork (ICF)
Oh god why, it’s not a product that is needed, far superior products out there. let it die. -
Jetfloor system AND Thermalite vs concrete block
Russell griffiths replied to BartW's topic in Foundations
I would rather use a block of your finest cheddar than a thermalite, solid concrete block all day long for me. -
You won’t though, you will spend it on a more expensive kitchen 🤣🤣
Are you not messing about over a couple of grand. Get the piles found in and sleep soundly.
earthing insulated raft foundations
Russell griffiths replied to Highland build's topic in Foundations
I have seen this done in America. -
I don’t like your layout at all. I would take the toilet directly to the out let for the septic tank. I would have a stack coming out of the ground rising to take the toilet, with a 50mm entry point going back to shower and sink, with a separate 50/40 to the kitchen sink.
Row of concrete blocks on flat, row of marmx blocks then timber sole plate, all held in position by insulation and screed. What are you doing with your external walls to minimise thermal bridge. Do the same.
Just the structural wall through to the beam and block, the rest on top of the screed no screws needed, pu glue the sole plates down, you will not move them.
Haven’t got time to think about your whole question. But you need to ditch the 32mm idea and go 40mm if any length of run then go 50mm 32 is only any good for a tiny wash basin over a tiny distance.
Siberian larch vs sweet chestnut cladding
Russell griffiths replied to PeachyBeechy's topic in General Construction Issues
Have you looked at British larch, or western red cedar or Douglas fir. Depends if your looking at rustic finish or sharp clean edges. Ive recently seen British ash that looked good. -
@Onoff when fitting a piece of board use a spirit level instead of the board to keep it stiff and straight, you can see it’s level without having to keep checking it.
Grinder
There are companies that specifically look at faults in new builds. Look one up and get them to investigate. it’s a shame it’s getting warmer. Get a thermal imaging camera thing, crank the heating up and stand outside to see where it is escaping. or set up a home made air test, set a fan to suck air out of the room and stand in the room hunting for the cold draught.
