Everything posted by Conor
External air ventilation for log burner
Conor replied to SBMS's topic in Energy Efficient & Sustainable Design Concepts
If you are building a well insulated airtight house, you can easily go a day or two with no heating before the house starts being uncomfortably cool. So I don't buy the "backup" argument as I cannot recall ever being without power for more than a few hours at a time. Do not miss a stove at all. -
Building regulations around stairs and bannisters
Conor replied to Kitten_mittens_63's topic in Building Regulations
Pretty sure you'll need it as the wording states number of steps / rising before a handrail is needed. I don't think it matters that the top step is recessed. Fit the handrail, then remove after you've got signoff if it bothers you. Or chance it and have the debate with the building inspector when they do their final inspection. Ours was really receptive and clarified a lot of things for us as he acknowledged that the regs don't cover every scenario. For a while there was a long debate whether our house was a two or three story! The latter would have been a disaster for our plans. -
Mixing large amounts of Concrete on site...
Conor replied to Mulberry View's topic in General Self Build & DIY Discussion
Is this your DPC course? If so then it'll need to be a single pour. Just get a mini mix in and a have a couple a couple extra guys with barrows and you'll have the job done in less than hour. Hand mixing that amount on your own is a very, very long and tough day, two realistically. And it'll work out more expensive than the ready mix. Factor in the time you'll have to spend getting the cement etc ordered/bought. You're only at the start do the job, you'll soon realise that your own time is precious, don't waste it trting to save a few pennies. And, you just end up physically exhausted doing too much manual jobs!!! Most I've mixed with a belle mini in a single session is 0.5m3. it's a lot of shovelling. -
Got a call and email from my local hire company. 3 months ago I could hardly get a digger for a weekend and no offers or discounts. Now they are offering hire at 30% less now. Definitely haggle and hire
Thyme thrives on poor, rocky, well drianed soil. The opposite of the average UK lawn. Mum has thyme, oregano, sage and mint taking over their stone wall terrace part of the garden. It's sprawled over the path and is popping up in little pockets everywhere. But I think this is a product of the very specific conditions (shallow pockets of pool soil in raised areas so well drained and plenty of warmth and sun in the summer). I think youd really struggle to keep other native plants at bay as thyme is quite slow growing. A lot of work.
Are there any manholes or chamber lids in the area in question? A utility company might have assets there and they will have a right to access, which could help out. A dial before you dig request will show this.
How to get an extra 2 SAP Points?
Conor replied to Andeh's topic in General Self Build & DIY Discussion
A good airtight test result will get you a much better score. Get the SAP person to re-run at an infiltration rate of 3. If you've been paying attention to quality and taking basic airtight measures, you'll get less than 2. Are the windows ordered/installed? They sound very poor performing. You'll notice that in summer and esp winter. Ours ranged from 0.5-0.9. -
We've a 80cm Korvo sink. Love it. You could have two of them side by side to replicate the size and functionality of the above, for a fraction of the price a fabricator will need.. KORVO Workstation Kitchen Sink Undermount Single Bowl with WorkFlow Ledge 16 Gauge T-304 Stainless Steel, Include Bamboo Cutting Board and Drain Tray, 76 x 45 cm https://amzn.eu/d/8GdUT3g
Whole House Cooling
Conor replied to sargan's topic in Mechanical Ventilation with Heat Recovery (MVHR)
What's your heating source? I found our ashp was really good at keeping temps down. House was about 25-27c in July and heatpump got it down to 21c in a day. -
Cut them down to 2100mm to match the top of your door architraves. That's what we did at our last place. Gives you a good 400mm to the ceiling and it looks right.
^^ good point. From what I can see, my 9kW has a min output of 2kW.
Would be much more cost effective to add more PV panels. How many do you have currently? Would the orientation of the new roof be suitable? Sorry, no real first hand knowledge of solar thermal, just that it's more expensive than PV and has longer term maintenance issues and higher failure rates.
I think you'll need to swap the central 7x2 with a steel, something like a 203x102.
For cutting sheets of PIR I found the best way was a cordless circular saw. Sheets are too big and heavy to use on a table saw. Only 50mm cut depth but flip the board over and you get all the way through. With a bag or vacuum attached, produces less dust than a handsaw. Mask and goggle up, it's not pleasant. And do it outside. Overlap you floor sheets at 90°. E.g. put down 50mm sheets first, then the 100mm on top but across the opposite way. Then foam any big gaps, and finally tape the joins. For the roof, stick your 100mm between the joists, then the remaining 50mm or whatever it is under the roof joists, and fix down with battens and your airtight membrane. You might have a different detail to this tho. Oh, get that roof battened and slated before the first storm rips all your membrane off
I think it's enough. Our island is pretty much the same, didn't go for a prep sink though as wanted more wortop space. No regrets as main sink is right behind my prep area on the island
What's the consensus on legionella and dhw storage temps
Conor replied to SimonD's topic in Boilers & Hot Water Tanks
I absolutely would for a vented system. Ever since finding a dead bird in dad's attic tank anyway. Chlorine has a finite life and gets used up. A few animal remains and a few days brewing, you've potential issue, not just legionnaires. Unvented, no point at all. -
@richo106yep, and @dpmiller has one as well.
Avoid b&q.
Glulam vs Oak for exterior uncovered pergola
Conor replied to thefoxesmaltings's topic in Landscaping, Decking & Patios
Yes, but you can get box section steel in most dimensions, so you can replicate the chunky look of the timber. Obviously, painted steel looks nothing like oak. All comes down to the look you're after. You seem to be in quite a natural, wooded area, so steel maybe not the most sympathetic choice. An alternative to oak would be larch, but it's now expensive as well. -
At the bottom of the report it shows the total heating demand for Jan and Dec, 2200kWh. Translate to a daily heating load figure and you're looking at about 7kW if you assume heating being on for 12hrs per day, every day in the coldest months. The peak may actually be higher than this, but normally it'll be much less. Other comments will follow from people that have done in depth heat loss calcs that can give you a specific number. But from us being in a slightly bigger house but with the same heat load (but unused basement), our 9kW coolenergy monblock is doing a splendid job. Hardly broken a sweat yet. Oh, monblock every time, less complicated, easier install, and all the noisy bits are outside.
Re steel. Just got a price from the company that are doing our gates and ballustrading, £1200 for a 7m long, 2m deep brise soleil with five supporting posts. Installed. Mix of 50x50mm box and 50x200mm, galvanised and powedercoated. Coming out cheaper than timber, and 4x cheaper than alu. Definitely worth pricing that option.
