Everything posted by Conor
If you've an existing connection then just use it and save yourself a chunk of money. Replace the pipe that's on your land from the roadside onwards with 25mm mdpe pipe. Remember, you own the pipe from the stopcock/meter box onwards. And as you say, you can put a stand tap at this point as well to serve the construction. Exactly what we did. Dig down at the hedge, found the pipe, cut I and stuck on a tee, post and tap on one beach, and th other ran to the building. There's little point in paying NIW a grand or two to replace the metre or two on their side. Unless it happens to be lead, in which case they'll do it for free.
That looks like quite a simple and neat solution for a complex roof. It's the hipepd end on your gable that's the culprit, along with the fact that there is no continuous ridge from front to back on the opposite side. Edit. I've just seen your plans post. That's a ln unnesecsarily awkward roof design. Why is there not a continuous ridge from front to back and why is it a tad lower than the main ridge? It looks awkward and it's going to cost you more.
The biggest issue I can see is BC signoff for the first house. The plans will show a party wall, which has a different specification to an external wall. Your brother will have to change the design of the wall to an external wall sepc - e.g a insulated and vented cavity wall. So extra cost. And when it comes to build your house against it, there may be other implications. Does a cavity wall meet the same requirements and a party wall? How do you tie the brick work (if applicable) together? At the very minimum you'll be adding tens of thousands in extra costs by not doing at least the main structure at the same time. Biggest costs savings would be groundworks, floor slab, walls and roof. Would you be able to do the slab, services, walls and roof of your half? Then do your fitout down the line.
Nope, not all. Check the BC document and it gives guidance on unvented runs. Here in NI, if it's less than 6m it doesn't need to be vented. None of our basement runs are vented and go straight to the outside manhole
Yeah, get a drain CCTV / surevy company round to check your inverts and the public sewer levels etc. Fairy standard. Or even if you are getting a Topo survey done that surveyor should be able to get it done. But a CCTV survey will tell you everything.
Are you planning on pulling it down? If not, forget about it, it's not a risk. Looks more like textured rolled plaster. Just scrape a sample off and send it off for testing.
MVHR Acoustic Distribution Boxes
Conor replied to Johnny Jekyll's topic in Mechanical Ventilation with Heat Recovery (MVHR)
No, only a couple locally branched ducts, most are single ducts from the manifolds. The semi rigid ducts seem really good at dampening sound. -
The key to a quiet system is big ducts and big fans running at low rpm. Prevent noise being made, rather than trying to treat noise. Attenuators / silencers help a lot as well, we've one on each main duct leaving the mvhr. The only noise we have is in the two bedrooms closest to the unit, despite a large attenuator and large semi rigid ducts. I'm going to dial back the airflow as I think it's too much. It's only noticeable on boost. -
Better doing it in reverse. Set your main immersion coil to say, 45c, timed to overnight cheap rate. Then have your solar diverter powered immersion set to a much higher temp, say 60c. This setup means that on sunny days your tank will be heated up to 60c, and your overnight immersion won't be needed. Then, on dull days when you've less heating and maybe used more water than normal, the overnight top-up will ensure you'll always have hot water. If you ever run out during the day, then you'll have to boost your main immersion. We've a similar setup, but with an ASHP doing the overnight top-up to 45c. Even this time of year, our 4.5kW array isn't enough to heat the water sufficiently.
What height to begin stair rail / balustrade
Conor replied to revelation's topic in Building Regulations
We did it same as Joe, newel post on the second bottom step. The underside of the handrail is a continuous 900mm above the imaginary string line across the treads. And remember, max of 100mm space between ballusters / spindles. -
Food Waste Caddy built in to worktop - Smell?
Conor replied to puntloos's topic in Kitchen Units & Worktops
100%. Just dump all your peelings in, run some water, hit the button and it's gone in seconds. We have the top of the range model, don't know what the cheaper ones are like but it's fantastic. I've shoved the remains of a cooked chicken down it, no bother. Seems to struggle with limes which is rather random and comical. No smells, not as loud as you think, and a doddle to install. Takes up a lot of room under the sink though and you'll need to have your waste pipe lower than normal. So get the unit before brining your waste pipe up into the cabinet. Only issue we had with it was when the spark was trimming cables near by an a 1" bit of wire got in and jammed it. Even at that, removing the unit to get in to it is easy, no tools needed (just need the hex key to refit it). -
^^^Get an insinkerator. One of my favourite things in our kitchen. Contemplated a prep sink in the island with an insinkerator, but in the end prioritised prep space instead and have it in the main sink directly behind prep area. 90% of our food waste goes down it. -
Batten out all of the units to give you a service void behind all the units. It's drastic, and kinda needs to be done before you start building the kitchen! Or, as nick says, rip out the back of the sink unit. I had to rip the base of mine out to fit my quooker cylinder, and take out one of the rear pieces so the flex hose weight would go up and down unimpeded. In the previous house had to rip out the back, and carve out a large notch out of one of the drawers in order to make room for everything. Modern kitchen units haven't changed much over the years (i.e. same depth and still have usual bits like shelf supports, solid base, etc ) so once you add in an oversized sink, boiling water kit, filter / sparkler and a waste disposal system, you've no space left. Our 900mm wide unit just about has space for a small plastic basin and roll up drainer. And that's with back and half th base removed and no shelves or drawers.
Apparently you say bye bye to any kind of warranty if you do this esp as almost all nowadays are moulded and have to be cut off. Hence our mvhr is plugged in via an adapter rather than removing the plug.
Try Argos, use them a lot more than Amazon these days, not much difference in price and we can normally collect same day from our local Sainsbury's.
Batten the walls behind your units to create a service void. Makes life a lot easier
Are you sure it's not meant to be 16mm pipe rather than 15mm? I.e like you'd have with an UFH manifold. I've used compression fittings on 15mm speedfit pipe loads of times and the olive really digs in (exactly why it's not suitable for compression applications).
We went for PVC aluclad. I'm aware timber is at least double the price. We're absolutely fine with the white PVC on the inside, works fine with our style and we wouldn't gain anything with wood or timber on the inside.. Performance wise, we're over the moon with them.
By having the window open, you're cooling the inside pane of glass (imagine a waterfall of cold outside air pouring in through the open window). This is enough of a drop for condensation to be formed. Better off having the window closes and having the fan womed for longer.
Look for an internorm supplier / fitter. We're mightily impressed with their triple glazed aluclad windows and prices were very good compared to the rest of the quotes - in and around £35k, while a lot of alu/alu clad quotes were £45-£60. That was 18 windows, 2 patio doors, aluminium front door and a 4.6m bifold. You have a lot of glazing, I think you are going to pay £40k + regardless. Definitely go for triple glazed.
There has to be some slack or else you couldn't drop the panels or or remove them, each one is a good metre long. I looped up and excess slack but left enough so you could flip a panel up 90° in situ and access the connectors. And the MC4 connectors are well tough.
It's entirely down to the surveyors valuation. We reached our full value about half way through the build (and therefore could draw down the full amount) due to the increase in property prices locally. I'd reccomemded arranging the valuation asap. However, if you've completed, surely you'd be looking for a normal residential mortgage at this point and settling up with Ecology, rather than drawing down more funds?
On the 25mm roofing battens. My roof though is a thermohouse panel system and is counter-battened, so I've a 25mm void under the felt as well as over. The drainage ridges in the trays are about 10mm high or so and that keeps the panels off the plastic and provides the ventilation gap. Plus whatever airflow come from under/over the roofing felt - I've continuous soffit vents and dry ridge. Image below is an unusual section where the trays met a flat roof (flashed 300mm under) but again, the flat roof is counter-battened and vented.
