scottishjohn
i remember now 5kw. that was the possible out put for the bottom lake and different turbine--bigger but much less drop again if i sell that bit --iwon,t be doing it
sowmehere i gone wrong with my calcs -- LOL will measure flow rat+ head again r anyway --its long term project ,after i can house built turbine for that is £1200 -- assuming 300 days of runnning --that,s still £2234 pr annum(0.16 elec cost) -so still looks viable ,if using it all ,and winter there will be no shortage of water time and more study will tell
been contemplating hydro -AGAIN somewhat different situation 2lpersec (7200litres pr hour)and 110m head can make 5kwph -thats basically a 4" going to a 2" input turbine at bottom of quarry now the stream/land drain I have -does not flow enough all year round -- so was thinking, as I do 2000ltr tank at top of hill fed by stream - with a syphon pipe --like a toilet cistern - so when level in tank gets up to full it starts the flow and keeps on till its near empty --It fills up again and repeats what have i missed? the vacum created by that drop will certainly pull the water out of tank will be testing actual output soon and throughout next year
flea bay for s/h granite work top ? snooker table slate? hosue i was brought up had this --otherside was the insdie of the coal bunker which just had a wooden door on it --so it got coooled by air from outside
at 2.6 you can fit UFH on top of floors no problem and get good insulation in as well--no need to rip up whats there if its good ,just fit covering of your choice to UFH--for best heat flow insulate under suspended floor if you can -but not imperative if you use pir boards and fit UFH in them then hard type -tiles or something carpet does work --i used to have it but not as good i f you got space then fitting insulated plasterboard to ceiling --stops you heating up the flat above
Which foul drain runs is better, red or blue?
scottishjohn replied to Dreadnaught's topic in Waste & Sewerage
If there are other users --maybe they will have a delivery on a big artic -- which could damage a lesser cover -
If on the public road then you should be using cast iron "heavy duty things - a 40 t load cast iron manhole frame and cover --very exspensive cheap galvanised one will not be fit for purpose in public road - https://www.draindepot.co.uk/600mm-x-450mm-d400-40-tonne-ductile-iron-cover-frame.html -
IC then -
blue- good straight runs between the inspection chambers there is a maximum distance you should have between rodingpoints /inspection chambers --look it up why not a rodding point/chamber where it the bend is ? -
17ft was what the dno told me was safety distance for a 110kplyon line
can you get a mains supply ? you can still be green -think how big a ground solar array you could make with the money for a turbine in winter not enough solar so you if no mains you need a generator if you wanto live in modern syle
not closer than 180m to any wood or anything that can alter air flow and at least 30m above it is what I was told
find a customer of thiers who have had it for 10years and ask for servicing +repair costs over that period--and bear in mind FIT is virtually sod all now if you have water then and it can make 5kw --that will be cheaper and very much more reliable-- 3 -4k is ball park figure for 5kw in hydro
I looked at this with the quarry plot I got where it could be on front face of a big hill bottom line after frank discussion with a man that could supply a one and specialises in off grid systems+services and repairs wind and water turbines etc is that in reality the 40k cost of a proper one installed --not mickey mouse type would take close to 20 years to get back - and the life span of the major components is not much longer than that so it would only make sense if cost of mains supply was very expensive--and my site which will be about 30k --makes going mains the right way - I can still go PV when prices get better and resale of extra energy is worth while and you will still need a battery system to store it to get best use out of it or when wind does not blow and you can expect a very long argument with planning to get one now all i am saying is ask a lot of different people and consider long and hard about it and will the company that makes this turbine still be here in 10years there was a very popular one in scotland that loads of farmers bought --then there were problems with gearboxs --such that the company went broke --cos the peole making the gearboxs -folded as well would I allow a trubine on my ground --yes if it was a rental of land( PPA scheme) --but only if it was a long way off my house
do the maths 2l per sec is 7200 litres an hour -- 7.2 cubic metres -- so how long are they trying to hold it back for
the deciding factor is gong to be the size of outlet pipe from your atenuation tank and the head --how deep the tank is -that will decide how much water + how fast the water can exit the tank sure someone on here will have the formulae for working that out ,once you know how much water you are expecting to control from your surface /roof drainage
mines on the garage roof --i get a small noise inside garage resonating through the roof beams -- but not loud by any means i could have put it at north side of house ,but as that can stayfrosted all day long in winter -- It has to be lower air temp --on roof gets sunshine all day
heres a selection of grease gun ends https://www.ebay.co.uk/itm/GREASE-GUN-ACCESSORY-ENDS-HYDRAULIC-SLIDE-ON-COUPLER-NIPPLES-ZERK-HOSES-1-8-G/283417023881?hash=item41fcf89589:m:m3E8SxPb-3Ibu1ogyAAK0Vw
not handy if you are tight for space eg slide on right angle one with flexible pipe is good -- but no doubt there will be some that you need to get at straight on
you using grease cartridges or manual fill ? or is it just not getting on the nipples at correct angle SNAP
easier to leave about4- 5ft of trunk then lever on that with the digger maybe to pull roots out
they are fire wood -no way they will get a TPO put on them --you can always replant -them in the plan -but if they die they die
you can at least remove the ivy from the good trees now --will show you are caring about them when the man comes
Is the whole build being done in some form of ICF eg velox ,or just the round bit ? as @Russell griffiths has said plenty of icf suppiers that make adjustable form to do round shapes .curved sips --never seen them
Bubbles forming in GRP, can't get rid of them
scottishjohn replied to andyscotland's topic in Flat Roofs
a wild guess boarding was not painted with a thick enough layer of resin first before cloth applied- A layer of resin first allows you to roll the laminate into the resin and any air comes out of the top of the cloth ,then add more to top as required to get it totally wetted and compacted takes alot more rolling than most people think to very easy to use to waste resin just dumping it on the top weigh the cloth --then use same weight of resin .thats ideal amount of resin to use --less than you think -- ok add more to give a real glossy finish if you like ,but its not adding much strength to the job -just making it less flexible yes its easier to use more so you don,t have to roll so much --but not as good a layup
