scottishjohn
Sunamp UniQ HW+i experience? Charge via ASHP?
scottishjohn replied to oranjeboom's topic in Energy Storage
Yes i got one of them, had it for years for another job -- could be used in new house and then see if i really need an ashp ,assuming by that time battry storage has dropped in price -loads of space fro solar pv -
or use that endless cable tie material with the plastic penny washer loose end plates which slide on and lock , or cut bottom section to to be a tight push fit between beams
that seems just the solution for a problem i expect to have on my build --due to exsisting house being built on bed rock no space for insulated founds without jacking up whole build ,which then would mean raising all exterior ground level or ramps will examine that option closely
on the same subject of temporary residence is there a time limit -
highly unlikely the extra cost of making another framework that is adjustable would ever pay back the extra cost but ground mounted could be different as you already have to make some sort of mounting anyway. If you look at commercial solar farms --i think you answer to this question is there not worth the extra complications
really you want the angle the same as your latitude with solar thermal for summer, and even steeper for winter due to low angle of sun --hanging vertical almost 54was my best summer angle
hey --don,t joke about that --just back fromn dumfries hospital ,visiting my older brother bonfire on staurday night and few beers and stood funny on a wee log ,went over broke his ankle in 3 places pins through it --waitng for swelling to go down then plates abd screws ,if no other problems he is 72 --so not going to be quick mending
190 mm solid block price walled?
scottishjohn replied to Byron Littlefair's topic in Costing & Estimating
we had to use them as a divider in our workshop -up to 8ft with butress --then metal stud wall up to roof absolute back breaker to work with blocks on the flat would be easier in hindsight -
Stone worktop suppliers in the Inverness area
scottishjohn replied to ProDave's topic in Kitchen Units & Worktops
you can come and quarry your own in my quarry if you like .lol -
Do i have to retract the fact that i called him a W"%ker
scottishjohn replied to Big Jimbo's topic in Planning Permission
why they so small --plot prices? -
4 x7 =28 ? 6 x8 =48 got a plan of it for interest sounds about right sizre for a holiday chalet -
water ingress through concrete block wall
scottishjohn replied to Daniel3103's topic in Bricklaying, Blockwork & Mortar
drill a couple of hole from outside inthe wall recess and use expanding builders foam ? patching will never mtahch the coulur of what you have now and as @ProDave say it never wotks tap outside of render with small hammer -in various places --if it sounds hollow ,then it is not stuck to wall -
so it has a foot print less than 6m x5m-? my living room is that size --and its not a big house -
Stop-valve key - trying to source and Intex 2 spare
scottishjohn replied to ToughButterCup's topic in General Plumbing
isit not the same fitting as the std "toby key"looks vaguely like it https://www.toolstation.com/multi-purpose-stop-tap-key/p30620 -
never seen one of those looks good
cut hole in base of sink unit so you can get at it easily from inside the cupboard ?
or rental from 20 illegal immigrants for housing.LOL -
any body done the costs calc on using thermalite type blocks against std blocks for a load bearing internal wall contemplating easiest way to rebuild this granite monster maybe leave outside wall and just build another house inside walls are 700mm+ thick -- so rooms would need up small if i dont, remove the interior rubble wall and replace with something thinner and which will give the insulation yes i know pull it down and rebuild it all -- just seems a shame to disturb perfect solid wall so cost of doing a thin joint mortar block wall using thermalite type blocks verus std 100mm block + of course tieing the 2 together
my suggestion is when you lay your concrete base -put bog pipe in there just under surface _and any other service pentrations (service ducts )- block up-and cover with thin concrete --then easy to open up later, even if you don,t connect to drains at this time --easy to dig soil later work out your drops now -
that will be the trigger its then no longer a garden shed -
Shed bugs in OSB sheets?
scottishjohn replied to daiking's topic in General Self Build & DIY Discussion
you can see them -so just brush them off -
its manchester for nairobi , no wood boring bettles in uk and wood worm don,t like osb just dust them off -it will be fine bear in mind OSB is not thick enough to make shelves that will have weight on them,unless you going to have brackets every 12" needs to be 1"thick plank or blockboard -
ssshhh --we are quite happy that most tourists coming to scotalnd just keep on going up the motorway past glasgow ,before they even think they are in scotland a very much forgotten and beautiful area --it si changing --but not as quick as i thought it would when i came here 40 years ago now its beginning to move and plots /house prices are moving up ,even in this terrible climate . yes there have been english folk that moved up 20 years ago -- panicked and sold to move back across the border with INDREF ,expecting prices to slump and less are running away now has brexit came along .,as many new ones coming in
might be if there were 2000 people in the street or it was mile away to find FREE parking , we don,t even have traffic wardens --so feel free to park on yellow lines chillax man -- life is good better watch it - I,m sounding like a tree hugger
the lack of traffic and the scenery were the main reasons to move here close to 40 years ago ,getting out of manchester and to be honest the traffic whilst a little more now is nothing like any city i just couldn,t be bothered with city traffic - would never move back too many people from too many places I have no interest in living in the multi cultural world that cities are is not for me If i wanted that i would have emmigrated to some far off country no one says hello or smiles at you in the cities now ,they just glare here everybody says hello even if they never met you before when passing on the street
