scottishjohn
    23
  1. assume you will need and upgraded transformer
  2. good info
  3. anyone got any suggestions for a sloping percolation field ,as looking at tech dat they all want a flat area --which is going to be hard to find , no water courses -ground is mostly bedrock
  4. agreed when compared to box profile yes -but if we did a survey by numbers then slate roofs on dwellings would be 90% at a guess. and that doc you sent me too is mainly victorian prefabs - we have some around here village halls and hunting lodges and they all look like they should be in australia .LOL we will aree to differ on what constitues traditional - in "brave hearts" time there would be more thatched roofed cottages ,as the peasants could not afford slate and as time went by they were converted to slate I drive by many houses every day built in the 1700,s --all are sarking boards with slate on top --not a tin roof in sight I doubt planning would allow a tin roofed dwelling in any town or village --not in keeping with the rerst of the surrounding buildings. not saying i agree with them --I am one for variation and allowing people to build what ever they want
  5. won,t be using tin roof anyway. it will be traditional --slates even if they are man made ones .LOL
  6. tin is certainly not a traditional use in scotland other than for cattlesheds +even those would have been slate when built if made from stone -- --slates are traditional hey what ever floats your boat ! my neck of the woods is about 250 miles from aviemore on s/w coast between dumfries and stranraer
  7. or use flashband at the end of the flat type to finish off+stop water being driven under with wind ?
  8. Maybe just me ,but i would have to cover that frilly flashing it with something . Is there a reason why you could not use lead backed flashband from frame to roof -- it sticks and shapes very well if applied correctly ?
  9. I ve not seen any of these velux fitted to tin roof where the adpator looks good i would still say my idea of taking a mould off you tin roof to get the shape and making an adaptor in GRP will be best looking and waterproof solution same as i did 25 years ago for my garage roof for my spray booth extractor chimney and thats 30"diameter fits so neat and once sealed own to roof it gets invisible nearly surely would look better if you laid some more roof over that frilly flashing at bottom of frame
  10. looks like the sanadreus fault line
  11. I,m no expert on solar PV--but if you had large water buffer tnaks for UFH and DSHW --you could probably use most or all of it to store your electric as hot water and in summer use it to run your ashp as cooling to the floor --just takes a bit of thinking about -
  12. the way you jusify them is if you can use ALL the power they make --then you are saving 15p per unit agianst the 5p you get selling it back to them that is the only way it starts to look sensible at this time -- so that takes a bit of thinking about --but plenty on here are doing that -- sure someone will point you the right way of going about it and get it dsown to 6 -7 years for payback at 23 years the panels are ready for replacing
  13. are you doing any of the build or are you going for turn key package ? spray iceyen is expensive compared to YOU getting insualtion type of your chice and fitting it --for a bulder it works out about the same --but he don,t have to spend hours fitting slabs or cutting pir boards to make them fit iF YOU DOING IT YOU WIL SAVE ALOT OVER ICENENE SPRAY -- it is the labour parts of the build where you can save big ICF the majority of the insulation is in the build process of outer skin and roofing choice -10sqm for concrete tiles or £100+ for exotic slates ,so many choices to make to get the finished price even for w+w stage and outer skin --rendered or facibnf brick or wood --all different prices and labour content -something else you can do yourrself
  14. how much of a difference- and how have you got an accurate price this quick ?was only yeterday ,.so they cannot have had your plans to give a proper quote on-and thrta is the only way to do a comparison nd can you elaborate on what you mean by "w and w" means -- if its what ithink --just a diffewrent spec of windows and ooors could be 15K of a difference anyway--you need cspecfic detaiuls of what is being used --Iam guessing your wood frame guesstimate is basic dglazing and maybe ICF is better quality or triple glazing there are guys on here who have ppaid 40k just for windows and doors i expect basic TF to be cheaper than icf --but all depending on spec could 10% only for what iwould consider a better build spec -send them plans and get detailed spec on both and if you got nudura quote that will be one of the most expensive types of ICF --more researching required
  15. you got mice there --looks like alot of holes in that block work hpe it don,t crack down that line of holes .LOL
  16. thats the thing --your current house what is the insulation vlaue of its walls and how air tight is it--????? not good and very draughty I,m guessing yes I have one and and wouldn,t use anything else my guess is the horror stories are from badly installed ones in very poorly insulated houses- there will be dozens of people on here with ASHP and no one complains of high elec costs compared with previous systems and or houses thats one thing about this forum --we don,t just share the good news but the cock ups and mistakes as well Ifthere was a forum moto it would be "everyday is a school day "
  17. you used to be able to get something called double bubble --it was smallsachets of an araldite type of stuff --but a bit more flexible iused to buy it in 50 sachet boxs when i had the body shop --used it all the time for small sticking jobs from badges to uphlstery -all sorts of stuff just googled it and yes its still made https://www.zoro.co.uk/shop/adhesives-and-sealants/two-part-adhesives/double-bubble-epoxy-adhesive-3gm-x-50/p/ZT1015050X less than £1 a sachet if that won,t stick it --its not stickable
  18. and your concrete is 20c? give it overnight to be sure
  19. battery powered tyre inflator ?
  20. If i was at work i would use compressed air to blow it out maybe next time 14mm holes for 10mm studs?--you only got 1mm either side of stud at 12mm hole
  21. your mum told you "cleanliness is next to godliness " there are alot of jobs where cleaning is more important then godliness --this is one of them -you could have just run yur drill down again and again to get debris out and try the studs "dry " before resin
  22. bottom line is they are peasants and don,t want or can afford to do the right thing and use 110vtraps with a generator in the shed-traps at £1550-£2000 a pop for proper magazine units they don,t make them any more ,but i liked the compressed air powered ones -dead simple run plastic piping anywhere and they reloaded that quick you could have 5 targets in the air at same time no body makes them any more -- simple air cylinder as they use on most production process lines to cock the spring
  23. yes it sets quickly and where the two parts meet and mix it will harden the end of the aplicator --so do all your holes at one go =clean them out -then glue all bolts in at one go and hold them vertical while it sets is it this one https://www.screwfix.com/p/fischer-fis-p-polyester-styrene-free-resin-380ml/42772
  24. use battery to convert or high voltage for transmission --then transform down again to 12v use " thats along way for a short cut" to me --just need large cables its for clay traps that are mounted on top of a tower --so you do not have to keep carrying batteries up =down to charge them
  25. more than twice the gap of a 45mm baton --and some use 38mm batons don,t see why it would take any longer at all--but not treated --idon,t like that chalk line the verticals and put straps where you need them
