scottishjohn
LOL well thats that idea trashed--but it will slow down heat leakage and should help to stop stagnation by keeping temp down until the concrete heats up , ok then less concrete more water storage--but still think it will be a non starter due to cost of tank with all complications of expansion of concrete etc - I do have 5000litre grp 10bar pressure vessel I converted years ago +insulated etc --but wife would not let me bury it in the garage a work of art making the copper solar coils 22mm input split into 12 X10mm pipes wound up looking like a hill billy still and out put coil was 1" single copper coil at top of tank tank is 8ft long x 5ft diameter all cradled in astrengthened plywood box--weighe 5tons when full and 130mm phonelic foam around it then air gap and double bubble foil then air gap and plywood outer casing my workers were quite worried when i pressurised it to 4 bar to test it all . all good fun --myabe i,ll weigh in the copper and make it into a simple garden water storage tank at new house--or maybe just try it first for a season in the new garden -and so what temp i can get it too--loads of space to play about If i still have the energy after building new house!!!
my idea of the insulation on outside of tank is to use the concrete as a large heat store which should stop the panels from stagnating --concrete will hold 5 times as much heat as water ,but heats up and cools down slowly. and get to 90c by end of summer and when tank drops below min set temp divert solarinput to smaller buffer tank or direct to floor +switch back when it makes more than is needed for immediate use. I had a calculation done 20 years ago by thermomax when i fitted first tubes --with my house it worked out I needed 20000litres storage +6x20tube panels to get 80c by end of summer for full years supply with a small possibility of needing to use electric inline boiler as back up -heat loss they claculated at 1.7c per week using 140mm of phonelic foam on outside. anymore and the difference is really academic -just cost outweigh the extra thermal gain now we are talking about a totally different house so numbers must be just a small fraction of that.as that same house uses £800 in electric for the ASHP -- my feelings are it still won,t be practical . 26mx2.6mx2,6m water storage tank +another 140mm of insulation all round the concrete +--but I,ll wait till heat calcs are done for final decision
lets face it a sensible scheme done by folk who have half a brain +not falling into the obvious traps wouldn,t make good TV - so no chance of being of any interest to to kevin now the cob castle was a good case in point . I like the idea but surely some sort of temporary porous formers on outside and the use the digger to compact it would have a more sensible idea
I have done lots of study on the various makes of ICF ,and would suggest you also look at integraspec ,they have some nice extras nudura and others don,t .. like chamfered window closing pieces which means you have no wood to possibly rot away and total foam surround to wall so definately minimum cold bridging. my attraction to durisol ,if i do go ICF, is the thermal mass inside the insulation . parge coat is no big deal cos not like plaster finish is of no importance --just fill up the surface to seal the "weetabix" finish choice ? as far as i can see they can all take any sort of finish you desire .
bit hard to get real comparison as no heat output given or even staed on navitron site for evac tubes and as istated earlier the key is having enough storage so panel never gets to stagnation point in a day . will look again later when fulldesign specs are available for house all information is good and added to the pot for cogitation prices for solar thermal are now much lower and a 3sqm panel can be be under £500 --your solar pv is 250-350 for 325watts solar thermal when enough sun from that one panel will be 1800w,quoted kingspan thermomax 30 tube panel spec, so all depends on how much free power with pv you need to use i suppose and how much hot water you need never simple
I understand why you do what you do --"seems a long way for a short cut" and complicated when one solar thermal will do so much more 80%of the year minimum to a much larger volume of a tank and a very simple control system maybeyou would get more where you are --but it does 80%+ in scotland no problem and htat was when we has 2 girls at home --now just the 2 of us even easier
I had this heat leakge problem with the tank when first supplied,as the foam used was rubbish i got PIR steam pipe lagging pipe sections and put them round tank --problem went away .no dhw tank is supplied with enough or correct insulation they are made to a price ,so they use low grade foam that is pumped into jacket ,even old style copper tanks which do have proper type of phonelic or PIR insulation on them ,are not good they need extra and include all the pipes coming out from tank ,if you want to keep heat in right place . physics tells us that making electric to then use it to heat water has to be less efficent than diret use of sun ,you are just trying to make use of PV electric that way and if no FIT --that don,t make sense-- anyway time will tell with what happens after FIT is stopped if it is not replaced by something else I can,t see how fitting pv in new roof will save on slates as you have to have something there instead if its cost then you do not use slates at £9-15 per slate for welsh slate at 19slates sqm that is lots of money £170-£285sqm use concrete tiles at around £1 each which equates to £10sqm or recycled concrete /slate mix at £20 sqm yesI,m a scot --every penny is a prisoner how much is a recessed pv roofing panels per sqm
unless they change things after the RHI grant stops for PV i doubt it will be viable any more --time will tell. ASHP has everything beat at this time I have a mitsubishi plumbed cylinder unit on my heat pump on current house -which is why i dumped solar ,as the anti legonella function knocks tempup to 60c every now and then which makes best use of solar in moderate months not that good .i have alot of experience over the years with solar thermal and it all revolves round getting as much out of it when its day light ,so lifting tank temp up by other forms stops solar working for a lot of hours . good control of what does what is needed to get best form it--simple dhw only --you just want a big tank i used blender on dhw supply so i only took minimal hot water from tank at 45c after cold blend --no point in putting lots of cold in it at the tap my tank ahd dhw coil at top UF in middle and solar coil at bottom and boiler heated parent volume when solar could not or UFH demand was too high for solar cop when raisng dhw to 60c is not good -- what i can say is when i swopped from modern lpg boiler to ashp i saved £1300 a year --house is not up to modern insulation stds add that to RHI and ashp is no brainer even on an older house if no mains gas --if you have rads then they need to be changed for ones designed for heat pumps
you have basically confirmed my thoughts --fit ufh in good insulated slab anyway , our climate here is very similar to cornwall --continuos spring interspersed with a bit of cold and heat # over heating --wife will soon sort that that -she is a window opening freak . so sounds like smallest ashp you can get --3kw will kill the job . Or i might go for solar thermal as ihave had until recentely 2x20 thewrmoax evac tubes onroof of present house 20years ago idi a retro fit underfloor system in this house by routing all chip board floors ,then coveringwith 6mm ply it has workeed well and solar actually contribute to space heating as well as the hot water# downside was storage tnak not large enough at 300litres so in summer it sometimes looked like a steam engine . kit i got then was crap --not the tubes ,but all other bits ,like plastic air separator unit --yes it melted and so did the panel sensor rersult so much heat that the plastic insulation melted off the copper pipes --so thats 170c + for sure . maybe will do what I always wanted and use to .solar thermal and large tank if heating load is as low as you say . the day I finished the installation was in february --i turned off lpg boiler and on a good sunny day it would run UFH att 25c + lifting tank to 50c so maybe my nutty professor idea of a 5000 or10000litre concrete tank insulated to death on outside could be a winner will wait to see final heat clacs when house is fully designed to make decisons --evactube panels are half price of what they were so i could have twice the are for same price
Foundation design for Durisol - help!!!
scottishjohn replied to MattButt's topic in Insulated Concrete Formwork (ICF)
maybe i,m being a bit cavailer --but me, I would start with insulation below it and make it twice the thickness you think-you can always dig down to your exsisting found and see how thick that is --then make yours thicker --bit more concrete is cheap enough at this stage --you get alot of concrete for 8K- -scotland rule is founds are twice as wide as wall on normal ground ,wider if its soggy ,you can always drill and "rebar " it to exsisting found as well at that stage , brick tie brackets or full length angle plate on exsisting walls to secure your sips to them as well -job done, just my thoughts -
How do I build this bit?
scottishjohn replied to willbish's topic in Insulated Concrete Formwork (ICF)
If you check out integraspec ICF they do end sections for window +door holes so you get complete insulating wrap,no wood -- sono cold bridge anywhere --so maybe use something like that +dpc and then coping stone ? -
doing some reading it would appear ,if you believe the hype, that a passiv house can do without UFH I find this hard to believe and would welcome all views on this subject my thoughts at this early stage are to fit UFH pipes to slab anyway -at least . I have even read that next year there will be a graphene heater element that will work with tessla power wall and solar Pv -- that too sounds a little star trekish
Durisol: that's it - the last pour.
scottishjohn replied to ToughButterCup's topic in Insulated Concrete Formwork (ICF)
durisol is maybe front runner for my projects ,but may go SIPS. on paper durisol if roughly cement rendered both sides to seal them give best "u" value of anything ,as far as i can find ,presuming you beleive what they all say and add a layer of PIR on outside and you got passiv house although they say no bracing is needed they also say only 4ft per pour. my thoughts ,and correct me if you disagree ,why not just use a little low expansion foam or "no nails" as you lay the blocks --that should help with keeping them in place -
Hi, i,m a 67 year old finally getting round to building my own house and along with brother and one for him as well 2 x 1 acre plots bought in s/w scotland overlooking the river cree estuary on the solway with outline planning already --now the problems start .LOL now its trying to sort out the best way to proceed --been hunting internet for a few months now already so expect lots of questions been in the motor trade for 40 years , so plenty of hands on engineering experience , in performance tuning conversions and racing , last thing we built was our garage about 30 years ago 30m x 24m portal frame unit and then total rebuild on a petrol station .but never a house ,so far OH and built a couple of PFA aircraft as well, a kit fox and a europa ,fingers getting itchy for a different challenge
