scottishjohn
    23
  1. a thick coat of pva or emulsion on eps and let it dry -so tape of choce will then stick to that ?
  2. It will work fine -just that you will be loosing more heat downwards than a thicker insulated system --but it will heat room well
  3. technically you could use a thin system and only lift floor level by 50mm - BUT you will be loosing heat into the concrete without a thick enough layer of insulation a bit of grief now will reduce your heat losses for ever -- do you know for sure that concrete floor has a vapour barrier below it and coming up the sides above the level of the concrete -isolating it from walls probably not at that age --so the right thing is to start again
  4. I have always lived in soft water areas and i notice the opposite if I go to hard water area - could it be the softner is OVER softening the water? are they adjustable
  5. i know nothing about 3 d printing --but that failure looks very simply that the material is not strong enough or too brittle Is it a case like nylon where you need to boil it up in water to stop it make it more flexible+ stop it becoming to brittle?
  6. the reason cars have been getting largerover the years is encaqp testing --cars have to be bigger + heavier for all the safety measures internal crash bars ,air bags etc all take space so if to get same intewrnal space car gets bigger
  7. can you get 6 x3 boards ? thats what my 74 year old plaster master uses now if he got to do ceilings
  8. i do not disbelieve you ,but the mot s must be carried out on pit with a jacking beam and swivel plates- must have been doing them for a long time with no change in ownership to still be allowed to have a pit - that will be bombed out if garage changes hands
  9. 2 post ramp was never an mot ramp all 4 posters or a pit now 4 posters with shaky plates for one man MOT operation for any new MOT stations
  10. the 2 posters are for sale -- only me here now -4 poster is coming to new house when built but £600 is bottom line --as they are not that old and proper ones with bottom frame work ,so suitable for floors that are not that good seen more than one 2 poster that just have the post, and no longditudinal arms on base , pull out of the floor when hairy arsed mechanic is swinging on a gearbox to get it back in scary stuff
  11. If i could only have one ramp it would be a 4 post with wheel free every time if there was a choice I got 1 x 4 post (bradbury) and 2 x (hoffman) 2 posters they have motor that can be single or 3 phase
  12. UFh will stil be best way even with mains gas
  13. A friend of mine has a stand alone garage wall height 10ft 6" he has a 4 poster ramp in there which has all his workshop equip on it,since he got rid of second car put ramp up --car drives below it and you got 5ft+ of space for stuff on top of ramp --with that or another car s/h four poster ramp --£500- £1000 that is a cheap second garage
  14. If you really want a transformer garage then dig a basement under it as your junk/service room I am suprised with the space premium in modern house plots these days that more do not have a basement for junk+services
  15. will hessian not hold water when it gets wet and let it through and then freeze plastic sounds abetter choice I think the idea of hessian is to allow it to breathe and let water evaporate --can,t see much of that going on for ther next few months if the hessian is soaked with rain
  16. not going to dry up at all this winter -- and if it gets wet it will melt and run down the stone work and stain it -- I suspect you need to cover it with sheet to stop that happenning . frost can only cause damge it there is free water to freeze
  17. Is this the right time of year to be doing lime mortar building ? Iwas ubde the impression it was a summer job building with lime mortar,due to its drying time
  18. wouldn,t worry abut what that old fart says he is so into independence ,but don,t live here has far too much to say about alot of things
  19. I had one that could do any number from 3 to 5 studs manual operation -- FACOM --which is what we all say to the french anyway
  20. need someone with an old type balancer which has a wheel stud plate
  21. good project everything bolts on - and everything is obtainable In france you can buy a NEW open top thing called an eden--perfect for you southerners that are complaing its too hot in summer definatly turn more heads than rag top porsche https://eden-cassis.co.uk/ and someone is making conversion kits for 2 cv in this country --but knowing what you guys are like --you would make your own
  22. yes i had one of the first ones in 1977 --bought it cos you could drive it for a year --sell it on and make 20% PROFIT
  23. If you want to do an ev conversion what about a 2cv --weighs nothing and won,t need a big motor or a lot of batteries to get a decent range then when you drive it hard it will lean over and you will think you are sailing LOL
  24. as already said ,you have to go with what your SE advises ,as he will have the insurance if he is proved wrong later I would comment that when making a basement in dubious ground most Icf systems go for a wall at twice as thick as the one standing on it above ground with drains etc and that will be with no extra load from another building very close your plan shows same dimensions as above ground ,which has no side loading on it at all . I,m certainly no expert in any way -- but that just looks wrong
  25. even cheaper https://www.ebay.co.uk/itm/Willis-Jacket-Complete-External-Immersion-Heater-Prewired-fully-assembled-/202416631247
