Mr Punter
    25
  1. With the MVHR, the inlet and outlets like to have the same air pressure to keep the system balanced, otherwise the fans will be fighting to equalise. The MVHR and the ASHP are performing 2 very different functions and it may be best just to install them as 2 separate systems unless you can quantify the benefit of mixing them.
  2. Even simpler with timber frame:
  3. The ventilation to the undercroft will be dependant on wind conditions. You may need to change to a different size / shape of ASHP unit in future, so the build in option may no longer fit. The external option looks easier to service and inspect. Have you calculated the cost of the difference in efficiency? Where is the flood line below which electrics are not advised?
  4. Is there a section detail through B1 showing the joists and ceilings either side?
  5. I have seen far worse. It looks a decent size. I seem to recall that it sits awkwardly on the plot though. You covered your bases and are experienced on construction sites so you should find this easier than most. Good luck!
  6. +1. Fill with soil and turf over level with the rest of the lawn. The grass seems to grow fine.
  7. Afternoon @Vicar and welcome. There are quite a few members who have used Nudura. From the footings and rebar I can't work out what the walls are doing. Any floor plans?
  8. If it is a large plot, is there any possibility that you could alter the topography by building up levels? If you have a large excavator and dumper you can make a huge difference. I would not bother with a cellar on the flood plain. You will fill it with stuff and if there is a flood warning you will supposedly have to shift it all upstairs.
  9. No, a disaster. Don't use bonding on any walls that are likely to be damp. The moisture wicks though the bonding and spreads out.
  10. I spent yesterday hacking off a thick layer of bonding plaster on a Victorian house. It had really sucked up a load of moisture. The previous owner had dabbed insulated P/B but one wall was part below ground, so that failed. PITA.
  11. I am happy for it to beep when the timer is up, just not every 30 seconds after. I hoped that there was a built in microwave that does not incorporate this "cunning" feature, or at least allows me to turn it off.
  12. I have a built in microwave and when the time is up it beeps. Useful. Sadly it continues to beep every 30 seconds until the door is opened or another button is pressed. V. annoying. There was no way of turning off the repeating beeps. Said microwave has now crapped itself and I would like a replacement that does not continue with the needy beeping. I tried some appliance suppliers who claimed this to be a safety feature but I cannot work out how it is unsafe as the beeping does not start until the microwave has stopped heating. Does anyone have a built in microwave that doesn't repeatedly beep, or are they all just annoying?
  13. I don't think there is much difference in cost between a metal web engineered joist and an OSB web engineered joist. If you have trusses and no ridge beam you would need a chord lower down and would not get the vaulted look. The zinc is probably expensive.
  14. Given that the floor was designed - I assume at your request - for 8mm deflection, there will be loads of spare capacity for the extra board layer. It is probably equivalent to having and extra 2 average sized people in the room. I would just get on with it.
  15. If you intend to insulate this between the joists with no airflow over the insulation it is very important you have a properly fitted VCL on the warm side of the insulation. With your downlights and MVHR ducting this will be very difficult to achieve so the roof will be at high risk of interstitial condensation and premature failure.
  16. It won't be much use for sound insulation. Can you use it in the centre of the slab and use the better stuff around the perimeter?
  17. That is a bargain. I can only just lift a 25mm sheet of OSB / ply. Hernia time for me!
  18. The diagonals are bracing. It could do with an additional horizontal rail at each lift and a toe board but not an immediate hanging offence and if I was the only one working on it I probably wouldn't bother.
  19. I always go 610 unless it is integrated.
  20. I would do clearance holes through the battens - maybe 5mm so you can load the screws. Assuming you have lots to drill, you could stack the battens and do 3 at a time. Once you have set one up you can use this as a template. If screwing into the rafter without a pilot is tricky you could do a 4mm pilot but not full depth.
  21. I can't work out why the builder is so concerned about rendering before the windows go in. Just bead up the openings and render, measure finished size, order windows, paint render, install windows. A good benefit is that the windows will not get damaged by render or paint.
  22. £200k for brickwork is loads. The contractor should be asking their QS why they missed the Flemish Bond spec.
  23. I have only seen it used for the mains supply up to the cutout. Sub main in SWA.
  24. I would really press the engineer to let you use 140mm blocks. Most garages are 100mm single skin with a small pier midway. Also there is a lot of work in those dormers for not much more space. Can you lose them and have roof lights, or are they a planning thing?
  25. Can you post a drawing? What is the steel supporting? Part A of the Building Regs approved docs may be worth a browse.
