Mr Punter
Pretty crap plastering. He shoudl have chucked on a few more bags of hardwall and ruled it off with a long straightedge or speedskim. It looks like he has just skimmed it.
Good for you. It will drive you crazy otherwise. A while ago I sent back 8 panes of 25mm thick laminated toughened glass because it was not the specified low iron and I didn't like the green tinge.
Tiling on anhydrite screed which has been down for over two years
Mr Punter replied to GaryM's topic in Floor Tiles & Tiling
I would have thought that any laitance would have worn off through foot traffic and cleaning and your plan seems OK. -
Filling 1-3cm gaps between ceiling and wall
Mr Punter replied to vagrantly3893's topic in Plastering & Rendering
It is expensive, heavy, difficult to cut, fix and finish and you don't get the benefits of impact resistance and pull-out strength where you would on a wall. -
Why on earth are you using Fermacell on a ceiling? -
They do a 3mm-7mm tape but you may find it easier / cheaper to use a low modulus silicone sealant.
An introduction... Renovation + 1950s + subsidence = a challenge!
Mr Punter replied to alfaTom's topic in Introduce Yourself
That is quite a bewildering selection of materials! Have you checked that the wall textured coating does not contain asbestos? Given the age of the property you need to be a bit cautious. -
I have bought it from ebay before and it was a fair bit cheaper. Make sure you get the Illbruck Compriband. Some of the imitations are rubbish and turn to crumb.
I got a local firm to strip the asbestos and replace with insulated metal sheets. Really good, but maybe not a budget option.
Do you buy in readymix and just get your wife to barrow it in and lay it?
Wet Brick Patches on Exterior Walls - New Bulld
Mr Punter replied to Marlz05's topic in Brick & Block
I am doing a full filled cavity with brick outer leaf and I will coat the brickwork with Stormdry Masonry cream. BBA approved, one coat application and 25 year protection life. -
Sloping tiled roof meeting sloping conservatory roof
Mr Punter replied to wtaf's topic in Roofing, Tiling & Slating
Yes someone with you would be best. -
I cannot work out where North is on the drawing. Can't see any bifolds. If the 2 windows at the top are the East facing tall windows, then are the French doors facing South? Wall insulation looks a bit thin but you SAP person will say if it is acceptable. Whatever, you may find that decent blinds will help potential overheating.
Photo would be useful. If it cannot be seen, it is not possible to say if it OK or not. -
Advice Sought for Foundation System/Drains/Sewer
Mr Punter replied to Narthecius's topic in Foundations
Perhaps start by looking at what other houses nearby have rear extensions. You could talk to Building Control and find out what foundation systems are typically used and whether there are any foundation issues locally. You will probably want a structural engineer for the project so if you can find one that has dealt with the ground conditions and sewer proximity before they should be able to propose a sensible design. -
Help: Single wall brick extension, what to do?
Mr Punter replied to CloGanga's topic in House Extensions & Conservatories
You could do as @markc suggests but if this is to be a habitable room you will also need insulation in the floor and the roof, otherwise you will have issues with lack of Building Regulations when you come to sell. -
We are on land that has about 2m depth of fairly solid clay and made ground, then 18m alluvial silt, then hard chalk bedrock. The previous buildings on the site had fairly shallow strip footings with no sign of movement. Our replacements are 4 storey and are on 25m piles. Anything founded between 2m and 18m would not be very stable. -
The were Sandtoft 20/20 tiles. I think they are all nailed. The dark grey (antique) ones look quite good. Fairly economical too for a clay tile.
Maybe once it is battened you could ask your solar installers if you should leave any tiles not nailed? I recently had some solar put on a tiled roof and it caused no issues. A few tiles were removed and modified with a grinder and replaced.
What am I doing wrong? Trades going AWOL
Mr Punter replied to SimonD's topic in General Self Build & DIY Discussion
They all seem to want £300 a day guaranteed for an easy days work. -
Request a fixing specification from the tile manufacturer specific to your roof and follow it.
Weatherboard rather than brick, effect on U values
Mr Punter replied to Post and beam's topic in Building Materials
Another vote for a thin layer of external insulation.
