Mr Punter
If the insulation is hard up to the battens it can be an issue. It is best to leave 25mm so that any water will run down the membrane and will not get trapped by the battens. If the roof is counter battened, this will be enough. Are you planning to strip the whole roof to do this?
Before you go much further, have you had an airtightness test to discover where any leaks might be coming from? Seal up the opening to the house so you just test the extension.
Fitting LVT under or around the toilet?
Mr Punter replied to iMCaan's topic in Wood & Laminate Flooring
Under is much better. You can temp remove the sink and WC while they fit the floor. -
Landscaping Plan from planners
Mr Punter replied to Caroline's topic in Landscaping, Decking & Patios
Well done. I have some friends that run a green waste site near you. It seems a bit silly asking for landscaping details on such a small site, especially as you have already specified the driveway, parking and paving materials, and with the house that accounts for 2/3 of the land. The lavender hedge and trees are outside the redline, so maybe they want some more planting inside? Any fencing or gates planned? Ask them. There is no rush as it is a before occupation type condition. -
The trouble is that lenders, insurers and surveyors do not see it that way and spray foam is considered high risk. They don't differentiate between idiot cowboys spraying badly onto the underside of slates and perished underlay on an old knackered roof and an install to a new building, properly detailed, designed and applied.
What a pain. Photos please. You may need planning and listed building consent, party wall agreement and structural engineer involvement.
Fire protection of steels
Mr Punter replied to Post and beam's topic in General Self Build & DIY Discussion
I have heard this from some people where although the floor may be rated for 30 or 60 mins, the steelwork within the void is treated differently, but I have never heard a coherent reason why. -
Sorry not paying attention, so on the outside like @Iceverge said. S/S straps, screws and eml.
With no vapour barrier on the warm side of the insulation there is nothing to stop warm moist air migrating through and condensing on the now colder wall. Absolutely crap design. BTW I saw in their "system design guide" several references to a "high mortality seal". I have never heard of this. Does it kill people? It certainly has a good go at killing dwellings.
Well if the pipe is leaking your idea of sliding 10mm inside should work fine, unless it is completely crushed and kinked.
I doubt the continuous pipe runs have failed. Test each run, find the suspect and report back.
Old Roof and Building Control Concerns
Mr Punter replied to RobertG's topic in Roofing, Tiling & Slating
I don't understand why this has come about. Normally, existing structure is considered OK unless there are obvious defects. -
Help with Failing Raised Patio after 6 months
Mr Punter replied to Larastafarian's topic in Landscaping, Decking & Patios
Some of the slabs look like they need levelling and repointing. The render on the table supports looks like it was done by me. Overall it is not great but I have seen worse. - How much hardcore stone should have been installed on top of soil? All the topsoil should be removed and dug down to the subgrade. Depth depends on soil type. - How much mortar should the tiles been layed on? About 50mm solid bed but this would not be permeable. - Should there have been a fall towards the steps/away from the house Yes with a channel slot type ACO drain installed linked into the main storm water drain? Not necessarily - Should the steps being formed with blocks with the tread/risers cemented to them rather than what they have done? Slabs would be supported on risers built in brick or block. Often infilled with type 1. - Should the planters have been formed like the have, is that an acceptable detail? Not sure what the issue is. - How should drainage been achieved at the lower back? If you mean the ACO against the house, it is common to see, especially when the paving is less than 150mm below DPC. It often doesn't go anywhere or collect significant water, but it acts as a barrier rather than having wet sand or soil against the wall. -
Tilt and turn french doors for Juliet balcony
Mr Punter replied to PJKB's topic in Windows & Glazing
Whoops sorry IdealCombi. My mistake. Very similar to the other 2. Owned by the same group. -
Gable might look nicer. I assume this is single storey onto a 2 storey. Any windows or awkward bits above? A photo would help a lot.
If that is a double garage it looks like you could get 4 straps on the front wall plate. That should be fine. You can confirm with SE or BC.
Non compliant outside drainage
Mr Punter replied to AdaminCymru's topic in General Self Build & DIY Discussion
If he was contracted to connect the surface water to a surface water sewer it is not acceptable to connect to the foul. He should either rectify or you withhold payment. It sounds a bit late in the day for this to appear. Connecting surface water to foul sewers is a major cause of sewage pollution in our rivers, lakes and seas. -
I have not used SPAR. Velfac and Rationel do timber finish on their outward opening products but not inward tilt turn. Cills are down to you to source although they will give fabricator details. Velfac and IC can supply the product with a timber cill packer for you to fit the aluminium cill to. Get the cills to project at least 25mm beyond the face of the brickwork. I doubt Velfac and IC will work for you as the order is small and delivery is expensive. -
Lime only mortar? (i.e. no cement)
Mr Punter replied to Gibdog's topic in Bricklaying, Blockwork & Mortar
I doubt it would have the strength for modern construction types. Cavity wall, wall ties, lintels will not work / be properly tested. -
Sealing timber cladding/reveal around window?
Mr Punter replied to junglejim's topic in Timber Frame
Silicone probably will not last very long and may discolour. Can you do it without? -
Guidance on best approach for excavation / foundations
Mr Punter replied to flanagaj's topic in General Construction Issues
Bear in mind that Building Control may (and should) ask for step free access from the car to the front door. Part M. Failing that you may end up with a very long ramp. -
Private shared driveway being blocked by neighbour
Mr Punter replied to qamar's topic in Party Wall & Property Legal Issues
Even if your rights of access are not set out in the deeds, you will have gained prescriptive rights of access. -
Yes I do wonder why there is such a focus on steel and fire protection. I could understand if it is a large complex steel framed building, but a dwelling or a small block of flats? I would be interested to see if there has ever been a case in this country that a small domestic building has collapsed or partly collapsed due to failure of structural steel in a fire. I very much doubt it. -
No, this will not work. The drip from the roof should be in the centre of the gutter. Often you need to put a timber like 4 x 2 on the outside before fitting the metal trim and membrane, but that didn't happen so you will need to get rid of the plastic fascia and fit a timber one further back. As the others have said, the insulation as it is will be a recipe for condensation and this will be more so if you use this for anything other than storage.
