Mr Punter
Solicitor to split deeds / get stopping up order
Mr Punter replied to Fi and J's topic in Party Wall & Property Legal Issues
You will not split the title. You will sell and transfer part of the land which will be on a new title and retain the rest on the original title which will be minus the bit you have sold. Most solicitors should be able to do this. You won't be able to do it until you sell. -
First timers attempting an ICF and Oak Frame house in Devon
Mr Punter replied to MCoops's topic in Introduce Yourself
Someone on here did an oak frame with oak visible inside and out. I can't find the person, but here is the house: https://www.rightmove.co.uk/house-prices/details/england-65891074-69232953?s=09f1fd364ad88af843b86a954972dc9081ac27208edb81c15a43198f3100ab4f&v=media&id=media0&ref=photoCollage -
Is there a dirgo in the cupboard? Where is the connection to the soil pipe?
Yes, you can build the non-loadbearing studwork walls off the insulation / screed.
Absolutely right. I would rather just use a bucket and slop out, prison style, than have a macerator.
The foundation will only be a good as the soil it bears on and I suspect that they may have been poured onto soft mush rather than stiff clay. Did BC inspect the trenches?
None of this looks great. You will need rodding access. 3 looks the least problematic. For access and rodding, outside the building is "nicer".
Musty smell, worried about interstitial condensation
Mr Punter replied to Archer's topic in Damp & DPCs
Burying the existing plasterboard behind insulation instead of removing it was a mistake. Plasterboard is prone to mould and should be the innermost layer in the wall buildup. You can either remove it or live with it. Why not leave this until summer and see how it is? -
Architects, ballooning fees and estimates
Mr Punter replied to Drellingore's topic in Costing & Estimating
I have just had a quick look at the plans. The fact that this is a conversion makes it more unpredictable. I guess it is not possible to demolish and start again? -
I would pay the architect for the work done to date and get others to do the technical design. I think around £2,500-£3,000 /m2 should be achievable. I often use different architects for planning and building regs. -
What a great plot! I understand the attraction of oak. It is a traditional natural material. Sadly for a house structure it does not work well as it is hard to achieve decent insulation and airtightness. There are loads of other options, so keep an open mind. You could always have an oak framed workshop / garage if you have the space. -
If it is a solid external wall with no DPC, then yes. If the wall is completely dry and has a DPC and a cavity then no. Other situations will be maybe.
If you are able to do this without severe planning implications then I would 100% recommend you do.
+1 Any no more flexi please.
That is a plastic dry verge and concrete ridge tiles. The biggest issue is safe access.
Air Tightness Test - poor result
Mr Punter replied to mike2016's topic in General Construction Issues
Surely it would be simpler just to make a few holes or leave the trickle vent open and retest. -
Render or texture paint on cement board cladding?
Mr Punter replied to philcvk's topic in New House & Self Build Design
For a couple of jobs I have specced Weber LAC and mesh onto cement type boards, sponge finished then painted. 6mm thick. It has stood the test of time. Thin coat beads. Material costs are about £12/m2. -
I have used Lead R which is a bit like flashband but tougher and a darker colour. Take your time to mark and cut the pieces and it should look OK. That flashband looks awful.
How important are the number of weather seals in a window?
Mr Punter replied to fatgus's topic in Windows & Glazing
It it worth getting the cheaper ones for fixed and more expensive for opening? There is no rule that says they all need to be from the same manufacturer. Get them both to send a RAL sample before you commit. -
What was the make and model?
PVC is fairly prone to discolouring. Front doors are normally fitted in the outer leaf of a cavity wall and the frame is sealed to the brick / blockwork. Without a sill, water should run down the face of the brickwork. It should not cause damp to invade! 22 years is probably not bad. I have paid £7,000 for front doors and have been very disappointed within 3 years.
Joint hot setts, not joint hot sex. Anyone?
Mr Punter replied to ToughButterCup's topic in Driveways
Paving Expert has some advice. https://www.pavingexpert.com/setts05 -
If there are trickle vents and they are not closed they should provide enough fresh air. A dehumidifier is a cheap to run way of reducing humidity. Get one where you can run the condensed water to the outside via a hole in the wall and piece of hose, so you can leave it switched on. If the PIV is not doing the job, consider switching it off. Constant running extracts may work better.
