Mr Punter
Delegated or committee how is that decision made?
Mr Punter replied to albert's topic in Planning Permission
You can talk to you local councillor as they are able to "call in" applications. Parish councils don't normally have much authority and are consulted for comments only and do not make decisions on planning applications. -
Between a Roof and a hard place....
Mr Punter replied to Mulberry View's topic in General Self Build & DIY Discussion
From what you have posted the issue is just down to the hinges on 2 or 3 rooflights on a flat roof. Why do you think the roof may have to come off? You probably don't need scaffolding. In my experience, the Velux flat roof windows do not offer much ventilation when open so you could consider ditching the opening function if push comes to shove. With the fixing the brackets through several layers of zinc, could you offset the hinges to overcome this? The legal route can be very long and costly and it sounds like it will be difficult to achieve a complete victory, while you risk considerable expense. You would need to expand on the "numerous potential defects". You would need actual defects to convince the court, even if they have not resulted in e.g. water ingress. -
For sewers, unless this is a requisition, the work is normally carried out by a private contractor and paid for by the client.
In the security window world, is PAS24 a con? What’s better?
Mr Punter replied to Adsibob's topic in Windows & Glazing
That is poor. I thought PAS24 was supposed to prevent this type of thing. I would ask the supplier and their accreditation company to give their view on why the window failed and what should be done for future. -
Considering PIV
Mr Punter replied to MortarThePoint's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The outside air will likely be drier and colder than the inside air, so no real risk of condensation. -
For timber fence posts my mate digs a 30" deep hole, so 750 deep. For your gates, the extra 450mm sounds good. Make sure the ground is nice and stable. If it is crappy made ground you could go deeper. You will already have a hole where the failed posts were, so you know that you will need to make the new ones bigger and better. Can you fix to the building either side, or is that a no-no? If you are allowed, get some angle drilled and welded on before you get this galved. Resin fix to the buildings.
That is quite often a weak point. It sometimes gets filled with mineral wool but there is a risk that too much can be added, closing off airflow beneath the roof tiles. I think your issues are mostly be reveals, external thresholds and dot and dabbed plasterboard. If you drill small holes every 200mm around the top of the walls you could squirt in some expanding foam. Along the bottom, remove the skirting board, foam the gap and replace.
Are these (leaking) Velux installed correctly?
Mr Punter replied to sniederb's topic in Windows & Glazing
Can this not be done from the inside? I doubt they will even need to cut many tiles. They may need new flashing but I suspect the current ones can be reused. -
It is sometimes simpler to have the basement the same footprint as the floor above. Make sure it is deep enough. Low headroom could be a bit oppressive. Get it priced up before you get too carried away. Even if it is not a cinema, it could be used as a bar, games room, disco, sex dungeon etc.
Looks like the black bit is meant to friction fit. Failing that, a bead of decorators caulk around the rim of the white bit will hold it securely to the plaster. You can always cut round it later if you need to remove it for any reason.
Mains water, taps and wells... Advice please
Mr Punter replied to Jack757's topic in General Plumbing
I imagine the other outside taps are teed off the mains supply. There is often a meter or stopcock in the ground near the site boundary. -
How to lap DPC - up or down - complex junction
Mr Punter replied to Bigdeadbadger's topic in Damp & DPCs
A drawing would make more sense here. The breather paper for the SIP needs to direct any moisture away from the structure. -
Feedback on EPDM vs cold applied liquid waterproofing on flat roof
Mr Punter replied to redfish's topic in Flat Roofs
Be very careful with fire test claims. Grenfell passed. Class E reaction to fire I think means it is normally flammable. I think it would be best if a professional specified this and get it cleared with Building Control. -
Precautionary reinforcement of holes in joists
Mr Punter replied to DKenn's topic in Floor Structures
No reinforcement needed. Find something else to do. -
Cemfloor for self levelling foundation slab
Mr Punter replied to BotusBuild's topic in General Flooring
I have seen it marketed as a bonded screed, so I can't see an issue. They may want the subfloor cleaned and primed.- 5 replies
- cemfloor
- self levelling
I had some shower bases where it was as if they were covered in eel juice. Fortunately after a bit of wear they are slightly better. For the current development I have specified non slip Mira Flight.
thinner alternative to flowing liquid screed - views?
Mr Punter replied to mikeysoft's topic in Underfloor Heating
Are you planning any ground floor insulation or is the slab already properly insulated? -
Steading entrance complete, I'm proud and showing the world.
Mr Punter replied to saveasteading's topic in Barn Conversions
It will be a while before that wears out. The ceiling looks rather good too. And a beautiful day for the photo. -
Jan 2024 Velfac mix of 12 windows and doors 22m2 2g and 3g supply only £600/m2. Fitting by others £111/m2.
