Mr Punter
    27
  1. Mr Punter
    Hi
    I still don't understand the issue. Is this an existing house you bought? Why did you get the tests done? What do you want to achieve?
  2. Can you just fix some brackets onto the wall at the top with screws and rawlplugs, then screw into the side of the stud to hold it firm? https://www.screwfix.com/p/sabrefix-heavy-duty-angle-brackets-galvanised-60-x-50mm-10-pack/61576
  3. Often have more than one engineer. Sometimes piling and ground beams, masonry, timber frame and balconies can each have input from different engineers.
  4. Mr Punter
    Hi
    What is the issue you have? Is it cold, damp, mouldy, high heating costs etc? The detailing of insulation / DPC / DPM gas membrane / insulation junctions can take many forms and there is not always a right or wrong, but some can be better than others. Because the house is complete any remedy suggested can only be applied to the as built, not to how it may have been better in the first place.
  5. I like the Gridshell building at the Weald and Downland Open Air Museum. Should not take you too long to design something similar for your client's granny annex... http://www.fourthdoor.co.uk/unstructured/unstructured_06/gridshell_photo_essay.php
  6. I prefer hydrated lime to plasticiser.
  7. It is tricky to do setting out manually if you have a sloping site, different levels or steps in foundations. If the plan is straightforward and the site is flat then no need for a Total Station bod.
  8. I would look at https://www.screwfix.com/p/timbascrew-wafer-timber-screws-gold-6-7-x-200mm-50-pack/6787j . 50p each, wafer head and you will get 50mm embedment into the OSB / joist which will be plenty. Can you check from underneath to make sure the fixings are locating OK? It is quite easy to miss a 45mm wide target especially if you are butting board edges over a joist. It may be better not to line up the boards with the joists - just lay in staggered rows and screws along each joist.
  9. Agree with @Russell griffiths to get a surveyor with a total station. After the ground beams were in ours did all the soil pipes, wind posts and steel column base plates, as well as walls. Marked with a Hilti pin on the concrete and coloured with spray. I still like to use a tape as a sanity check sometimes.
  10. If you are using a Paslode and the fixings are visible, buy and fit a "No Mar" tip so the timber does not get the little indents.
  11. DWG TrueView
  12. The weight of the window will often be held by chocks or packers so the effective bearing is hugely reduced. Your slider is less than 100kg per linear metre. A single skin single storey blockwork wall is about 500kg per linear metre. All looks fine.
  13. Don't butt them, offset one bay by using a block widthways in the first row of one half, so the beams are staggered on the sleeper wall. You may end up with a few odd bits where you can't use full infill blocks but you can fill this with concrete.
  14. The beams don't normally span from outside wall to outside wall, so you may be able to lap them on the sleeper walls. If you have rigid insulation going down past the beams it would be better to keep the cavity open and trim them back if needed.
  15. How will the water get under the floor in the first place?
  16. A steel fabricator would be able to produce what you need by welding support pieces onto the web / flanges of the beam. They need to be able to support the timbers and stop them twisting. They may also need to prevent them moving in or out, so a through fixing may be needed. You will need to find a solution that satisfies your aesthetic aspirations as well as one that is structurally acceptable. You will need a section drawing showing the timber joist, roof deck, wall and steel. Building control may ask for SE calcs.
  17. You could have a worktop with a waterfall front edge.
  18. Pump it back up to 6 bar in the morning, then check again in the evening. If it still falls, check your test equipment is not leaking.
  19. Looking at the pic they could have been 600 ctrs? Was a while ago now. It looks like 1 for every 2 plastic ICF ties. Not for roof plate as we only did ICF for the basement and went timber frame above.
  20. What is this used for? A long time ago it was 2.5 for power and 1.0 for lights. Now it seems to be 1.5 for lights.
  21. Using Polarwall I replaced the inside XPS with 10 x 2 timber with coach screws at 400 ctrs facing the core. Screwed them in about 40mm deep with an impact driver so there was 60mm cast in the concrete core. We later used face fix joist hangers. I think we went with 10mm coach screws. https://www.screwfix.com/p/turbocoach-coach-screws-yellow-zinc-plated-10-x-100mm-50-pack/89717
  22. Half a cubic metre is the max amount of concrete to mix by hand and even a quarter is hard work. With a mixer I would not do more than 2 cubic metres even with a labourer unless readymix was not practical. Concrete is over 2 tonnes per cube, so about 90 small bags of ballast and 18 cement.
  23. I would like a bidet. I know they are not popular but it allows a good wash of the nether regions without needing to strip off and shower, and I am not sure I am ready for @JSHarris's shataff.
  24. I understand that these deactivate after 10 years whether they are OK or not. I am not sure what parts become defective and why they cannot be replaced. There seems very little research into the 10 year lifespan and it seems that most smoke alarms fail because of dead batteries or disconnected power. I think the 10 year thing is environmentally irresponsible and a bit of an industry con. I have 11 smoke alarms and if I went with the Google Nest I would need to pay at least £105 per year to the robbing bastards.
  25. I have Aico alarms - one in every habitable room and every hallway - over 4 storeys we have 11 plus an external sounder on the roof terrace. We have the switch that allow you to detect, test and silence.
