Mr Punter
What to use on our new build house for a roof quandry
Mr Punter replied to Claire Eason's topic in Roofing, Tiling & Slating
I have used some of the rubber stuff, but only on a garage. I did it on my own but it would have been much easier with two. There are some here who have installed fibreglass (in bone dry conditions) with great success. -
Those pillars are fairly small. It won't take much material to fill them. Half a bulk bag and 5 cement would do both.
That is not the case, it was a bit of an old wives tale and never proven. Between 1:20 and 1:60 seems to work well. I assume there is a downhill slope, so I would go with this and have the drain fairly shallow all the way, providing enough cover for whatever is above. I think you can go 45m between inspection chambers and if the drain run is shallow you can use the small ones.
My guess would be this is a floating floor without a sufficient perimeter expansion gap. Ask the previous owners. You may need to remove the skirting and use a plunge circular saw to cut the boards near to the walls. I have a Makita SP6000J which gets fairly close to the edge, but there may be better. You will need to finish the ends of the cuts with a multi tool.
No, it will not be revoked if you apply for a new consent
Ceiling sound insulation alternatives
Mr Punter replied to joe90's topic in General Self Build & DIY Discussion
Resilient bars seem to work fairly well and I think if you combine these with double boarding it will be better than rockwool. The British Gypsum White book has some details for floor / ceiling constructions and the sound attenuations. Even a couple of decibels makes a lot of difference. -
Can't you use deck chars to straddle the bottom one and tie your bar to it? You could chop them into smaller bits if you want. https://www.buildbase.co.uk/deck-chair-reinforcement-100008639-2805084
Did you look at having the Kingspan inside the I joists? There was or is a rule of thumb that suggests that if you have more than one insulation type the less vapour permeable should go inside the more vapour permeable so that any vapour getting into the structure from the inside can easily diffuse out.
I have fitted Combimates in new builds. Quick to install and they don't take up much room. The only issue is if you leave them with the phosphate balls and don't use any water the stuff breaks down and you risk clogging the system. You can take them out if you plan to be away for over a month.
Timber Walls connecting to top of Block&Beam Floor/screed
Mr Punter replied to Patrick's topic in Foundations
NHBC, TRADA and others recommend treated timber for external wall studs and sole plates. I guess it is extra protection against rot if they get wet. For some reason it does not apply to roof timbers. Are your timber I beam flanges treated? Again, NHBC say they should be. -
I think the bearing for the soleplate must be at least as wide, so you may need blocks laid flat underneath a spanning the cavity onto eps / screed will mean the bearing would not have an even loadbearing capacity and the soleplate will not be properly supported. The soleplate should be treated timber. -
Gulf between TER and other 2013 building regs.
Mr Punter replied to epsilonGreedy's topic in Heat Insulation
Building regs are being used to improve the energy efficiency standards of new buildings. The standards for Part L, which deals with this, have become far more ambitious compared to all the other approved docs, so what worked 5 years ago will not pass now. -
What is the negative effect of too much mortar plasticiser??
Mr Punter replied to epsilonGreedy's topic in Brick & Block
5 minutes is OK. Depending on temperature you could leave it mixing for an hour or two. -
Do bear in mind that with trees in proximity to foundations, the actual size of tree is not taken into account, as the effect on the foundation is calculated as if the tree is fully mature. The tree size is only used if the tree is being removed, as it may lead to clay heave. Sometimes Building Control will ask for further information before they give a conditional or unconditional approval. As others have said, don't complain as you will gain nothing and may risk pissing them off.
- 7 replies
- building regs
- building regulations
Chip in concrete floor beam end, what should be tolerated?
Mr Punter replied to epsilonGreedy's topic in Floor Structures
I think it would end up a right mess. -
No but it does apparently help the mortar heal small cracks over its lifetime. -
Structural Warranties, NHBC, LABC, etc etc ..
Mr Punter replied to Ed_MK's topic in New House & Structural Warranties
Not really. Most lenders will give a mortgage on the strength of a Professional Consultant Certificate. I have used them for flat conversions, where NHBC were just wildly expensive (like £8k per flat). Everyone was able to obtain a mortgage with no issues. -
Size and layout of your networking cupboard?
Mr Punter replied to puntloos's topic in Consumer Units, RCDs, MCBOs
We have all the stuff in a sliding door wardrobe in the back corner. We have consumer units x 2, 14 no. CAT5 terminated into patch panels flush mounted in the plasterboard, 16 port fanless switch, broadband modem, Unifi AP, phone master, TV cables, TV distribution and door entry control box and it takes up very little room. I prefer not to have a cupboard just for this. Nothing gets too hot so we have clothes etc in there too. -
The water will do it no harm. Concrete cures very well under water.
Those solid barrow tyres are useless unless you are on smooth paved ground. Anything else they just bury themselves and unset the barrow if you go over uneven stuff.
I am not sure what the right angle is for. I would have 2 straight runs - 1 from utility to manhole - picking up the WC en route and 1 from kitchen to manhole. I would want access to the start of each run for rodding / jetting. This means you will not need an inspection chamber in the kitchen and the runs will be a fair bit shorter.
No, you unroll DPC straight on the top of the sub structure blockwork and beams on top. No mortar. -
Corian is softer than the quartz based materials like Silestone. It is not scratch resistant but you can polish scratches out. It also tends to mark so if, for example, you are preparing strawberries on it you will be left with marks that cannot be wiped off. You will need a scotchbrite and cream cleaner. The solid colours can be joined seamlessly. I prefer quartz as it in non-permeable and scratch resistant. Just don't put hot pans on it.
Oil is only for engineering bricks - especially blues.
300mm thick is fine for domestic up to 3 storey and the 1m depth is often just frost protection / rule of thumb but if you have point loads from columns you may need thicker / wider and / or rebar. Your SE should advise. We have had to do 1000 x 1000 x 400d concrete pads for some columns.
