Mr Punter
I am not slow to criticise architects but I think it would be really useful to have a designer spend a couple of hours resolving this properly as this is going to cost a lot of your money. As others have said, elevation and plan could be a lot better.
I am not in favour of buying goods from China. I think it is better morally and ethically to source locally made if possible. Also you can bask in your own smugness.
If the front gable was 1.5 - 2 metres narrower the eaves could be the same height as the rest of the house. Maybe you could increase the depth to make up for the loss of floor space if it does not involve too much of a compromise for you.
Building a garage over my own services (gas and elec)
Mr Punter replied to Moonshine's topic in General Construction Issues
If you dig a small trench either side to expose the services you can work out their depth and whether the raft will be able to bridge them. It is not unusual for services to run under a slab. I thought you had an integral garage in your plans? -
condensation in cold roof in passive house
Mr Punter replied to kaye's topic in Roofing, Tiling & Slating
Mostly, pitched roofs are either cold roof + cold loft with insulation at ceiling level or cold roof warm loft, where the insulation is between and under rafters. To be a proper warm roof, all insulation would be above the rafters. @kaye has cold roof + cold loft and needs ventilation at eaves, plus a bit at the ridge. -
Could you just swap it for a programmable stat? This will allow you to set any temperature at any time.
Staining on external wall insulation system
Mr Punter replied to Heidi's topic in Introduce Yourself
It looks like the joins in the insulation boards. The render should last longer than that but it is not uncommon to see modern renders discolour. Can you get the contractor back? -
Yes. The units are a lot more than gas boilers but if your house is well insulated that seem like a decent budget. Depends on cylinders, controls etc where you will need a bit more say £15k. If this is a spec development you are wanting to turn you may want to think twice. The gas tanks are like being a hostage. Probably the ASHP would be half the price to run but purchasers don't look at this (unless they have one).
I would guess that ASHP and UFCH will be at least double the price of gas boiler and rads, but if there is no gas, you don't have much choice.
I am really sorry to hear this. Sadly it is not that unusual, especially if they are paid up in full. With insurance, all your contractors should have their own but you also need self build policy. Others will suggest the best value. Is it possible to contact the sparky and see if he will come back to work for you? Don't bother if he is a pain though! Hopefully the house is fairly weathertight?
No reason you should not get consent for a new connection for 1 property.
You need to apply to the Sewerage Undertaker - often the water company. They will do an assessment on capacity. You will need to do similar for all services for their infrastructure capacity if you are proposing 20 units.
Shared Drain... *Hypothetical Question*
Mr Punter replied to Mulberry View's topic in Waste & Sewerage
Where we are there is a lower connection fee but I think they have increased the infrastructure charges. I have never know them to inspect a connection but have once been asked for photos when we made a late change to our proposal. There is nothing stopping you installing a new chamber but you will probably need the consent of the sewerage undertaker. If you are connecting a property that was not previously connected you will need to fill in the form and pay the connection and infrastructure fees. The wastewater charges are often on your water bill. -
I think they charge about £250 for sewer connection fees. -
This is a transfer of wealth from rich to poor. It would kill affluent areas and benefit poor areas. It will bear no relation to the funding of local services. It is not a terrible idea but I think a halfway house would be more acceptable. Also, I am not sure how they arrived at 0.48% as I think it may need to be nearer to 0.6% to be revenue neutral.
Over half our housing stock is flats. A quarter is terraced houses. Most of it is existing. How the hell will the heat pumps work out?
Quandary: Timber frame or masonry cavity wall
If there is room for a crane or telehandler, timber frame will get you in the dry quicker. I have done timber frame over a concrete (ICF) basement. We used timber joists for the ground floor structure. You will need to work out where your insulation is going and carefully plan the junction between the 2 systems. Make sure the join between them is at least 150mm above ground level. -
Planning Amendment vs Full Planning Application
Mr Punter replied to harry_angel's topic in Planning Permission
From my understanding, trivial alterations would be a 'non-material amendment', more major changes, but not increasing impact on neighbours etc would be a 'minor material amendment' and would seek to vary the condition referring to the drawings in the original application. 'Material amendments' include changes that would affect neighbours and this would will need a new application. -
MVHR and open fireplace
Mr Punter replied to Ronan 1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
So the short answer is you will not benefit much with MVHR as it will not be able to compensate for the uncontrolled air losses through the open chimneys but feel free to have it anyway. Agreed that you will struggle to get Building Regs to pass an open fire. Not sure if the convector box ones would let you scrape through? I think they are a bit more efficient than a straight open fire. If you have a fair bit of land you may want to consider mounting the PV panels on an outbuilding or at ground level as you may need quite a few. -
Advice on where to start for a complete beginner!
Mr Punter replied to 834843's topic in New House & Self Build Design
You will need your own plans. These could be cheaper if you want them based on what the neighbour has done. Maybe have a chat with them and find out who did the design and the construction? -
That did cross my mind. Could be a Teutonic thing.
The dropped kerbs you could do by way of phot and covering letter to highways. I have done a traffic management plan. Below are the headings. Try and cover them all. This one was quite detailed but for a simple project could be brief. Site address Planning ref Description of works Contact info Permitted routes for deliveries (overlaid on map with weight restrictions etc) Construction traffic hours Site access Abnormal loads / unloading by crane Highway damage prevention Vehicle scheduling (table showing number of vehicles at different stages) Other highway users Travel to work / contractor parking.
Are those for some kind of basin? Got a picture of it all finished? Be nice to see an "After" photo on this thread!
SVP out and back into building envelope - is this possible?
Mr Punter replied to Moonshine's topic in Waste & Sewerage
It is quite difficult to see because of the split levels, but I would not want to bring the pipe back into the building if avoidable.
