Mr Punter
If these are sliding patio doors, can you just have a 50mm wide transition piece from the (say) 18mm wood floor down to the 10mm threshold? You may find the flooring supplier will do one or know someone who can machine it.
Utilities connection experiences
Mr Punter replied to WWilts's topic in General Self Build & DIY Discussion
The final utility connection is normally done by the monopoly company for water, gas, electric and phone. You can do the sewer yourself / your contractor. Electric you run duct from the road to the inlet point, water run MDPE pipe from the boundary to your stopcock. Gas like you to leave them an open trench. They seem to really like turning up when the scaffold is down and everything else is done, then getting you to dig out a trench. -
If you lay them offset you will need shedloads of feet. Even if you just have them stack bond you will need a foot for each block plus a load for the perimeter. I think you have already sussed that you will need to cut them as they will clash.
Those blocks are designed to go on a solid bed like sand, mortar or concrete. If you want to use the stilts you can use decking or pavers. I have them with non-slip porcelain slabs on a roof terrace. Maybe just store the blocks somewhere next to the walk-on glass...
Once you start to sink the ground floor you almost need to treat it like a basement for waterproofing purposes. Can you sink the surrounding ground?
- 9 replies
- foundation
- ground level
(and 2 more)
The ACO will help a bit. You could bring the cement board down a bit. You are trying to have the external ground at the same level as your internal floor and it won't work out. The DPM under the Celotex is almost trying to do the job of below ground tanking.
Did you consider using a Marmox or Foamglas Perinsul course under the timber frame to stop cold bridging? Also, there should be 150mm min to the DPC.
Drilling Through 11mm Thickness Steel Beam
Mr Punter replied to NewToAllOfThis's topic in RSJs, Lintels & Steelwork
Controversial I know but I have used holesaws and gone in dry. I just make sure that it is kept cool. I sometimes use a step drill bit for making holes larger but I have only used this on thinner material. -
You need to get yourself into as comfortable position as you can and be patient. There is a sweet spot where it will cut through nicely. Don't rule out using a core bit and just make a larger hole. -
I understand that with the Google Nest alarms, they brick at 10 years from manufacture, so no chance of squeezing another few years, just more crap to landfill.
- 9 replies
- smokealarm
- electrics
(and 2 more)
As long as it has BBA and is acceptable to BC and your warranty provider I would go ahead with your groundworkers suggestion.
- 1 reply
Just that you may need to abandon part of the foundation and dig as per consent if you don't get you revised approval. If your architect is confident you could just go ahead. If there is drainage / service runs affected it gets more complex. Also, if it is a poured slab it would be tricky to alter.
Cherry picker is a good way to stuff up your driveway. As others have said, correct compaction of base is crucial but is normally just done with a lightweight wacker 2 passes. We have clay blocks which keep their colour really well.
On new build they want main interlinked with battery backup. You can have the interlink wireless if you need to but they still need mains power. Follow the alarm manufacturers instructions re: positioning, but they are correct not to site them in the apex.
- 9 replies
- smokealarm
- electrics
(and 2 more)
You could screw these https://www.forestgarden.co.uk/product/1-8m-x-1-2m-pressure-treated-contemporary-slatted-fence-panel/ to the front, painted if you want. Cheaper from other retailers.
Chimney DPCs and damp handling
Mr Punter replied to MortarThePoint's topic in Stoves, Fires & Fireplaces
Yes. I used some on a freestanding wall that was prone to getting saturated. It has been very efffective. I also intend to use it on a new build South facing brick flank wall on first and second floors. -
In England it is possible to offer to purchase subject to planning or change of use. The deal is binding on the parties, so if you obtain the change of use the seller would be obliged to sell at the agreed price. Probably the same up there.
Turn a habitable room into dressing room to avoid fire regs?
Mr Punter replied to Mat1's topic in Building Regulations
In the past I have had to use heat resistant glass in some rooflights so it could be used for escape / rescue purposes. Bit of a joke really as the glass failed soon after and was replaced with the standard Velux stuff. -
There is often a presumption against new dwellings in the countryside. What reasons did East Devon planning give you?
Ask them to suggest who that "someone" should be. Tell them that you know nothing about it and are relying on their knowledge, help and advice.
I think this is just for the piling mat, nothing to do with the buildings. This is just temporary works to support the rig, concrete lorries etc. I would bat this back to the piling contractor as the OP is not in a position to take design responsibility for this. You don't want the rig falling over and finding it is down to you.
You will need purge ventilation for the new bedroom. You also need some natural light. If you could remove the section of wall where you currently have the 3 internal windows and extend the bedroom by 1 metre you could incorporate some Velux rooflights. Fire escape will not be an issue as you do not have to travel through another room to get to the front door.
Sheet OSB and ply is often imperial. Most plasterboards are metric. I notice some boards like Glasroc are imperial. Worth checking.
11mm or 18mm OSB for temporary floating floor.
Mr Punter replied to epsilonGreedy's topic in Floor Structures
I would use flooring grade T&G chipboard 18mm. The sheets glue together with pva and are 0.6m x 2.4m (1.44m2) Best to lay some thin polythene over the insulation first so it does not abrade. -
You will need to support the column from elsewhere and either fit RC padstones or cast them in situ concrete. Normally need to grout the column base as well. The expansion fixings are not suitable.
