Everything posted by jack
It's pretty common to run a ring around each room at socket level. See this page, which has some helpful drawings about zones (note: do check that it's correct and up to date before relying on it!)
Cheap, Thermally Efficient Non-Structural Wall Detail
jack replied to Nick's topic in General Construction Issues
I've heard of this sort of thing in critical applications like sound rooms. I believe the main aim is to avoid having multiple sources of resonance at a particular frequency, rather than reducing overall sound transmission levels. I doubt it would make much difference if you're just trying to reduce external noise. 300mm of a dense insulation like cellulose (which is what we have) or wood fibre will cut noise like you wouldn't believe. -
They were designed as right hand cars from the start, it's just that Japan standardised to indicator on the right. Someone once told me that in the UK the indicator stalk used to be on the right, but changed over time due to the number of Euro imports. Not sure whether that's true. I lived in Australia for several years and most non-European cars have the indicator stalk on the right. It actually makes a lot of sense, because you can operate the indicator while you're changing gears during lane changes or coming up to an intersection. It's a pain changing over though, for sure. I find it easier to change between left hand and right hand drive than to switch indicator sides!
Hello to Everyone, Look Forward to Talking to You All
jack replied to Nick's topic in Introduce Yourself
+1, that's what we did. No way I'd have been able to afford a "building plot", but we just managed it with the bungalow (buying in 2012 didn't hurt either). Services already on site, no argument about the allowability of development in principle. If you're surrounded by larger houses, as we were, and the plot is a decent size, planning should be reasonably straightforward. I believe - but do check - that there's no strict maximum percentage size increase unless you're in the countryside or a conservation area. We replaced an 87m2 bungalow with a 289m2 very modern house with barely a whimper from anyone. You'll fit in fine around here. Are all Nicks like this? -
Oh god, not another one! Just kidding (if you've read around, you know the @Nickfromwales I'm talking about). Welcome to the forum and thanks for your kind offer to contribute. Always lots of questions about glass! -
I don't want to know how much time I spent/wasted thinking about this blimmin' house! I'm a thinker rather than a doer by nature. I'm certain that there were days when I just wandered around the house for several hours absorbing what was going on and pondering. Even though we moved in over a year ago, there's still time being spent/wasted on figuring out how to approach what's left. Worse, because the easier stuff gets done first, it's the "hmm, how best to do that" stuff that ends up filling your remaining to-do list. I'm at the point of just asking a builder in and paying them to do the rest, because I simply can't face any more decisions! The problem is finding the right builder
- 18 replies
- overthinking
- over
Wasn't 2015 pretty dim too? I seem to recall people talking about day after day towards the end of the year with zero production!
I'd report it now. This scam relies on ignorant people contacting him by email before paying via Amazon. Since you already paid via Amazon, I suspect you're no longer a target and won't hear from him again.
Not sure about that. Take the end case of there only being one small hole left. It'll take a lot of fast pressure changes between inside and outside for much air to be driven through it. I'd guess that the more of the larger holes you block off, the harder it will be to detect air movement through the remaining smaller ones.
We have an 8.5kW array on two sections of flat roof on the Hampshire/Surrey border. About 40% of them are facing directly south at a fairly shallow angle. The remaining 60% are in a flat east-west concertina shape with a very slight tilt towards the north. There's some morning shading throughout the year. We went for Enphase microinverters following modelling that showed how much more power would be generated. This is the summary from about half an hour ago: It's dull and rainy here this morning, so I'm surprised we even have that much being generated.
Official testing is an average of positive and negative tests, for exactly the reason you mention. They also make a note of wind conditions on the day, and won't (or shouldn't) test if it's above a certain wind speed, I believe. I think they did three cycles ([positive + negative] x 3) of the test when they did ours. With the house depressurised, even small leaks were very obvious. We got just under Passivhaus airtightness on our first run (despite the front door not actually being closed properly!) They depressurised it after the last run and let us go around for a few minutes looking for any leaks. The biggest was clearly around our large slider, as expected. There were also a couple of pin-pricks in the airtightness tape due to misplaced staples near windows. Unfortunately, for a decent sized house you'll spend a lot of time going around all the interfaces for relatively small gains, and it's unlikely a tester is going to hang around for that unless you're paying.
Stage 1 Is Very Nearly Complete :)
jack replied to Construction Channel's topic in General Self Build & DIY Discussion
Well I hope she wears proper footwear. The boots that woman is wearing are completely inappropriate for site work. -
@Construction Channel Ed, your address is in some of the screenshots above.
Good point. Even less reason to buy this one
Interesting unit. A couple of concerns would be: - corrugated pipes = higher likelihood of blockage/grunge build-up - stainless steel = good for longevity but heat transfer not as good as copper - looks like it would be difficult if not impossible to clean - looks like only a single wall construction. If so, doesn't building regs (but don't quote me on that - I'm no expert!) - the whole unit is only 60mm in diameter, and the waste water connections are 1.25" BSP fittings. This seems very small for a shower outlet. It also suggests that the gaps between the internal pipes in only a few mm. I can only imagine how little hair it would take to cause a blockage in one of these units.
We have high ceilings downstairs so the mounting height was okay for us. Ours is behind a full-height removable panel at the back of a drying cupboard in our utility room: I assume the 25 deg C ambient temp is to do with Legionella. We have several showers a day, so unless the house is left unoccupied for a long period, I'm not really concerned about this particular requirement (even if we go on hols, the temp in enclosed spaced will quickly approach the low-20s ambient of the rest of the house anyway). Our plant room would have been a better place for the unit, as it's just on the other side of the drying cupboard, but the plumber was very reticent to install it there given it was likely to be well above 25 deg C for long periods of time. It's been quite a while, so I'm not sure. I believe it was around £600, but that's a complete guess. Powerpipe (the main competitor to the one I used) has pricing on its website
I believe it was this one.
Just typing this as you posted actually Nick. We have one. Long payback, yes, but I reckon 90+% of the hot water use in our house is showers. Baths are extremely rare - maybe once a month at the moment. We have 4-6 showers a day, 2-3 of which are kids old enough to shower themselves but not old enough to get out of the shower without a lot of cajoling. Even taking a conservative estimate of efficiency, we save a lot of hot water with WWHR (reducing energy consumption is good, surely? ). Equally importantly, we get a lot more out of our tank. We have a 250L UVC. With our particular water usage patterns, I suspect it's like having a 350+L tank. As for just taking shorter, cooler showers, no thanks. A decent shower is one of the few luxuries I allow myself. I already keep them pretty short and I shower at whatever temperature is comfortable. We don't have high flow showers. One thing I don't have is comparative performance numbers, because the unit was installed before the house was occupied. I do know we've never run out of hot water in over a year. Can't say whether that would be true if we didn't have the unit.
I've been looking at this recently. I was originally thinking along the lines you discuss, but I'm concerned about complexity etc. Ideally you could provide an original number for each order, but that's a bit of a pain, and I don't doubt that a lot of delivery people will ignore it. Another approach I'm considering is buying something like this or this and building it into a cupboard
Screwfix all the way with me. The staff aren't that helpful, but they have an absolutely no quibble returns policy, and I can check online to see prices and stock before I leave (and even buy it). We had one about 20 mins drive away, which was a bit of a pain during the build, but not so bad as long as you planned ahead and tried to make each trip worthwhile. Painful when you got out of the car at home and realised you'd forgotten to buy the most important thing on the list! We did use Travis and Jewsons for stuff Screwfix didn't sell. In the end, we found the people at Travis (in our area, at least) a lot more helpful. Once they got to know my wife by name, the haggling over price became faster, but she still had to ask them every. single. time. whether that was the best they could do.
Volume of a complex shape: a bit of head scratching
jack replied to ToughButterCup's topic in Foundations
I'm sure he can't wait! -
My wife hasn't yet, but she'll find a way! Thank god I'm perfect
Wow, that's some view. House is looking good too!
Story of my life.
