jack
    41
Everything posted by jack
  1. What brand have you used, and how long ago? We have a 1 year old Siemens and the change in heat is as instantaneous as gas on ours. You change the setting and the temperature changes immediately. What size have you used? The large "ring" on ours is 24cm. I just made 7L of yoghurt (don't laugh) tonight in a 9L saucepan. The base of the saucepan is about the same of the ring. Our hob also has two adjacent square sections that can be controlled independently or together to give something like a 20 x 40 cm area. I have a cast iron plate that we use on that for bulk bacon, steak etc (I put it on a silicon mat to prevent scratching). Agree with all that. We have a hand-me-down Le Cruset casserole dish from my wife's grandmother. It works brilliantly, but we now have a permanent mark on the glass where the dish was taken out of the oven and placed on the hob temporarily. There're also fine scratches already showing along the edge of the shallow bevel along the front edge. Oh, and we found a chip along the front edge a couple of months after moving in. No idea who did it - theory is that one of the kids dropped a heavy glass and either hasn't said anything or didn't notice. Might have been me or my wife I suppose. Siliconed the chip in back in place, but I can still see it. In our house, the hob is on our island, so front and centre for all visitors. I wouldn't want a big chunky (and possibly crusty) hob in the middle of an island. That said, black glass does tend to show every mark and splash, so you do need to clean them pretty much after every use. Takes about 20 seconds though, so no big issue. I used to hate cleaning our gas hob because it was so fiddly (and I'm a messy cook, so it needed a lot of cleaning). One thing I do prefer about gas is the ability to agitate food in the saucepans while it's cooking, like flicking a frying pan with your wrist to mix things above a gas flame. You can't do that as easily on an induction hob because you risk scratching the surface, plus it turns off as soon as the pan is picked up. Induction certainly isn't perfect, but having had several gas and electric hobs in the past, I'd never go back.
  2. All you need to understand is that when you heat something like ice, it takes a certain amount of energy to change its temperature by 1 degree (say from -10 deg C to -9 deg C). The amount of energy required for each degree temperature change is fairly consistent. However, once you reach 0 deg C - the temperature where the ice melts - something interesting happens: the ice stays at the same temperature as you keep putting energy in. You keep pouring lots of energy in, and slowly the ice turns into water, but without actually changing temperature. As Terry said above, it takes the same amount of energy to change the temperature of ice from -58C to 0C as it does to convert all the ice to water without changing its temperature. The Sunamp phase change materials use the same principle. The main difference is that they are selected to have a phase change temperature that is adapted to the desired application. In the Sunamp case, the temperature is around 60 deg C (I believe - it may actually be a temperature range more than a specific temperature). That means that when you first heat the material, it'll get to 60 degrees, then stay at the same temp while you pile more energy in. In this way, it can store a lot more energy than water over the same temperature range (incoming cold water temperature up to a safe maximum of, say 80C), because the phase change system has its phase change temperature in the working range of the fluid. The phase change temperature is also high enough that it can usefully heat water above the desired temperature for supply to the DHW side of the plumbing. Having a phase change material with a phase change at, say, 35 deg wouldn't be much use. It's really interesting stuff. I looked at PCM panels when we first started planning the house. They're supposed to help buffer heat to keep the house temperature more constant, but I think they're overkill (and expensive) in a passiv-ish house.
  3. Maybe there's an advantage to charging or discharging sequentially - something like the series PCM equivalent of maintaining stratification in a thermal store?
  4. I've had a devil of a time in the past finding large-bore flexis (particularly for our ASHP). I know there's not such thing as true "full-bore", but what's described as such is often so far off the mark as to be ridiculous if not a flat-out lie.
  5. I believe you have something similar to us (Dualflo, the trade version of the Harvey softener). When I looked at the "22mm full bore" connections, I was surprised to see that they included a pair of flexis with 11mm internal diameter at both ends. Given it was advertised as "full bore", I talked to the plumber (he wasn't onsite at the time) and he seemed surprised at the 11mm restrictions. So I called the supplier and explained in detail, saying that I assume we'd accidentally been supplied flexis for the smaller unit that they do. The new ones arrive and they're the same as the old ones - that's actually the "full bore" flexi they supply! The next interaction is with our angry plumber, who's been told by the supplier that since the cables weren't incorrect, they're charging him for the new ones and he plans to pass the costs on to us! We got it sorted out in the end, but I found the whole thing a bit surprising. We have four showers and two baths in our house. While baths are very rarely used (handful of times a year) and never while the shower is on, two showers running is pretty common, plus there are toilets to flush, a washing machine and a dishwasher that all might demand water at any given time. It seemed crazy that they'd spent all this time and energy running 22mm pipework all over the place, only to send it through four 11mm orifices. In the end, I just had the plumber bin the flexis and convert to 22mm pipework. Also, remember that the softener needs access to a drain, and a power source unless it's one of those that doesn't need one. Hopefully not too off topic...
  6. Sounds good. Just make sure that the lights they specify are going to be generic enough that you'll be able to buy them - or something similar - directly. The brief experience I had involved the specification of a single light (well, a cluster of light types) that would have cost several thousand pounds for a single room, and had no obvious affordable alternative.
  7. Welcome John
  8. We have a one year old Siemens oven with self-clean function. It does indeed give off unpleasant odours when cleaning itself. I tend to do it with the MVHR on boost, and when we don't plan to be sitting in the kitchen. Hopefully this isn't as bad as a wood fire for particulates! I also agree with whoever above said that you need to clean doors etc before running the cycle. We managed to generate some baked-on stains on the door surrounds that will probably take steel wool to remove.
  9. I'm convinced it's an attention span thing. I can focus on a single boring task for hours if I have to but my missus just can't do it. Interesting your wife noticed the improvement in the doors @JSHarris. That seems to suggest that she was actually aware she was doing a poor job!
  10. As did we! There was nothing in the instructions about this, so I called the manufacturer just to confirm softened water was okay before the plumber plumbed it in. They left me on hold while they spoke to their tech department. The answer (best I recall) was something like "We don't recommend the use of softened water because the boiler hasn't been tested with it. We suspect it would be okay but you won't be covered by our warranty if you supply it with softened water".
  11. We talked this through with our electrician and he mentioned the "accessible" requirement. In the end we mounted them in a bank out of (direct) sight on our pantry wall. In our case it was probably the easiest place to put them in terms of cable runs, because it's inline with the more direct route from the CU and roughly central for all the appliances.
  12. This has come up in the past, so I won't beat it to death again, but: - the amount of sodium in softened water will depend on how hard the water was to begin with. Harder water = more sodium when softened. - it's not appropriate to compare the sodium content of softened water with that of milk, because sodium alone is not the whole story. It's the balance between dietary sodium and potassium that's potentially a problem for those who are sensitive to sodium. Milk has three times as much potassium as sodium (470mg/l Na v 1440mg/l K), so the sodium in milk can largely be ignored (indeed, the additional potassium may even help balance out excess sodium from other dietary sources) That said, the risks of consuming sodium have largely been debunked: https://www.scientificamerican.com/article/its-time-to-end-the-war-on-salt/ I personally have no problem drinking softened water. I occasionally drink from our bathroom tap overnight and it tastes perfectly fine. For reference, our tap water is "slightly hard" at 140mg/l CaCO3. Do check with your appliance suppliers. We were surprised and a bit annoyed to learn that our boiling water tap supplier wouldn't guarantee the boiler if used with softened water. While I was sure it would be fine, I prefer not to go against manufacturer recommendations with this sort of thing, so unsoftened it is. After a year, we've had a little bit of scale build up on the outlet, but nothing serious.
  13. Agree with all that. I don't think anyone's suggesting that a 300L TS is going to be a high performing solution if only heated to just above the required outlet temperature. My point is really just that when sized and heated appropriately the temperature fall-off isn't as severe as very simple modelling might suggest.
  14. These TS graphs always seem a little over-simplified to me. Ignoring the full contents of the coil at the full temp of the TS (easily a couple of litres depending on length/internal diameter) cold water coming in at the bottom is heated as it moves along the coil. The water will gradually gain heat as it moves along the coil, so you end up with a gradient of heat along the coil's length. Initially, full temp may be reached well before the water reaches the end of the coil. In that case, the outlet temperature won't drop at all until enough energy has been removed that the water needs the full length of the coil to get to the initial temp of the TS (ignoring losses for this analysis). The outlet temperature will start to fall at that point. Due to this mechanism, the bottom of the TS is cooled faster than the top, resulting in a temperature gradient along the full height of the TS (ignoring mixing at the moment). This means that although the average temp of water within the TS will fall at a particular rate given the length of the coil and temp differences, it will be warmer than that average at the top, and cooler at the bottom. This means that the water at the outlet will be higher than the average temp of the TS at all times. I don't know how you'd model all of that in practice, but the short version is that TS performance isn't quite as bad as might be concluded based on modelling that doesn't take into account the generation of a temperature gradient as heat is extracted. I believe this is one of the reasons that tall, narrow TSs are preferred.
  15. Yes, I saw the other conversation. That was what prompted me to do a bit more research (well, that and yet more prodding from the missus). I'm just not happy with the risk. I have a couple of other ideas that I'm happier with.
  16. My missus was all over the digger and dumper we had onsite for a while. She loves that kind of thing.
  17. My wife wants one of these. I looked into it and have put my foot down. They just scream "here's where the key is". The right kind of pry bar will have many of these off in seconds, ready for the scrote to take home and open at will.
  18. My best guess is that they're just trying to get people to be aware of the problem so they can reduce the number of payouts. I've never heard of anyone not being covered by insurance in this situation (a mate of mine had his new Porsche nicked by someone fishing for his keys through the letterbox), but it'd be interesting to know if that's the way things are headed.
  19. When we were burgled (scrotes kicked the door off the bungalow we've since demolished to build the new house), it turned out we didn't have a BS approved lock that the terms of our insurance required. Surprisingly, Tesco insurance paid out without a whimper. That included over £400 in cash (PTA money from a school fare we'd had the day before) and new-for-old on a beaten up old Macbook that I'd bought second hand several years before (they paid out well over twice what I'd paid for it!) And it wasn't even an oversight. They pointed out that the lock wasn't up to snuff and that they wouldn't pay out again in the future if the door or window through which access was gained wasn't locked to the required standard. So yes, insurers can be bastards (the ones we're dealing with the roof leak are a good example!) but they aren't always. Oh, and I certainly wouldn't recommend relying on an insurer's goodwill. Check the terms of your insurance for lock types. Usually you'll beed a BS3621 5 lever deadlock, but some insurers will accept other good quality locks. Ours was happy with the high-spec (anti-bump/snap) euro-lock on our multi-point locking front door.
  20. There's an interesting Grand Designs using CLT (which I'm sure @D_T has seen): I seem to recall a bit where he decides to go it alone on the panel erection after splitting with his project manager. There's a really hairy bit where he and a mate are trying to put up a roof panel on a rainy dark night - terrifying stuff!
  21. Welcome! Interesting build method. I looked into CLT as a construction method when we were planning our build a couple of years ago, but the lack of local knowledge and difficulties with estimating costs made me a bit nervous. I'm assuming a CLT core with Larsen trusses outside? It'd be really interesting to get some details of what you're doing and what you learn as you go along. We may need to put in a CLT subforum!
  22. But who else would have applied the sticker? It's clearly the seller's own sticker, and hasn't been removed (no wrinkling etc) from another sample. I think it's pretty easy to show that there's been a mistake - either the seller put the wrong sticker on the sample, or the sample is right but they've supplied the wrong product. It sounds like the seller is admitting on the phone that the former is the case, but legally I don't believe you need to prove which of these situations applies. You just need to show that the seller gave you a sample and what was supplied didn't match it. In the absence of a plausible alternative to the two set out above, that's legally the end of it. Whether the seller wants to take the hard road on this is another issue, but from what I can see the buyer's legal position is pretty strong. As said above, it's critical that the sample be retained, and that photos are taken showing the difference between the sample and order.
  23. Exactly my experience. Private building control typically couldn't care less about this type of thing I suspect.
  24. jack
    Hello
    Welcome Julie. Sounds like an exciting project! If you have any specific questions, head for the relevant sub-forum and hopefully we'll be able to help.
  25. I actually had MBC drop the floors in our bathrooms by 50mm to give us room for UFH. In the end we heard so many stories about heating not being required that we didn't bother! I just checked: upstairs is 20 deg C and downstairs is 21. Works well having the bedrooms a bit cooler, it's just the bathroom tiles being a bit chilly when you have a shower that isn't ideal.
