wozza
Everything posted by wozza
  1. Yeah its a bit nicer to use and I did use it as the final finish. - Its a bit pricey though.
  2. We will be installing a Bora hob with external extraction when we fit the Kitchen. We have been to a couple of showrooms and had a full demo at a showroom in Cardiff whilst there for the weekend. Try and find a local showroom and have a demo.
  3. I used BT1 on mine.
  4. Why can you not have a direct air feed ? Is this an option? Leaflet Efficience Pf 2014 (calameo.com)
  5. wozza
    Dimmable LED
    Varilight Pro dimmers are great for LEDs - you can get the modules so easy to fit in most faceplates. I have some Enlite and Aurora complete downlights and some GU10 Bulbs in some fittings and they all dim well.
  6. IF you cant get the bricks you want in squints, then could you get some contrasting squints to make a feature of it?
  7. I think they need to get an engineer out - I can clearly see a leak on the bottom left
  8. I have 2 stats controlling UFH that are fitted to metal boxes that are screwed to internal block / brick wall with dot and dab plasterboard. I have another 2 stats controlling UFH - both are fitted into metal boxes in acoustically insulated stud walls (12.5mm plasterboard, timber construction with 100mm rockwool RWA45) - one of them is using just the floor probe. The last stat controls the radiators and is fitted in a plastic drywall box into a paramount plasterboard wall. We don't have a large amount of airflow as far as I know - the rooms have constant trickle ventilation and hold their temperature well - since reading your first post I have placed one of my digital thermometers close to the stat that gets the most movement past it (its adjacent to the integral garage door - its in a metal box screwed to brick wall) and I don't see any significant temp variation. Are your stats mounted in plastic or metal boxes? Fingers crossed that I don't get the issues that you have, please keep us updated on how it goes.
  9. Emilia Clarke has been following this thread: Emilia.mp4
  10. Keep you in the dark You know they all pretend Keep you in the dark And so it all began Send in your skeletons Sing as their bones go marching in again They need you buried deep The secrets that you keep are ever ready Are you ready? I'm finished making sense Done pleading ignorance That old defense Spinning infinity, boy The wheel is spinning me It's never-ending, never-ending Same old story What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say I will never surrender? What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say that I never surrender? In time, or so I'm told, I'm just another soul for sale, oh well The page is out of print We are not permanent We're temporary, temporary Same old story What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say I will never surrender? What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say I will never surrender? I'm the voice inside your head you refuse to hear I'm the face that you have to face mirrorin' your stare I'm what's left; I'm what's right; I'm the enemy I'm the hand that'll take you down and bring you to your knees So, who are you? Yeah, who are you? Yeah, who are you? Yeah, who are you? Keep you in the dark You know they all pretend What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say I will never surrender? What if I say I'm not like the others? What if I say I'm not just another one of your plays? You're the pretender What if I say that I'll never surrender? What if I say I'm not like the others? (Keep you in the dark) What if I say I'm not just another one of your plays? (You know they all) You're the pretender (Pretend) What if I say I will never surrender? What if I say I'm not like the others? (Keep you in the dark) What if I say I'm not just another one of your plays? (You know they all) You're the pretender (Pretend) What if I say I will never surrender? So, who are you? Yeah, who are you? Yeah, who are you?
  11. My recently fitted Grohe frame had wobbly bolts, no extra nuts to tighten.
  12. I have 5 of these stats and I do not appear to suffer any of the issues that you have. I spent a lot of time checking for the best location for 4 of them and also confirmed that they were suitably accurate with a couple of digital thermometers over a period of a few weeks. Have you tried swapping the stat that is reading high for one that is reading ok to see if the problem moves with it? Heatmiser do a wall plate / surround for the V2 stat - not sure if it would help.
  13. We have an oak floor in our lounge - I am considering re sanding and re coating, I am almost certain we used Osmo wayback when we fitted it. Whilst looking around for alternatives I came across this stuff - it seems to have some good reviews, I have a short piece of Oak handrail to protect so I may get a sample and try it. They do interior and exterior versions. Wood Oils, Treatments & Finishes | Rubio Monocoat Store (rubiomonocoatonline.co.uk)
  14. I agree - looks like the hinge is upside down.
  15. Yes, but not the end of the world depending on the fixing type. Yes - only hand tight - if you overtighten the rubber o ring will be forced out and they will leak.
  16. I am not sure how well it would work, even if it was perfectly level, how would you bleed out any trapped air - perhaps fitting the flow and return diagonally opposite might help. Surely just fitting a small rad upright would warm the cupboard enough.
  17. Recessed mirror looks nice
  18. Yes we used a primer on the floor, not sure which now, and yes the Setaflex above and below the Ditra.
  19. We used a local concrete pumping firm and volumetric concrete wagon - I cant fault them. I would call a few local ones and get them to quote.
  20. We have Cemfloor screed - we used Tilemaster Setaflex adhesive. We also used Ditra matting and we have 1200 x 1200mm porcelain tiles. We fitted Genesis expansion joints in each door way and also across one section of the floor as it is longer than 8 meters. I cannot comment on the matting that you have linked - we chose Ditra as it has a proven track record. We also used the perfect level master tile leveling system.
  21. Dont try and bend it with a spring like that - you wont get a good bend. Dig it out - sweat on an elbow or extend the pipe - it wouldn't take long, or dig it out back to the bath and replace with plastic.
  22. Are you going to fit the integrated appliances into the rental place? We have an integrated Siemens Dishwasher - had it for over 10 years - its very good, I think its one of the upper range models. We have a freestanding Bosch washing machine - again very good We have a freestanding Samsung Condensing drier - again very good. We are most likely going to fit Siemens dishwasher and ovens in our new kitchen (Bora hob)
