Help me with my little penetrations, please.
Nickfromwales replied to ToughButterCup's topic in General Structural Issues
Have you a plan of what's coming through and where? Ground floor WC off a rising stack or straight into the floor? That one needs some real thought if the latter.- 13 replies
- services
- marking out
Sorry @Temp / both, I should have been clearer. Assuming the slab is laid, I was referring to cuts in the tiles at the door thresholds and putting a coloured silicone / caulk in to allow some separation / movement between tiled 'areas'.
Do you have a City Plumbing? This recommendation is for an ideal world btw understandable that you need to get on .
Flushing that laco residue out is paramount as it's horrible stuff. You REALLY should get some Telux and try it. On new stuff it's brilliant and leaves very little residue.
I too have slung many of those....but not ONE off a 'sports' bag
A good solid unified slab then, so I'd second the motion for no decoupling . The only thing I'd do is a couple of expansion gaps at the door thresholds where there could be some movement. Its very hard to just promise someone that it'll be fine, so some caution is always extended, but the absolute truth is that you should get the tilers input also ASAP as it'll be their head on the block not ours. Afaic, if primed and laid with a good quality flexible tile adhesive, you should have no issues. I'd only be worried if you intended to have zones and only heat certain rooms at certain times, but that has been well discussed as an unwise way to use the system. Will you just run at one temp so the slab heats and cools 'as one'?
Hoover and prime the concrete or the latex will come up .
Dragons Den for you, cockles . ???
If that had a slightly more forgiving handle it would be great. Maybe you could retrofit an old sports bag shoulder strap ? I use totes with tubular handles and rubber grab grips. Two of them so they're not too congested. Theyre both full to the brim with various crap btw
Help me deal with a neighbour!
Nickfromwales replied to hmpmarketing's topic in General Self Build & DIY Discussion
Do you know anything about the disappearance of the original vicar Jeremy? -
PVA it and give it a 3-4mm coat of latex, then paint the latex ? It'll be like a snooker table then. Second year with no man shed so I know what you mean ?
How to find a slow leak?
Nickfromwales replied to Fallingditch's topic in Central Heating (Radiators)
Leak sealer should be the absolute last option IMO. Relocating the EV is quite straightforward, I'll add details in a bit ?- 76 replies
That water on the floor was probably the PRV connection onto the boiler having not been tightened up properly so basically the pipework leaks when the boiler discharges, from the actual union on the boiler where the copper PRV tail connects via a brass nut. If you have a basin wrench / similar, see if you can check it for tightness. It's got a rubber washer in it so it doesn't need to be super tight, but most put it on hand tight and just forget about it as it never gets tested when filling and commissioning.- 76 replies
Oh, if your feeling fancy, you could mount the unwanted filing loop and pressure gauge in the office / other as a remote means of checking the system pressure and topping the boiler up. Maybe preferential to going into the dungeon to do it?- 76 replies
You can tee the EV in just about anywhere tbh. Ideally it should be local to the boiler, and if it were me, I'd do that just to have a plumbing-free attic. At the moment you have a cold feed for the secondary filling loop. Not needed. You have a secondary PRV. Not needed. You have a secondary D1 discharge pipe from the PRV. Not needed. Youd have central heating water up there heating the EV and wasting gas. Not ideal. Strip the the ev back to its input connection, bin the rest of it, cap any unwanted / redundant pipework accordingly, and mount the secondary EV at the boiler. Match the two pre-charge pressures at 1 bar and end of problem. The EV in the attic looks a terrible install to me, so is just a liability waiting to go wrong. Far better to have all the boiler related equipment in one location IMO. Do the cold and heating pipework that go up to the attic and terminate there, or do they traverse the attic and come back down to service another rad / etc after picking up the EV ?- 76 replies
Well, if they're driving landys over it then winner winner. A sacrificial rubber mat where your putting the stands down or laying anything heavy / metal would still offer some longevity IMO so that's my 2 cents .
The only thing that marked my travertine, in the bathroom, was my daughter throwing up on it . It doesn't like acidic 'solutions' that's for sure ! A good bit of elbow grease and some clever cleaning of the floor with various cleaners and it's now barely visible, but was a pita compared to the porcelain outside the bathrooms which just wipes clean in milliseconds, regardless of who's done what to them. Is your slab screed, or concrete with Re-bar?
Maybe paint the whole floor and get a large rubber work mat cut, say 2.5m x 4.0 m, so your working on that and not directly on the floor? Also be a bit warmer in the winter. Oil and grease spills can be wiped up off that with ease, but the 2-pack floor paint is pretty damn good stuff for general wear and tear. Is that a 2-part, or just open and apply?
Yup, that's what I found. I also like the fact that it seems to harbour less surface crud, so the joints need less cleaning / refluxing during soldering. Im a convert now, but remember to have a clean pipe and a clean fitting so soldering goes well. What flux are you using ?
Ok. Looking at the pics it's quite easy to see that this guy can get both his Landy and his van on HIS drive. Also, as a medium, he can park his van across his drive, face on, and if he needs to get the Landy out he just moves his van. At the very last resort, the space can be moved 3' to the left and placed at a slight angle, sympathetic to the acces to your plot. I think it's simply a case of meeting with this guy and saying it exactly as it is, as he's not exactly going to be massively put out by moving over a bit, or parking on his own drive. Go knock his door, and just spit it out. . You'll feel much better when you know where you stand. . -
Slightly relevant to the thread -
Turn it vertically through 90o and bingo..... your new bog roll holder ??
You can borrow my Pajero then and shunt his van into the next street. Just a fall-back option. .
