Select the right timber ( roof / floor etc ) at the top of each chart and fill your boots. Link
Can't find the right stopcock (copper to mdpe)
Nickfromwales replied to ProDave's topic in General Plumbing
How much cheaper would insulation be vs deep excavations? . -
I'd be shocked if they pulled you over tap type tbh, unless you get a jobsworth. As long as you have a D-C NRV, you should be ok. Have you been given written criteria for the new connection, or are you just picking up on a existing feed and altering it? If the latter then will anyone actually visit / call to inspect it? -
Yup. Last one I did they wanted 750mm ! One before that they made me core a 100mm hole through breeze block footings and slide a sleeve through to the ground outside. Theres more sense and reasoning for electric cables than there is for water pipes. -
Moral of the story..... "Don't prioritise beer and takeaways over checking and ordering oil"
If you tick the boxes, so..... 1) incoming mains into propery 2) stoptap of whatever guise 3) double check NRV 4) drain off cock ....then I doubt if any BCO would fail you, but the water company may. Can you give details of your supply from the road in please? -
Outside taps are 'accessories' to the main, UNLESS you have teed into the incoming main mdpe as it comes up the drive to the house, at which point you would indeed be right to fit stopcocks as they would then be spurs off the rising main. For outgoing supplies AFTER the stopcock you deffo should use 1/4 full bore as @TerryE has done. Click on my profile and you'll see the blue handled one I fitted for attic isolation on an UVC multi-block. Near silent in operation too. -
Ok. My question was aimed at if it was a boiler / fire ( aka deadly ) flue, I should have been clearer. . I was just going to give you chapter and verse TBH, like stop denting / damaging it for one, but if it's just a humble extractor duct then it's not an issue. . Much better pic. If we can see the whole 'picture', the advice will be better .
Is that a flue liner @Dee? Can we have a wider angled / zoomed out pic please? Ta.
Tres bien. I'll order that, as roof cuts are the final frontier as far as my skill set goes. Currently mastering the nemesis that is staircases at mo as I'm trying to bag more garage / attic conversion / extension work this year.
As much as possible TBH. The more the better afaic, and if ordering the new timber at 4.8m then there's your overlap ( 6.0 - 4.8 = 1.2m tail end ). If ive got the right end of the stick that is .
@PeterW that first link just refreshes BH Is it just my end? Can't get any sense from it. ?
Design Help - Plumber not helping
Nickfromwales replied to DeeJunFan's topic in Other Heating Systems
It's no different to how a regular heating and hot water system is plumbed. The heat source ( ASHP ) produces heat, and it gets pumped out. That flow goes to a diverter valve which has 3 ports..... 1) heated water in from HP 2) flow to UFH / buffer 3) flow to DHW / uvc When the demand is for Ufh, the unit idles at low temp / max CoP, but when the UVC calls for heat ( cyl stat and / or 'boost' controller ) then flow to the Ufh is completely isolated and the HP ramps up to say 55oC to heat the UVC only. When the UVC is up to target temp, the diverter redirects flow away from the UVC, back to the Ufh, and lowers the temp accordingly. The ashp gets a trigger signal, either from the 3 port valve or cyl stat, so it knows when to alter the temp range. -
@Dee Are these part vaulted ?
Dee, have you mentioned that your a brave self-building lass yet . Avatar please ! And are you really doing the dormers ? I know you can drive an excavator so I won't be one bit surprised TBH.
Crossed posts
A ridge board isn't load / weight bearing. A ridge beam is. If your making a 'cut' dormer then your looking at triangles, with the bottom horizontal timber being your ceiling rafter. If that's the case, and they're not vaulted, then you don't need a ridge beam . That help ?
Lost track of this one. My point about the instant is that your dropping down from a 22mm outlet from the UVC and then have the 15mm inlet / outlet of the instant. There will be a drop in performance there without a doubt, how much exactly will be down to the unit, but it is a definite design consideration. Also, I'd be VERY interested as to what the Steibel unit will produce as useful heat at anything over 10/12 litres per min with cold water going in. @JSHarris, can you add some details if possible please? Ta. In a nutshell yes. With a possible 12kw of direct electric heating ( 4 x 3kw immersions @ 2 per tank ) I seriously doubt you'll ever need a back up on the back up. By all means fit a cable for an electric instant, but I'd hold off buying and fitting one unless it's needed. Plumb both cylinder to the ASAP ( low grade heat to the TS and high grade heat to the UVC. UVC selected as manual boost only for when pv isn't generating ). It would be, imo, madness not to as you'll have oodles of DHW, a backup plan in case the ashp goes down / off for maintenance, and most of your DHW supplied at the better range of CoP from the ashp. -
No refunds given ✌️️ Last time I 'sabotage edit' one of Peter's posts ? "If you can't do the time, don't do the crime"
Oh, and sorry @Dee. Another innocent thread hijacked and disgraced. Freedom of speech isn't all it cracked up to be
Penis, I mean truce.
You may want to check your last post. I fear you may be stalking me especially on Thursday evenings in Merthyr where I dress up in ladies clothes and dance for 50p for the boys....
This board has some great features. You can select a little slider tick box on any thread. Where it says Submit reply just slide the 'notify me of replies' doo dah. To notify a member that you've mentioned them in a post just type @ then the member. A drop list will appear and you simply select them. Like this @Dee. It'll go blue when done correctly.
The door is open, he's has only to walk through. There are a few 'missing in action', a bit like yourself, but hopefully as time passes the repeat offenders will surface .
