Only advice to add to this phase is to add one or two automatic air vents ( bottle vents ) instead of the manual ones. Will make commissioning a much easier job . These will screw straight into the empty holes ?
I did an entire oil boiler job once in around 400mm and less crawl space. Fitted all the central heating rads, pipes down into the 'basement', then under I went to extend, clip, and insulate it all from 10mm to 15mm to 22mm. And a poxy favour job Just resign yourself and crawl around until you love it. Then start working. Enjoy ?
Then drink the vodka -
Meths. . -
Welcome aboard . Another from the land of the hot press.
- 13 replies
- 3
- n.ireland
- norn ireland
(and 2 more)
Relax. It keeps us out of trouble ??
Game, set and match
100m2 is not quite so limited . Also, , for large installs you simply run multiple ring mains accordingly How many rewires have you done in a medium sized house that have a ring for the kitchen / utility sockets, a ring for upstairs sockets, and a ring for downstairs sockets? More than one? ( I know I'm going to regret asking, but I'll take what's coming )
Best to get back to cable sizing
Just all the TF builds I've been on have had to have the deck down first so the stud frame / cassettes can sit on top of them. Trying to work out how your dealing with that but needs must!
I don't see how you can leave the floorboards out of the first floor with a TF build . You not using T&G Dave?
Unvented Cylinder D2 discharge pipe calculations
Nickfromwales replied to ProDave's topic in General Plumbing
22mm will be ample if there's no immediate invert. They're what cause the problems. ? -
Just have a joint in the pipe . Maybe fit one of these where the joint is going and use this as your connection point for the basin and utility etc . Use metal brackets for the horizontal run, one just before the break, and another two on the remaining run before it goes vertical to the new loo, ( as plastic ones are a bit shite on horizontals as only one side of the clip really gets strained ). I often find these broken over time with the run all shapes. .
How much vertical fall can you get from start of D2 to first invert ( to horizontal ), and then how much horizontal before the next drop Dave? -
The blue walls match the sky ?
@ProDave / @Steptoe What about putting a piece of soil pipe in that 300mm section to allow room for convection air flow? Could you have mitigated the 6mm cable by ducting through the insulation?
Thanks for the very informative post . Personally I feel that most would put those small losses down to eventuality, and accept that there will be some drop in performance but not enough to re-write the books. I certainly don't see anyone rushing to do a ring in 4mm2 cable but I do always run a 10mm2 for every instance that requires only a 6mm2 as the sliding scale of performance is most significant with higher loads. The savings stated may have to be toned down slightly to allow for additional labour / time for working with ( terminating ) larger cables, fitting deeper boxes etc so I really think this should be considered as 'case-specific'. I maintain that it's down to the commissioning agent to ascertain sizes / suitability of cable runs, so it is in fact a little strange that the question has been asked in the first place TBH, unless the op is wiring themselves and has already agreed to get a third party to sign off. In which case, again, they should have already designed, and specified all of this criteria from the outset. Lets wait for @lakelandfolk to rejoin for further input and clarity of the situation
+1, which is why I've added the 'disclaimer' in my last.
Agreed. Plus you can allow for diversity ( unless that's already been factored in by the regs which I'm unsure of ). Again, ageeed. NOTE : Each install is unique. Let's remember to dispense advice accordingly, in a positive manner, and get the op to as good a resolve as possible. Cable sizing should only be summised under qualified supervision, IF you do not deem yourself competent to do so. We should also advise that for a 3rd party sign-off ( certificate ) said qualified person will need to witness the cable installation, from start to finish, in order to ascertain its compliance, and satisfy themselves that the type and size of cable used is completely fit for such purpose. @lakelandfolk, who will be signing-off the work?
Ok. Firstly I'd look at ventilating the crawl space with a blower / BFO fan. Next, go outside and remove the manhole cover to ventilate the foul network so any accumulated gasses can dissipate. Then I'd get a 4" angle grinder ( gloves goggles etc blah blah blah ) with a thin slitting disc and cut out a slot in the middle of the piece you've marked out for removal, say 150-200mm high and as far around the stack as you can safely get. Before finishing the cut, gaffa tape / secure the off-cut so it cannot fall down the inside of the pipe Once removed, then you can start to remove smaller sections of the remaining piece of cast, piece by piece, as you can now feed the grinder deeper into the pipe with the space you've gained by cutting out the first section. Roll up a couple of rubble sacks and shove them down the cast to act as a debris plug. Complete the bottom cut by angling the grinder down slightly, taking care as you complete the cut as the grinder may bite if any downward force / weight is free to move downwards. Once happy that the cast won't drop any further, angle the grinder upwards and complete the top cut. Mark out the actual size of the section you need to remove and repeat the above until your done. Bingo bango. Edited to add : don't go for the full cut first time as you may damage the pipe during the initial cut . Always cut out a section first to see if the upper section of pipe is secure and then proceed to the final cut accordingly. Oh, and good luck. ?
Daves BCO acted accordingly for a property which would not, otherwise, have had a vent to atmosphere. By offering an alternative route to atmosphere he would have got off the hook, pretty much as he says above . For the record, the vent does not have to assist / aid the rising pipe work in the property, it only has to vent the accumulative gasses / stench to atmosphere and can do this at pretty much any junction / location, as long as it's connected to the main foul network with an appropriately sized pipe. For eg, on the far right of your property you have a pine end, so you'd be able to rise up that to the highest point ( centre ) and terminate there, and you'd also be able to use the smaller size 3" pipe ( as its not taking any water / other ). Edited to add : with the above proposal you can then fit the AAV's accordingly where required, so you'll still need to accommodate the pipework internally and be able to access the AAV for inspection / replacement.
Only prob is at 330mm you'll have no real length to get a decent saw stroke going. Cast is a b'stard, has anyone here ever had to cut one / has cut one? I have, and it's a pig of a job.
Put a 3" vent on the rear facade and have no penetration through the roof whatsoever? How far along are your groundworks, and are you mains sewerage or treatment?
