TonyT
    6
Everything posted by TonyT
  1. My renewal came through today currently paying Scottish Gas 3.061 per unit if gas 14.778 per unit of electricity both have a 15.891 daily standing charges if anyone has a supplier that can beat these and provide a referral link when I need to change at the end of July just incase someone can get something out of it too
  2. contains TV cabling/distribution data cabling netgear WiFi router netgear switch UPS for WiFi router
  3. Agree with the MCCB. But the previous poster advised a MCB.
  4. The architects I know advise the clien on how to spend money knowing fine well they are in a percentage of the final build cost.
  5. Advise the bricky of this when he is quoting and let him deal with it.
  6. My house wrap was only guaranteed for something like 4 months exposure to UV Tyvec house wrap I think from memory.
  7. The single phase mcb/rcbos that fit a single phase board fit a 3 phase board manufacturers don’t mix them about... you wouldn’t need an extender you get large 3 phase boards. it’s a more elegant designed solution in my opinion.
  8. There is no regulation about proximity of different phases in close proximity to each other. personally I would go for a 3 phase board it’s what is done in the industry.
  9. You probably wouldn’t get discrimination/selectivity between mcb/rcbos in the consumer unit best to stick to a fuse.
  10. https://www.tlc-direct.co.uk/Products/WYDSF100M.html?source=adwords&ad_position=&ad_id=315107931576&placement=&kw=&network=u&matchtype=&ad_type=&product_id=WYDSF100M&product_partition_id=987624279487&campaign=shopping&version=finalurl_v3&gclid=EAIaIQobChMIuvyIwqPl8AIVT7LVCh1SBgu6EAQYASABEgIfhvD_BwE if it’s more than the max permissible you need one of the above units to protect your cable. the one that the DNO supply protects their cable and meter.
  11. Each DNO is different but the common number is 2or 3 metres max, then you will need to run a sub main with suitable fusing of your own. your local electrician will know this
  12. IDC is designed for solid cores fixed wiring is solid cores patch leads stranded
  13. Option 2
  14. https://www.steelaccessories.co.uk/products/continuous-high-chairs-wire-deck-chairs?variant=39487334613154
  15. I don’t thing the regs has metal ceiling supports as cable containment. looks rough
  16. No plumber would be using car body filler, buy a good quality silicone.
  17. http://www.hetas.co.uk/wp-content/mediauploads/Ventilators.pdf hetas guide to be vent, a few years old but you will get the idea
  18. With rods you have to watch the zones of influence so if you hit a rod 1.2 metres into the ground the next rod if you decide to add another needs to be 2.4metres away So sometimes it’s worth just throwing the tape into a trench , backfilling with bentonite if necessary and away you go.
  19. If you have trenches rather than rods use copper tape, bare copper 25mm wide by 3mm thick in the trench and terminate it into an earth rod chamber, there join it to a 16mm earth conductor. This allows the joint to be inspected.
  20. Use threaded screws to metal dowels. screw wood screw part into timber leaving machine thread exposed for bracket with a nut.
  21. As we don’t know the layout how could we comment. if space saving meant this had to go in the garage I may be inclined to build a small cupboard and insulate it to reduce losses. Hot water return circuit could minimise this along with smaller diameter pipework.
  22. I have a 1860 Victorian end terrace, nothing fancy about it. just that I have year on year as general building improvements have taken place I have improved the thermal performance of the building, to lower running costs, for my old age when I will be living off my pension, and no doubt energy will be an expensive commodity. Not sure why things need replaced every 10 years, my office has its air con still working after the install date 21 years ago. well installed and maintained equipment will last.
  23. Best insulate insulate insulate and get that air test from 6 to something of 1 or under. then any heating source will cost a negligible amount to run
  24. Pour some self levelling compound to make the difference up
  25. Get the joiner fitting the worktops to router out a rebate for the led/trim/bezel. That would work
