TonyT
Everything posted by TonyT
The manual says it’s a 240 volt version
What’s the depth under the floor? maybe you can crawl under? I used 100mm of rock wool slab friction fit.
Wet and forget. Or patio magic to clean deck with no effort. then a clear decking oil for me.
Ok for closure the name is clickfit and are available on solartradesales. cheers
Storage cupboard off the entrance. seems a logical place for a consumer unit
Cheers appreciate you looking but no match. plan b
I have looked for a few days but not come across a match, does anyone recognise this end profile? possibly the original install was about 10 years ago, just before I decide to go down a different route. cheers
Come on guys, everyone deserves a lunch break! I wouldn’t want to work for some of you, standing over the shoulder ensuring you start at 8am. what about when they are thinking about your job at night, ordering material, picking up before you get on site. too many spreadsheet warriors!
Why doesn’t the delivery lorry not come with a hiab?
Kitchen Electric / Oven Isolation switches
TonyT replied to wozza's topic in Electrics - Kitchen & Bathroom
You could argue that the isolation switch is already provided by the big red isolator in the consumer unit and nothing else is required. -
If you can get the permanent connection in, the utility companies will only mess you about and when you want the permanent supply they will be nowhere to be seen. Get the supplies in early and let the only drama be the painter not finishing on time?
Boundary box- good name https://www.scottishwater.co.uk/-/media/ScottishWater/Document-Hub/Business-and-Developers/Metering-Services/200718appendicesV23April14.pdf
Ebay £500 for 10off 245 Watt panels plus rails.
torn between doing nothing and jet wash.. vinegar seems too much of a big task.. appreciate the info
Just acquired a second hand set of panels and rails, wools like to clean the rails up a bit before installing on my garage, anyone offer advice on the best way to clean aluminium rails? Cheers!
Do you have a loft? stick boiler etc up there make sure area floored, safe to access and with light
How to strengthen brickwork which has spalled from removing plaster
TonyT replied to HaloThree's topic in Brick & Block
Definitely worth it, to secure bricks and from droughts etc Might be worth using some expanded metal lathe fixing that first and cement rendering over. -
I can’t imagine in the day and age of GDPR any council would be giving out info, if it’s not available on the planning portal.
I’m a festool sander man, but if it’s for a few occasions get one out of Aldi/Lidl, use and abuse and if it breaks get a refund. Local store for easy return.
Common to have a gap when integrated appliances are used, let’s the dishwasher for example pull down and not have to notch the kick plate.
Architect has done a wonderful scheme but-
TonyT replied to DragsterDriver's topic in Surveyors & Architects
So was it like you asked for a townhouse and he designed a wonderful bungalow? -
Part ways with the architect. They are at it. -
And once you have done the joists, and you have any left over timber add some mid point noggins to stiffen it even further. looks good https://www.trada.co.uk/media/3809/design_a_deck_planning.pdf some good info in the link
Do I need a tv aerial
TonyT replied to Russell griffiths's topic in Networks, AV, Security & Automation
Can you not take the aerial cable somewhere else? Inside a garage? out on a perimeter fence, but cable underground? -
Additional steelwork off the existing purlins?
