Bonner
Everything posted by Bonner
That’s good going! I think mine will be twice that but haven’t looked at the bottom line since the main contractor pulled out. Just pushing to finish then add it all up. Not at any cost, we are spending wisely, just can’t predict the final cost. On the other hand, we have no idea what it will be worth in the current market so can’t say if it’s worth it financially or not. Hopefully we will enjoy living in it and look at back the build as a life experience 😬
Cheap(ish), fancy(ish) toilets - Toto, Vitra, Grohe
Bonner replied to puntloos's topic in Bathrooms, Ensuites & Wetrooms
Double check valve will solve that -
Have you thought about a bidet? 🤔 -
Cladding and Window Colour Combination
Bonner replied to benben5555's topic in New House & Self Build Design
Most people let their cladding naturally weather to silver grey, avoiding the need for regular repainting, have you thought about that? Colours are personal choice and some go better in different locations, you can find inspiration on sites like Pinterest -
DIY Kitchens have a useful planner with 3D visualiser which you can easily move things around.
Tight Utility Kitchen design - is 3000mm sufficient?
Bonner replied to puntloos's topic in Kitchen Units & Worktops
If the drawing states 3000, you are very unlikely to finish at that after building tolerances, plaster etc. If you want 5x600 units, you need to start with 3100. -
+1 waste of time, the edges should be butted up to an upstand anyway
Been quoted list less 70% and still 30% more than on line retailers!! My local merchants is normally empty apart from a couple hours in the morning. Meanwhile they have to pay for premises, energy, staff and even a manager, with limited turnover. They will never compete with on line retailers and will only survive as long as customers are willing to pay trades ‘whatever it costs”.
I used Siberian Larch in the end but looked at many alternatives. I would not be comfortable with timber imported from West Africa even if it does claim FSC certified. Apparently not durable in it’s raw form, needs to be thermo-modified which then depends on the consistency of the process. After thermal treatment it is brittle so certain profiles not recommended.
On a previous house, I did about 10 different mixes before I arrived at a close match. Even then the colour changes with age. Try another builders sand (bagged), a bit of Portland cement with the white stuff ...
I went to see a passive house which had only IR heaters. Could work in very low heat demand properties but otherwise I expect expensive to run. Have you done a heat demand calculation? Is this single or double storey? If two storey, you are unlikely to need much heating upstairs. The UFH cost seems very high. And yes, it is likely to put future buyer off.
We also went with dark colour inside (RAL7015) even though the supplier offered white. They contrast the white walls and frames the views.
Thanks, I needed to hear that 😬
Do I really need a SE to calc/spec structural elements of this garage? I could do without the fees unless they can propose a more cost effective construction. The main element is the beam for 5m span, but I was also looking to confirm specifications of the two smaller beams and wall piers. It will be inspected by local BC due to size but they seems quite relaxed about it.
I agree the drawing is not clear but the note states twist strap. It has 90 deg. twist whereas the other type has 90 deg. bend
If you Google 900*100*30 twist strap you will find the right product. Designed to strap the truss to the wall, not fastening the wall plate which is what the angle straps do.
I used to live by a woodland, got a gleaning license from the forestry commission. Don’t think other people bothered but it was only a few groats a year.
Cheap sturdy vacuum cleaner for DIY cleanup
Bonner replied to Gill's topic in General Self Build & DIY Discussion
+1 for the Titan from Screwfix which has a power take off for tools (despite its power consumption, it’s not running long enough to worry me that much). -
On Channel 5 last night. Interesting prefab build, on a spectacular site with nice finishing details. https://www.dailymail.co.uk/femail/article-11732091/amp/Couple-spend-1-1million-building-dream-Scandinavian-home-Scotland.html
MVHR Install
Bonner replied to crispy_wafer's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Wow that’s tidy enough! Shame to cover it up 🙂 -
Fitting shower trays - sand& cement / tile backer / tile adhesive?
Bonner replied to Moonshine's topic in General Plumbing
Spoke to my plumber (who is very thorough in everything he does). Never used sand and cement. It used to be tile adhesive but now it’s the cheapest mastic on the shelf (No nails, silicone or even caulk). It’s just a bed to prevent concentrated loading -
I have 7015 slate grey, slightly lighter than anthracite, so not so common as muck and happy with it. I agree with @craig, a dark grey would spoil the character. Why don’t you have two colours, light grey (7032?) in the old part and a darker shade in the modern extension? https://enlightenedwindows.co.uk/tag/ral-7032-pebble-grey/
The ones I had in the past were 300W and took about 30mins to reach temperature. Water heated, at least by an ASHP, are not faster to warm up but they always on. My point was relying on a PIR to switch on a towel rad may not work very well as you would be finished before it warms up.
Guessing you have a gas boiler? With an ASHP towel rads never get too hot and are always on, controlled by room and tank thermostats. I did consider electric and agree they could be a better solution for some. They are very slow to warm up so wouldn’t rely on a PIR sensor.
