Bonner
Everything posted by Bonner
In a hard water area they quickly show limescale (within days!). Scratches to the coating depends on quality and usage so can’t comment.
Never seen this on a drawing. Assuming they are built into the inner leaf of the cavity wall, it is the same as floor joists which are not treated. Just make sure the cavity tray is installed, then it will be fine.
- 9 replies
- tanislised timber
- preservative
The L shape doesn’t really add much useful room, makes access to the HW cylinder awkward. Better to keep the space for your pantry.
As @Alan Ambrose says, don’t expect to make any profit these days. Plots prices and build costs remain high with resale values generally uncertain. Of course it depends on the specific location and local supply vs. demand.
Tiling on anhydrite screed which has been down for over two years
Bonner replied to GaryM's topic in Floor Tiles & Tiling
The screed might not crack but large porcelain tiles will expand at a slightly different rate. I also laid 800mm tiles on Anhydrous screed and wasn’t going to use a mat but decided to in the end. That’s just my experience, @nod is the real expert! -
Separate issues; moisture, adhesion and movement. No doubt it will be dry after 3 years. Any remaining laitance will be fairly obvious and easily removed. A decoupling mat is still recommended to allow thermal expansion without cracking the tiles. -
Should I fill the hole under this window with expanding foam?
Bonner replied to vagrantly3893's topic in Windows & Glazing
No reason for the gap, fill it up!- 1 reply
As above, opening window needed for ventilation but not fire escape
Unless I am mistaken, it’s fine as it is. The bedroom door opens on to the hall. Even though not directly it’s still part of the hall and acceptable fire route.
2 years and a bit after breaking ground....
Bonner replied to Moonshine's topic in General Self Build & DIY Discussion
Ha! No problem keeping an eye on the builders from there 🤠 -
It says BSP one end, compression the other. Isn’t that the compression end? See if it goes on a comp fitting?
Looks great! Must have been challenging just getting out of the ground, steep site and proximity to neighbour! -
More or less what I paid for a Grant 13kW HP MCS installed. I would have installed one myself but no time and benefit of 7 year warranty (for what it’s worth …)
I would go for a standard oak staircase from one of the specialists (Pears, StairBox, TK etc). It will be impossible to match the colours due to natural variations, just look at your flooring picture 😉
Really depends on what can support the landing. Is it butting up to 2 walls or 3? Can you share a drawing?
Just make the slab separated from your house wall/foundation. Don’t forget you need to maintain certain clearance for airflow according to manufacturer’s instructions.
Building a dropped ceiling over kitchen peninsula
Bonner replied to Owool12's topic in General Construction Issues
2 x 1 battens would be cheaper and easier, there is little weight to support -
I have got this one which has a removable stabilising bar. It is not recommended to use without the bar but on a narrow stair case there’s not much wriggle room … https://www.screwfix.com/p/werner-3-section-4-way-aluminium-combination-ladder-3-51m/503kh
Cleaning cement mixer for 2nd batch of mortar
Bonner replied to smart70's topic in Bricklaying, Blockwork & Mortar
If you’re mixing the same day, just slosh some water around the drum to loosen the remnants and mix it in with new batch. -
Spot the ball... er Stud - for ventilator through wall
Bonner replied to RichardL's topic in General Joinery
As above, either lots of exploratory holes or a neat cut out of the PB -
Size of patio dilemma
Bonner replied to canalsiderenovation's topic in Landscaping, Decking & Patios
IMHO it looks a bit tight. Think circulation space around your table, do people need to squeeze past the window or planter side when those chairs are occupied? I would add another 1m to the width. -
I paid less and got less. For example, staircase can be designed for free by one of the specialist suppliers but if the architect does it, you can be assured it will fit! Electrical layout can be done by yourself but useful to get a professional take on it. If the architect works with the structural engineer, you have got a better chance of avoiding pitfalls during the build. All lessons learned for me. All in all, it seems a reasonable price.
As it says in the installation guide, 2-3mm joints. These are normally formed naturally by the shape of the paver, no spacers required. Bear in mind they have a ‘face’ side which is the way they should be laid.
