dpmiller
Currently
Viewing Topic: Floor tiling on suspended chipboard floor - do I do same again...........
Everything posted by dpmiller
Extension- Last Stuff.
how did the builder insulate the sloped ceilings?
- Down the big long lane...
Panasonic 9kw Aquarea wiring diagram
take the cover off that stat and see which wires are connected. I'm guess in the two you can see are for it's thermistor sensor and it hasn't yet actually been wired to anything else...
https://www.oso-spares.co.uk/thermostats/80345---thermostat-for-boiler-delta-cylinders https://osohotwater.kmc.fless.co.uk/content/uploads/2020/03/OSO-DELTA-DCF-F1-MANUAL-UK-142227-00-1.pdf
does that wee stat even have wires connected to it?
seems not?
Liquid Screed Recommendations
no laitance with our gypsum?
Buy in haste, repent at leisure : ElectriQ dishwasher
It's the brand of Appliances Direct AFAIK. I bought one of their cooker hoods and it was very impressive on test. Not fitted yet mind..
Panasonic Air Source Heat Pump
if so why would a new pump fix it?
Grant Vortex Oil Combi boiler spares help
https://www.grantuk.com/professional/spares/oil-boilers/control-panel-spares/temperature-control-pcb-with-sensor-mpcbs54e/ looks like the pcbs56 doesn't have the sensor sockets but this does?
No deal Brexit impact
/never mind what they'll do with stuff being sent to this "other" part of the UK...
- Adjusting a UPVC Door
Solo Timber Frame
not sure what's currently happening what with COVID etc, but some of the NI-based frame companies will travel over to erect a kit. You might try Leadon, Kilbroney, Kudos, Kingspan. Some of the other companies aim more at the volume market and are less likely to be interested, but any and all may be happy to put a kit on a lorry and send it over, with an allowance for local sourcing of insulation etc.
Try my hand at most things
try pushing a damp string up a hose filled with peanut butter @SteamyTea they're steerable for good reason...
Mixing mortar
local concrete guy sends one of his trucks out with mortar each morning to top-up tubs he has out on sites. Whatever is left when the truck comes back is tipped for some of the small businesses to descend upon, vulture-like...
Evidencing self consumption post FIT
If you've got a diverter, do you really need to think about this even?
4G/5G booster
I use EE and the local tower is an 1800 one here: https://www.4g.co.uk/4g-frequencies-uk-need-know/
4G/5G booster
this is the one I sprung for https://www.aliexpress.com/item/4001051426244.html "outdoor" antenna is in the attic, I'll probably get it outside when we've scaff up next. I've two indoor antennas on a T-piece, one at each end of the upstairs balcony. Without the booster, there is basically NO signal in the house. With it on, there's two bars upstairs and 1-bar downstairs, only a few dropped calls. there are variants for different frequencies, you'd need to check which bands your operator uses.
Oil Boiler Locking Out
cupful of ash-free 2-stroke oil if you must, or a gallon of diesel. But tight pumps tend to gall and seize in a non recoverable manner... No, I'd be happy it was the cap tbh although the filter is worth a change. / you can see efficiency improvements by installing a Tigerloop, havng a constant head of pre-warmed de-aerated oil *does* work.
Really dislike the ads running on the radio over here at the moment- "do business with the rest of the UK? find out what you have to do NOW" b'stards.
4G/5G booster
legal or illegal? there are plenty of chinesium boosters and they work well. IIRC @Jeremy Harris discussed them a couple of years back. I've one for EE's frequencies and it's works bleedin well.
What is Energy Integral
Ask Zoot?
