dpmiller
Everything posted by dpmiller
I'd just go 150 insulation and 50mm pumped screed for the same build height. Conveniently matches a block...
2020's last laugh: a leaking roof. Advice please.
dpmiller replied to ToughButterCup's topic in Roofing, Tiling & Slating
Only the finest Chinesium for me, and darned handy it is too. -
Avoiding poorly designed, fancy(price wise?) devices
dpmiller replied to puntloos's topic in Electrics - Kitchen & Bathroom
we've a Panasonic free-standing combi microwave with no turntable, and it does all modes outstandingly well? -
MVHR dripping!!
dpmiller replied to Pete's topic in Mechanical Ventilation with Heat Recovery (MVHR)
One other observation on my system- what kind of trap do you have on the drain? If airflow is imbalanced (too much extract) the extract fan is powerful enough to pull water UP the drain pipe from where it'll flood the H/E drain area and even flow over the bottom of the fan when it'll splash water into the extract outlet duct. Suggest checking the drain pipework is well sealed and the trap functional... -
seems it would help with your button and menu issues? -
read the manual before purchase. -
MVHR dripping!!
might pull the covers off and check that the H/E is fitted centrally. If it's moved in transit it could be leaning on one or other of the covers, distorting it away from the foam seal. / mine's normally absolutely dry, but currently- extracting a tonne of water from the screed- there's a weep from the bottom of the front panel... -
we bought a plot with planning retained on footings. A change of design took a *long* time.
to have retained planning, the footings must've been inspected by BC. Talking them into getting the files out of storage might take a wee while these days?
drains are already in. If you can use the current footprint and the footings suit what's going on top, carry on. If not, sadly it's digger and crusher time...
why don't you search the Welsh B'regs and find out, yourself?
What is your design floor temp?
unplugged the extension lead?
how much Danish bacon is bought in the UK?
What is this spinning bevel edge planer called?
dpmiller replied to epsilonGreedy's topic in Tools & Equipment
one of these @vfrdave https://www.ebay.co.uk/itm/Compact-Router-Trimmer-Laminate-Kit-Trimmer-Tilt-Plunge-Base-Guide-for-Makita/324222818852?hash=item4b7d2f9a24:g:2ZAAAOSw--xfAGqL but mine came from a guy in Crumlin that brought a batch in. It's grand for the money, the plunge base is very solid. -
is an accumulator an option?
needed to spend the lump money @Declan52. Skim will probably be a room at a time at this stage- I need habitable, not finished, for now.
- 367 replies
- ireland
- timber frame
you need a brave thickness of it I think tho? Well we've a floor. It's solid enough to walk on, hot enough to get the whole house to 17c, and there's water p*ssing down all the windows and doors... @SteamyTea wanna have a go at how much energy 10m3 of gypsum has goiing spare as it cures?
- 367 replies
- ireland
- timber frame
Willis powered UFH Electrical Fault - HELP
dpmiller replied to Triassic's topic in Underfloor Heating
generally the modern willis is a soldered-up unit, it's rare to see one that has a seperate shell and element. -
this side of the Pond and no, not expensive. Not terribly high spec either tho...
- 1 reply
The BCO isn't coming back, won't be measuring it, and the builder won't be fixing it. But you will live with a cold room unless you work out what should've been done and check what was done. If the room was warm, none of this would matter; but you've got a problem and you're currently trying to diagnose it.
"roughly sure" isn't good enough.
@Conor yes they were, and we were pretty set on hemihydrate from the beginning. The latest cement-based one for CES is apparently very good tho, I'm told.
- 367 replies
- ireland
- timber frame
how did the builder insulate the sloped ceilings?
yes, there's a slip layer down. Still fearful of a breach tho...
- 367 replies
- ireland
- timber frame
