Everything posted by markc
Good morning and welcome. brick collector, now there’s a new one
Grand Designs - Chisel Cliff House up for sale ay £10m
markc replied to AliG's topic in Property TV Programmes
While watching the programme I thought it was over ambitious and more like a hotel build than a house. The eye was kinda cool though. -
Can you remove the roof tiles without it being 'demolition'?
markc replied to DG123's topic in Demolition
Removing slates or tiles using a mewp is slow and back breaking. (Leaning out of the cage to reach the roof isn’t easy). As above, cut your losses and save your time and energy and let the digger do the work. -
+1
One day I hope to have enough free time to #£&@ about like this. Not jealous much …. Honest .
I would go with condensation forming on the stack, then running down
Does concrete cast furniture need to be monolithic
markc replied to Adsibob's topic in General Structural Issues
Self levelling will be fine, just roughen the concrete surface to let it get hold (assuming it has been floated) -
Just because he is/was registered or qualified doesn’t mean he is or ever was any good. there are a lot of highly qualified unemployable people out there. what is your time worth? Do you really want to spend your time and money educating this guy? cut your losses, learn from the lesson (cheap is cheap for a reason) and find someone who you can work with
Mulitool is very slow cutting through nails even with expensive blades. Knock or bar the timber back as far as you can then get a hacksaw in. Much quicker and easier
Omg! Think I need to be looking around Scotland for a plot instead of Yorkshire
Much easier to calculate the volume of tank and make a dip stick. anything that obstructs the filling flow will cause problems. ifyoudont believe the delivery truck gauge get them to put 20 litres into a container where you know the level. highly unlikely a reputable retailer will be fiddling the meter.
What fittings do I need to connect to my shower mixer and heads?
markc replied to Conor's topic in General Plumbing
Yes they will be ideal if you already use Hep20 -
What's the highest temperature rated paint available?
markc replied to Oxbow16's topic in Stoves, Fires & Fireplaces
What are you “painting” anything inside a stove or boiler soon burns off or acts as an insulator. -
If the stacks project into the rooms and the blocks ARE on the party wall then the stack must be yours …. Or am I missing something
Asking your screed supplier is sound advice, as you are tiling then I can see scope to reduce the drying time as the floor finish won’t be susceptible to moisture and it’s unlikely you will be taking the screed to anywhere near is max compressive strength. drying time also depends on how wet the screed was when it was laid.
Partitioning Garage for Utility, ideas?
markc replied to JKami84's topic in Garage & Cellar Conversions
Insulating a floor properly would mean raising the floor height substantially or digging down to add the insulation. any insulation is better than nothing, even a couple of layers of insulating underlay and a covering of laminate would make a big difference to painted concrete. Roof void if there is one is the ideal place to insulate above or insulating plasterboard to the ceiling for an “easy” improvement. is the outer wall cavity or single brick? -
As above, real slate has been used for hundreds of years and proved itself to work well, but as a natural product it has flaws, is not consistent and often breaks when you least expect it. ’fake’ slate being factory produced is very consistent, rarely breaks but does look “too uniform” in places.
No problem with a Hardybacker over sailing this corner, even 6mm is very strong when covering voids. if you want to buildout, clean surface, key with diluted pva, ordinary mortar mix. if you leave a small hole at top of backer board this could be fixed in place and then push mortar through the hole and let it drop into the void. But really not needed.
Notification of Statutory Undertakers?
markc replied to Tracey Gardner's topic in Party Wall & Property Legal Issues
Why should it be anyone’s “responsibility” ? loads of old services are buried in strange places, maps and plans only give a rough idea of pipe and cable locations. It is good practice to look around for access covers and man-holes etc. To get an idea of what could be buried but gas and water can run for many miles without any indication of their presence -
Sounds like a balancing problem, anything under pressure will always take the easiest route, balancing rads forces water to go around the whole system by restricting the outlet of rads. look it up on YouTube etc.
The installation Cert is issued on completion of testing. Only one Cert required. you really want the same person or company to complete 1st, 2nd and test or it will be a nightmare of blame and complaints from whoever does it.
