markc
    22
Everything posted by markc
  1. Never understood people concreting up against external walls. Also looks like the on Crete slopes down towards the door - this will be forcing water to drain down the face of the wall under The door area. you can free up the air brick by cutting away a strip of concrete in front of it and even adding a low power bathroom type fan to keep air moving.
  2. As a turnkey package then the contractor walking away is unlikely, the labour on the other hand is very likely leaving you with possible delays etc. of course you are aggrieved, just try to find an amicable solution rather than going in all guns blazing as you have a long way to go. Tell them that you are not happy and are going to try to rectify the problem yourself and you will deduct the cost at the end …. This could well spur them into sorting it out and being more diligent in future.
  3. That’s why Joe’s suggestion is a good compromise, they are not doing re work but see that you are not happy and want the gaps filled. Yes you have to do something but that’s better than them walking away or getting really annoyed. A bit of give and take will get you a better build and much less aggravation.
  4. Nothing wrong with fitting kitchen then laying flooring, but fit the end panels after the floor has been laid. flooring up to end panels looks terrible and is a water trap. Fit end panels with a couple of mm gap underneath to allow any water to dry without affecting the panels.
  5. I’m guessing the aerofoil wing provides the ‘lift’ and the forward motion turns the propellers connected to generators. im sure fixed generators with tidal acting on blades would be less problematic and easier to maintain
  6. No need for heat, acro or jack underneath and push them up. ** do not whack it, that will cause paint damage and additional distortion. Slowly push them into place.
  7. You can fit without top rubber (some people think the black rubber looks like mold so don’t want it) but then needs a good flexible clear or white ct1 or silicon
  8. Sorry that was a bit harsh, it’s your build and you are wanting it right, but try not to find fault with everything or you will get more and more stressed as the build goes on.
  9. If the outlet is in that corner then it’s probably just being held back by the membrane and a bit of leave debris. If the outlet is in another corner then you have a dip … how deep is the puddle?
  10. ??? Are you trying to find problems that don’t exist? you are at slab pouring stage and appear to have a good job done so far, as the build progresses there will be problems and hiccups, save the stress and fretting for those.
  11. Why flexi saw? You want the trimmed area flat and level with the rafters or studs. bow saw blade with a bolt at each end to make holding easier for awkward areas but you can do pretty much everything with an ordinary wood saw … if need be bend the blade near handle to crank the handle away from wall …. But then you end up doing some cuts uphill because the saw becomes handed.
  12. Smoke bomb or just a candle (light and blowouts lit smokes) incense sticks work great too, hold it in front of the area where fire will be, if smoke is pulled into and up the chimney then you are ok. If smoke is pushed into the room then you have downdraft
  13. Water will look like puddles on the flattest of surfaces. This looks pretty good. Unless there is a deep bit in the larger area then I would be very happy with this
  14. Yes one on top of other with staggered joints
  15. +1 on @Russell griffiths comment. Rubber membrane roofs and gutters often have raised “dam’s) at outlet points to retain a shallow puddle. Never understood why but seen it on loads of membrane details.
  16. Mobile phones got smaller and smaller until someone realised they could watch porn on them ….
  17. Good point … oil is running out, we must cut motoring costs …. Sell bigger cars! ?. I wonder how many 4x4’s every go off tarmac or tow heavy trailers?.
  18. The grant done work is often worse than not having any. Poorly fitted, water getting behind, cold air gaps and horrible work and detail around window and door reveals
  19. Depending on floor finish there is no need to floor fix. If you are screeding then the screed will secure the partition, remember to double sole plate to distribute load across insulation and also leave enough above screed to fix PB to
  20. +1 to @gravelld comments. Easy to do badly, can be very tricky to do right
  21. Trust estate agents to find any excuse and way to inflate prices… brexit doom and gloom … we expect property prices to rise. a meteor will destroy the earth …. Property prices rising at the fastest rate since 1860. etc etc etc
  22. One light? I didn’t see anything mentioning halogen floodlights. I figure LED feature lamps so maybe 10 fittings @ 10w each. Less than 1 amp even with some voltage drop.
  23. Interesting points and I fully understand where you are coming from. many of our tree surgeon customers are still getting payments to burn wood, to dry wood, to burn ?. im sure they are supposed to use the heat produced to heat homes etc but several have bio mass “boilers” satin containers in the middle of fields just burning wood waste and getting paid for it.
  24. Logs are not fossil fuels … bio-mass so it’s considered green
