markc
    22
Everything posted by markc
  1. +1 to this as long as the stainless is low grade, do not put zinc near any stainless in 400 grade or above
  2. Damn, Peter bet me to it again
  3. Close the outlet side to almost shut, I've just had similar problem with a couple of rads, bled perfectly but water takes the easiest path and with outlet too wide open the hot water seems to just flow across the bottom
  4. Yes, 5x2 on edge are string enough and if you add some extra pieces at bottom of post to make it 6x5 full depth and maybe upto 6in out of the ground there will be any of ground bearing area to resist the post from being pushed over. Ram the earth back in with a heavy post or big hammer
  5. No need for cement. Nice deep holes, preservative on the timbers and compact the earth back around them.
  6. They may as well have blamed brexit
  7. Brilliant screw for secret fixing through tongues of boards but these do pull through chipboard quite easily. Ordinary heads work much better on flooring and pull down tighter
  8. Firstly, the contract and quote wording will be very important here. workmanship (is that sexist now?) is pretty poor but did you want too much for the money available and contractor agreed to lower the price? … not right in my book but it does happen too often. the crack does concern me as it runs through bricks, the rest looks cosmetic and can be made to look much better quite easily.
  9. Odd detail so yes it could be supporting the ceiling as well. Nothing wrong with it being two pieces, they probably needed to pack out a bit. I quite like the look and design of the staircase, maybe too much dark wood. post caps are easy to replace with something closer to post size and maybe raised centre like a fence post cap. bit of tidying, rubbing down, bit of filler and maybe some white to break up the brown and it could look fantastic
  10. @Oxbow16 if it is 1-1/2 bsp then this makes it much easier and I would leave it in place. Might be worth getting a couple of fittings and with a bit of fettling get a connection to work.
  11. +1 on this, Octopus were brilliant when I wanted 3 for my workshop
  12. A lot easier to remove the old one and replace.
  13. If it’s for wrapping around split insulation in bands then I always use ordinary electrical insulating tape, also makes really good plasters for holding bits of fingers and thumbs together
  14. Tongue and groove - the joints in the edges of the boards
  15. +1 on the above
  16. You are right, butyl is very tough. As Joe says, good fill with glue and you have a waterproof joint anyway. Also Tape is an easy way to cover screw holes if the person screwing down gets over zealous and leaves holes above the heads.
  17. Any butyl tape should work well, just needs floor to be dust free as you lay the tape
  18. If you have a crusher then use the material as temporary hard standing and access etc. if you have to hire a crusher then the cost of that plus all the material sorting will probably cost more than flattening and getting it taken away.
  19. Offer to pay the credit card charge and they may accept the payment, assuming they have credit card facilities.
  20. I recently left some off it’s outside just out of curiosity, the pieces stood vertically with groove uppermost have suffered the most but the horizontal ones laid on a cobbled area are dirty but pretty much unaffected by all the rain. just thinking about this more, a full continuous bead of glue on top of the tongue would prevent water getting in and not gluing under the tongue would ease water getting out.
  21. Nothing wrong with screwing down just don’t bury the screw heads as this leaves holes to fill and allow water into the core. Any holes or deep screws should ideally be filled if you are wanting resist standing water .. (slope would be better but not great for floors ) ?
  22. Plans are open to interpretation, if you want to compare then a Bill of Quantities is required to enable all to quote based on the same amount of any item. also make a detailed explanation of what you are wanting them to quote on, level of finish, when the job will take place, where the site is, site conditions etc. even then you will get a wide range of prices back
  23. No two quotes will ever be the same unless it is for the supply of an item only. every site, access, timeframe, client, finish required etc etc are different. the secret is to being specific with your requirements and questions
