markc
    22
Everything posted by markc
  1. Is that a throne?
  2. Difficult to be specific but the top pic looks much older than 70’s bottom pic def appears from that era.
  3. 12t machine I bought last Xmas with a leaking drive hub, luckily bought it as a toy. Replacement drive hub £2200 but 11 months wait time so it might be running early next year. But worth keeping an eye on EBay earlier this year picked up a Sany 1.6t machine, full cab, 2017 and only 650hrs on it, as new condition with full paperwork for £12500 plus vat…. And it’s a great machine
  4. Pedestals can be on a slab, placed on pads or even cast as pad and post. a raised pedestrian area is 5KN/m2 so very low ground loadings. curing time, allow a week to be on the safe side.
  5. Yes! Laminating greatly increases the structural strength, torsionally stiffer, bending greatly reduced and splits/shakes are limited to lamination sizes.
  6. Well done, yes trim the edge insulation but never hurts to keep a DPM upstand, it can go up behind plasterboard, plaster and skirts etc. stops any spilled water going where it’s not wanted and adds adds air tightness around the perimeter/through stud walls etc.
  7. We have 150mm concrete in our workshops and regularly put down 20tonne+ point loads
  8. Oh yes! Whenever I see them on EBay I always send a message saying yes I will take it … same message comes back that it is presently in Edinburgh but they will bring it to me after I pay. On one I said I was in Edinburgh at the moment so happy to collect and pay cash …. No response.
  9. Hi and welcome
  10. Looks like tile on top of bitumen, probably shrunk back from the wall over time. Filling with foam or flexible sealer will be ok. Grippers really should have been glued or drilled and screwed on that floor.
  11. As above! If this isn’t an outside wall then extra caution is needed
  12. Looks and sounds like damp walls and could well be a chimney leak. If the skirts are wet then you might as well pull it off especially if plaster has detached. As the patch looks quite even I would guess at water falling down a cavity and splashing rather than seepage through the wall. What’s on the other side?
  13. I think you are right, pull it out and insulate properly if you don’t need it.
  14. Yes, the compound is always going to break up on a flexible floor. The T&G is the ideal surface. Might need to go back around and adjust the screws to get it level but levelling compound isn’t the answer. the plywood could be kept but you still need to level what’s under it
  15. So you have some thin levelling compound over 4mil ply over a floating floor over PIR? It’s going to flex and destroy the compound. can you ditch the compound and ply?
  16. They have to make the wind somehow
  17. The thermometers are useful but no substitute for thermal imaging
  18. Very few good machines at the right price at the moment. Shortage anyway and weak £ meaning loads of plant being snapped up and going abroad. if buying ‘cheap’ be aware of potential repair costs, track motors and drives are like rocking horse Pooh and a slew block will cost a fortune.
  19. markc
    Bedrock
    Answers really depend on the type of rock and what size machine you are using.
  20. Try Glassandstainless Not had any balustrade from them (yet) but def my go to place for toughened glass
  21. Mini hi-tip dumper? But a couple of cube or less isn’t bad in barrows and shovelling into the walls
  22. markc
    Hi!
    Hello and welcome, I’m sure your input will be appreciated
  23. Yes, as you use the space and vacuum etc. you will see the carpet taper down towards the LVT anyway. When first laid you will notice the height difference but that will soon change. if you want it less noticeable, get the carpet fitter to taper the underlay or leave it slightly short of the LVT to taper the carpet level
  24. Better to have carpet higher than any solid floor to prevent a trip hazard as you leave the carpet. Think how far a carpet compresses while standing on it.
