Everything posted by markc
M10 is 8.5mm tapping drill. If you don’t already have a hole in the stud then spot the centre (needs to be very close) then drill something like 5mm then open up. Problem with cast iron is that it machines and drills very easily and drill bit will want to break out of the side of the stud and go through the iron instead. Chucks do not need the grooves so unless you are drilling accurate holes then a bit of wobble isn’t an issue for most jobs.
Downdraft extractor fan socket, plug & cable
markc replied to WWilts's topic in Electrics - Kitchen & Bathroom
Remove the panel it’s fitted to and do away with it or put it inside the opening instead of outside. Watch out for bare terminals behind that could touch the metalwork -
I doubt you will need PP but if it’s not done right it will not last long. If water can get under the tarmac it will soon break up and come away in sheets/chunks
It can (and does) happen where damp is ‘sucked’ inwards by the dots and dabs, but why is the wall cold and damp? Is it a new build that hasn’t dried out or an old existing cold wall? As long as the wall is now dry, throwing plenty of heat into the build will sort it out but if there is a source of damp in the wall then it will continue and spread
There is the APF - Assos. Of Prof Foresters
Wall should be fine, plaster shouldn’t go right to floor, neither should plasterboard if it’s a stud wall.
Looks great, had to look twice at the toilet roll holder on bottom pic … thought it was an odd placed door handle or flush
If skirts are MDF then rip them out, pine or hardwood and they will be ok. if water is coming up through grout then there must be voids under the tiles and it will cause problems with the floor or just start to smell or start mould growing on the grout lines
Multi tool, use edge of the blade and plane away the high spots - this way you don’t get fine sanding dust and much better than chipping away any humps.
Is it the whole house that feels cold or just downstairs? Reason I ask is that a couple of years ago my soon to be mother in law constantly complained her house was freezing and it was the kitchen floor sucking heat away, the house was actually ok but you felt cold because your feet were cold. Dug floor up, insulated and relayed and the house has been completely different since. if the loft is well insulated chucking that much heat in should have the upstairs fairly hot. my house has no cavity, I like 18 degrees when I’m home but I don’t use much gas at all, but I don’t work from home.
I couldn’t sort mine through the hole and neither could plumber so I ended up pulling the top off
Access from behind, or if not possible then a boxed out area to mount on with a removable lid.
Yes, double sides sticky foam pads work well too, had a similar problem with a mirror that rattled when the door was opened or closed, resilient material dampens the sound and being sticky stopped the mirror moving.
203x203x46 UC is a substantial column with a massive load bearing capacity, they must be there for something other than supporting a garage door. assuming this is a really good, heavily insulated garage door, it is likely to weigh around 300kgs which is nothing compared to the structure and occupancy. so my feeling is your builder is talking rubbish and omitting two large UC columns is going to affect much more than just being able to have a garage door.
Think of a number, double it and add a bit more. many years ago building costs were roughly 1/3 plot, 1/3 build costs and 1/3 profit or saving, now the plot can cost way more than 1/2 the finished value
Agree with the above, having set and tested literally thousands of chem anchors (plus had hundreds checked and signed off by Hilti) I’ve learned a lot. embedment is very important, hole cleaning and effective mixing are musts. I always spin the rods in backwards (drill running anti-clockwise) so the threads are pushing and mixing rather than pulling the resin out - this is especially important with glass tube systems because the tube forms part of the anchor - I have seen ground workers breaking the tubes and pouring the contents into holes 🙈. but chem anchors are convenient and when set correctly (in a sound and suitable concrete/stone/block etc) are only surpassed by cast in caged Holding down bolts
This sounds like a blocked chimney, not necessarily an install problem. Birds nest in the cowl? Very possible if it hasn’t been lit for 6 months
Guttering overpassing our boundary line
markc replied to gutterman's topic in Party Wall & Property Legal Issues
You can stick to your guns and force some changes to made, or a gutter oversailing isn’t the biggest problem in the world and you could point out it’s not right, but you can live with it. -
Yes you could get heave, but you WILL have a tree falling sooner or later.
Electric arc furnaces have water cooled cables … very strange to be bolting a massive connection (12 x m16 bolts) and then coupling the water pipes up that flow water down the centre and around the conductor to keep it all cool.
+1 tried tested and approved sump systems are not that expensive
Last week, labour only to membrane, batten and tile a bungalow. Lowest quote £4200, highest £27,500 🤪 now some variance is to be expected but this is ridiculous
help please, LR & seller conveyancer issue
markc replied to DocK's topic in Party Wall & Property Legal Issues
Why would it be the solicitors fault, I’ve never seen a solicitor come out to check fence positions during a sale
