markc
    22
Everything posted by markc
  1. Hi and welcome
  2. Not really, if you were framing it all with 3x2 then it would be incredibly flimsy and fragile, but a decent framed wall with tight joints is surprisingly stiff and once you have some plan bracing in they will stand up to knocks are high winds
  3. 8m walls are no problem with staggered joints on top and Sill plates. Temporary prop if it’s really windy until you get a central truss or joist in to brace against.
  4. Difficult to say without length of run, trial pit and site specific but I would work on £1k-£2K /m with a minimum £6k to cover enabling works. (Haven’t done any commercially, only F&F in last 6 or so years).
  5. True, thing is, if you can’t get to each cell then you have little chance of recovering a pack
  6. Tantalised timber 😊
  7. This is what we use to bring cells back up.
  8. Sarnafil is easy and pretty indestructible
  9. Council house a few hundred yards from my mum, family always complaining house was damp and windows misted up. … they had laid turf in a bedroom for the dogs! I dread to imagine what the house smelled like
  10. Corbelled brick and stone (no strip concrete underneath) are the worst and have to be done in short sections, less than 1m to cast a strip footing to support the individual bricks/stones and then excavate again under those if extra depth is needed. With deeper existing strip footings, 2m sections are possible with props for peace of mind. cast the new section approx 10mm low and then hand pack with firm expanding grout to prevent settlement.
  11. As above, and if not damaged they can be brought back up slowly with a variable power supply. Our customers often ‘forget’ to charge their machines for extended periods and we can usually recover the Cells over a few days getting the voltage up to where the charger will recognise the cell and kick in.
  12. Find a local saw mill, they are your best bet
  13. Yes, not the nicest job, mini digger with bucket on backwards helps
  14. I don’t have a display
  15. Very nice
  16. Don’t all smart meters connect through the property Wi-Fi ? my octopus meter does … well occasionally but I don’t monitor it anyway
  17. I’ve seen injection done under large slabs to re level and it worked well (drive and pathway). But it is still under pinning but without the tried and tested methods of excavate and replace with known quantities of concrete and bearing dimensions etc. I’ve been involved on some big stabilisation projects but I would not use this under walls etc as the bearing surface etc. is unknown. Yes it might work, but for how long?
  18. Without digging (no pun intended) for information on the product/process, am I right in thinking this is a soil stabilisation process by injecting a “substance” that then solidifies? If so then I would be very sceptical for future insurance or mortgage purposes as it is effectively underpinning.
  19. Yes lay the slab in the extension first, tell the ground worker the plan so shear connectors can be included in the slab ready for next pour. When it comes to the screed do all the lot in one go.
  20. I don’t think the water is getting in because of the gap, rain would need to be blown horizontal and pretty constantly to cause any trouble. The sill doesn’t appear to have a drip catcher and (might be distorted image) sloping down towards the building so water is pulled in rather than being blown in. the black is the old sill and any water landing on that should run outwards and down the wall. I really think there is more going on here than just an un filled gap.
  21. I assume that the stairs did not fail in this instance. no they didn’t
  22. How old is the property? What windows were in previously? Even with a gap under, water should drip off the sill and not run underneath, or certainly not enough to cause damp walls
  23. Not a nice job to do, material cost about £2K pre covid and 2 of us for 4 days doing the work. This weekend done a similar cellar dig out for another relative (I really must say no to freebies for family)
  24. Replacement floors make a massive difference. My mother in laws kitchen was cold damp and pretty miserable. Dug out, insulation and replaced and it’s now completely different.
