Everything posted by markc
Interesting, I have no idea why but it does only occur with softer nylons, cast nylon6 and 66 are not too bad and Delron seems pretty unaffected but these are all engineering materials. The softer general purpose nylon bar and sheet seem to absorb the WD and surface 0.5mm or so swell .
1930s roof - how soon will I need to replace?
markc replied to Question's topic in Roofing, Tiling & Slating
Morning, there are many buildings out there with roofs 100’s of years old so it’s difficult to put a timeline on things. When you look at what a roof has to endure you start to appreciate why some fail sooner than others. wind, rain, snow, orientation, pitch, airborne salt, sand etc. moss … if moss gets hold around slates they soon start to crumble. any photos so we can give you an idea of condition? -
So true, similarly nylon swells with WD40 causes us loads of problems with sliding collars on air and hydraulic cylinders and interlocks when people blather them in WD40
A cheap laser thermometer would give you loads of info and pinpoint where the cold spots are. Get one, draw a sketch of the house and go around noting the temps (try to do them all within a short time) and post them on here. @j_s bet me to it
Kiln dried Firewood - how much do you pay?
markc replied to Adsibob's topic in Stoves, Fires & Fireplaces
That sounds about right, asked a few of our tree surgeon customers and they are wanting around £135 per cube. -
Dry sanding with dust collection is your best bet, if you wet sand plaster it will run down the wall and set again. You can hire dustless sanding machines also called drywall sanders.
No way! I can understand them wanting the sum that would have been paid when on site and a disruption fee if install team were delayed at last minute but a storage fee is taking the p1%#.
As Peter said, has to be PVA primer. You will always be able to chip it off if you try but lifting in sheets is a big no-no, over time it would crumble and bits would find their way into voids as the floor lifted resulting in high spots and a horrible crunching noise when walked on. Take up anything that’s loose or sounds hollow if talking it all up is proving difficult
If the slab was very cold I could see the SLC crazing but would (should) still stick. did they lay it over a dusty slab? I reckon the flood has done you a favour as this would rear its head in the near future anyway. as above, rip it up and start again
Just need a Tricorder .. (Trekkies know what I mean) .. couple of buttons and a few flashing leds but somehow it displays anything in great detail.
Temperature swings in a garage or shed along with prolonged periods of closed doors makes condensation inevitably. I keep two oil filled heaters on thermostats in my garage to protect my lathe, milling machine and big table saw.
Yes I’ve had this one, at least you have an open slot to get through and should be able to wiggle the bolt back enough to get door open (failing that angle grinder). I had to drill out an anti snap euro cylinder to get a door open and it was a pig of a job.
That’s madness, digger for a few hours and dig a couple/three holes. These can double up as percolation test holes if organised and located properly.
As above, plus I’m a bit confused regarding your dilemma, are you thinking the lines/corners may not be straight or square? If so this needs sorting now. If it’s your perception of the position “in space” then it may well be all in your head. Buildings never look right when the founds are dug … ohh it’s small, thought it would be bigger, feels odd etc. etc. this changes completely when walls are up.
Haven’t seen anything specifically like that but I mounted similarly using a big adjustable mount that had two folding arms to allow it to pull out and turn either way, if both arms unfolded then it would reach the side. Bear in mind the fixings and cantilever load mounting from one side. These loads on the fixing will be many times that of centrally mounting.
Incredibly difficult hole to seal
markc replied to j_s's topic in General Self Build & DIY Discussion
Not an overheating risk through a few inches of foam, burying long runs of cables in insulation prevents heat dissipation but copper being a very good conductor of heat you won’t have any issues as any heat will soon be lost either side of a foam plugged hole -
+1 on the foam, might (won’t) look pretty but will work -
Impossible to determine unless you know the stair design (depth and angle of stringer) and floor levels. If you have the stair design or drawing then it’s easy to mock up on site
No problem using for cabling except that access is difficult and you will be extending runs considerably to get into the chimney. Running heating pipes is also not a good idea as any heat lost would be better keeping the rooms warm, not an old chimney
That reminds me of a job we were doing in Milton Keynes, first day crane on site the local HSE guy came to tell us he passed this site twice a day. Needless to say everyone told to be squeaky clean. One day he came onto site and the bell was ringing on the crane (kato truck cranes all did this whenever boom was below 30 degrees) but instead of telling the guy this, crane driver said “please don’t phone my gaffer” and why is that? Because he’s always told me to turn the bell off if I’m doing anything dodgy! 🙈 let’s just say we didn’t get much done over the next few days
+1 a cheap generator will be noisy and likely to play havoc with any tech you have in your home. a decent silenced stable output gen is definitely £5K+ and add another £1k for the lpg version.
@Radian bet me too it, just finished reading and the first thought was strip and redo the entire roof in one go. Removes loads of work and potential grief.
Insulating a cold floor makes a massive difference, my mother in law’s house was cold and the kitchen was horrendous, always felt damp and musty. Drilled a couple of test holes in the floor and found concrete on top of clay and ash. She wanted a new kitchen so timing was great, dug out, added DPM and 100mm insulation with a 100mm concrete top (corbelled foundation prevented going deeper). Topped off with a slate floor and the kitchen is now the main room for anyone, no changes to heating or anything, just made a massive difference
You will find one to fit, have had a few recently that were measured (and stated) assistance to back of face plate when it’s generally face of face plate (flush with door edge)
You will be fine, concrete generates heat as it is curing. Really low temps that can or would cause flash freezing at the surface would be an issue but in Uk no problem
- 1 reply
