Chimney breast removed and joist floor needs to be added.
Gone West replied to moe's topic in General Structural Issues
I'm looking to do the same, but as a chimney breast is often structural, providing bracing to the wall, I will get a structural engineer to check it out first. -
I just disconnect the hose from the tap and most of the water runs out. By the time it's cold enough to freeze I doubt there's much water left in the pipe to cause a problem.
The bungalow we had to dismantle had all the internal walls and ceilings lined with Chrysotile asbestos sheets. The roof was also covered with asbestos tiles. I took a sample and had it tested. I got several quotes to have the internal sheets removed and disposed of, which varied between £4000 and £13000. I ensured that the cheapest quote provided all the necessary paperwork. While the internal sheets were being removed I was kitted up on the roof removing all the tiles and bagging them up for the workers to dispose of. So it cost me £4000 plus the cost of the testing kit. To get a sample from a roof I would wear a mask and I would damp down the area thoroughly and break off a small piece and send it for testing. If removing the whole roof I would wear the full required PPE. There may be a local company who would take the bagged up and sealed sheets. https://www.amazon.co.uk/Asbestos-Sample-Only-Test-Testing/dp/B095PCZJ4X/
Why wouldn't you. We had several triple glazed units replaced after our windows were fitted, due to marks inside the units which were unacceptable.
Short answer is no. The difference is far too obvious.
I used all Floplast in my last build because I wanted to be sure every fitting fitted together. Floplast do a good range, but no good if you've already started. https://www.screwfix.com/p/floplast-solvent-weld-bend-135-white-50mm/29473
What am I doing wrong? Trades going AWOL
Gone West replied to SimonD's topic in General Self Build & DIY Discussion
I did all the circuit design, first and second fix myself. The BCO told me they didn't do electrical certification so I sorted beforehand for my son in law's friend to carry out the required checks after each stage and issue the Part P Certificate. -
It could be a Weeping Hemlock. They look like council kerbs. Not the prettiest edging and they weigh a lot. I would go for it, just ram down 200mm small rubble or type1 for a base and brick on top. Lay it all out dry first to see what it looks like. Good luck.
If the quoted 250% increase in efficiency of light conversion proves to be correct then perovskite panels would be significantly better than silicon. I can't see it happening in the near future though.
MVHR design help / feedback
Gone West replied to Ola's topic in Mechanical Ventilation with Heat Recovery (MVHR)
IIRC in the PHPP the default temperature is 20C throughout the house. We actually ran our PH with a temperature of 23C. I think, unless it's a typo, that you will need active cooling for a lot of the year, in order to keep part of the house at 10-12C unless you live a long way north.- 18 replies
- extract / ssupply points placement
- cascade effect
It would be interesting if there was historical data going back over the last 50 years. IIRC many years ago the lower Thames was so polluted there was no wildlife in it and then years later they were saying salmon were seen in the Thames.
Slaying the demon chimney stack
Gone West replied to Nick Thomas's topic in General Self Build & DIY Discussion
+1 -
We have a hose pipe ban and can only use drippers. We bought two master units which have a filter and pressure reducer in them. We have two areas and one has around 100m of 13mm pipe which feeds two rows of new hedging, and a few newly planted shrubs with the 2 litre per hour drippers screwed directly into the 13mm pipe. The other area uses around 15m of 13mm pipe with 4.6mm pipe 'T'eed off to sixteen pots using a mixture of adjustable and 2l/h drippers.
I've just installed two Gardena irrigation circuits in our garden. That was something I never thought I would have to do in Cornwall. https://www.worldofwatering.co.uk/
I would have thought the flints would whack down better with chalk in the mix as it will fill in the gaps like having fines with type1.
I may have misunderstood, but you seem to be saying you should only use a raft if it is required by the ground conditions. I chose an insulated raft because it was the best fit for my design of PH. Whether it was over-engineered for my ground conditions I do not know, as I am not a SE.
We built an Isoquick insulated raft thirteen years ago when we started building our PH. The SE was employed by the company installing the raft and didn't attend site. With my lack of experience I thought the raft was massively over engineered but I knew very little about insulated raft foundations.
We had an insulated raft foundation and the SE only wanted a soil plasticity test from the centre of the slab area. He told me what was required, I dug a hole, put a soil sample in a plastic bag and took it to the laboratory. £50 for the results, it was thirteen years ago though.
For our next gabion wall I've decided to make the baskets myself. I have the crimping tool and clips, I've seen how they're put together, so I'll just buy the appropriate mesh sheets.
When I had my 9m x 3.5m concrete slab laid last year I had it floated with a bull float and it had a good finish.
We didn't use a decoupling membrane and didn't have any cracks in the concrete. We used BAL flexible adhesive and the tiles were 750x450mm. I had a Vitrex wet diamond bridge saw which I also used for the roofing tiles and patio tiles.
The government gave the BoE independence over monetary policy in 1997 setting a target inflation rate of 2%. This was to stop years of governments using interest rates to suit their needs. I don't think we should return to the old ways.
Councils banned from charging for....
Gone West replied to Gone West's topic in General Self Build & DIY Discussion
I finished the build in 2018 and was able to use the local tips (East Kent) before they introduced the charge. I reused and gave away most of the waste so never had to use a skip.
