Vaulted hallway
Gone West replied to eandg's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Sorry I was looking at the first BPC description where you have "Upper floor extracts: 2x bathroom, 1x in each bedroom" which was changed to supply in bedrooms in the second BPC description. -
Vaulted hallway
I don't see how. I have looked at the details on your other thread and both of the BPC configurations look odd to me. I've not seen extracts from bedrooms recommended before. The Paul design looks more conventional. The basic factors are to extract from 'damp' rooms and supply living areas, with the extract and supply being balanced. In a two storey house the hall and landing aren't usually classed as living areas but there is no reason why a supply can't be fitted either to balance the system or because the hall is large and used as a living area, as in my last house. -
Vaulted hallway
I designed and installed the MVHR system in my last house and I had an outlet in the hall which helped with balancing the system. It's not a problem. Here is the calculation for the house. -
Cement mixer hire or buy?
Gone West replied to CalvinHobbes's topic in General Self Build & DIY Discussion
+1 Exactly what we did with our Belle Minimix. -
New build designs........ Comments please
Gone West replied to GK22's topic in New House & Self Build Design
IMHO overall it's a nice design. I like the entry view. The SE view has too much glazing and the NW view has too much render. Breaking up the render with timber cladding as in the entry view would help. -
Foam Gun Cleaner - am I doing something dumb??
Gone West replied to jayc89's topic in General Self Build & DIY Discussion
I've had one of those, seemed much the same as others I've had. -
Raised bed from 2.4m 'sleepers'
Gone West replied to Radian's topic in Landscaping, Decking & Patios
Originally I was going to use dung boards, because they come in 4.8m and 6.1m lengths, and have several short posts along the lengths to stop flex. Wendy didn't think they were chunky enough so the plans changed to sleepers. The idea was for two 3m long raised beds seperated by a 1m walkway covered by a long arch, so forming a cross shape. The problem is long chunky bits of oak are a lot more expensive than dung boards. -
Not yet, but was going to later this year. I was going to use the 100mm thick sleepers and if they did flex tie them together on the inside with a short post half way along. Keep us updated I'll watch with interest. -
Replicating window cills in-situ
Gone West replied to jayc89's topic in Bricklaying, Blockwork & Mortar
I cast replacement window sills at my old Victorian cottage in the nineties. I did much the same as you except I put lengths of rebar longways in the mould to strengthen the extended ends. -
Welcome to the forum, we're eight or nine miles north of you.
If the trees would be in the way of your build and are not covered by a TPO then I would remove them before applying for planning permission. I don't know of anywhere other than on the LA list.
We can't trust energy companies
Gone West replied to Radian's topic in General Self Build & DIY Discussion
Do they insist on having a smart meter. -
OVO have certainly slipped down my ratings. Like @ProDave my FiTs were changed from SSE to OVO and they told me my electricity supply would be changed to OVO as well. So last December I tried to change my FiTs from OVO to Good Energy. Good Energy told me they couldn't switch me because my generation meter hadn't been checked recently so I asked OVO to inspect the meter. It wasn't sorted out until last week and I had to email the OVO CEO Complaints Department to get a resolution. I also got an apology, a nice hamper of goodies and a cheque for £50 but I'm still moving my FiTs and my electricity supplier when I can find a decent one. -
IIRC the tape I used was 20mm wide. To ensure the seal is watertight, the gap to be filled, should be within the expansion range of the tape.
Compriband is UV stable which may be or not important in some applications. I have used an alternative which worked for me with sealing windows but I don't know if it was the only sealing layer it would work very long term. https://www.affixit.co.uk/expanding-foam-tape-compriband-alternative.html
Larch or Brick? - a Cladding Dilemma
Gone West replied to deancatherine09's topic in New House & Self Build Design
+1 -
MVHR is Largely Bogus
Gone West replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We now live in an old solid stone walled bungalow which we are going to improve, after having lived in a Passivhaus which we designed and built ourselves. Having had MVHR in the PH we don't want trickle vents here, but we are going to need some form of ventilation. My thoughts, for our less than airtight house, is to fit a PIV unit in the cold ventilated loft with the output connected to a manifold which would supply air to the living quarters. We would have outlet vents in the kitchen and bathrooms to evacuate stale air. We would fit a heater to the manifold to ensure that the supply air was the same temperature as inside the house. This would obviously use more energy than a MVHR system but would be offset, to a degree, by the temperature increase in the loft during Spring and Autumn. The MVHR system we had in the PH had a small ASHP built into it which warmed the supply air so there was no, colder than room temperature air, going into the house as there is with a conventional MVHR system. We are also deciding on whether to use A2A ASHP heating or an oil fired wet heating system. This will also impact on how we design the ventilation system. -
Does it have to be though? Why not fit the PIV output into a manifold and duct to required rooms. -
Why is that? Can't you use an in ceiling unit?
We've just had the first service carried out on our hybrid and chatting to the salesman we were told they now need a company directors approval to take an EV in part exchange.
This is dredging up memories from the distant past. When I replaced all the windows in that house I painted all the new frames and beads separately with three coats of Sovereign SX70 before glazing them. We drove past that house last year and the same windows were still fitted. I don't know whether any of the DG units had blown but they were 4/6/4 air filled so not that good insulation.
I glazed all the DG timber windows in my house in the nineties with hard spacers, Butyl 66 compound and timber beads. None of them failed in the fourteen years we were there.
I've not seen DG units fitted with putty and I thought the oils in the putty reacted with the seal around the edge of the DG unit.
Back in the nineties I fitted 4/6/4 DG to wooden windows.
