Good books on self build project management?
Gone West replied to Rachieble's topic in General Self Build & DIY Discussion
I've got half a dozen books from when I designed and built my own house. I don't use them any longer, so if some or all are of any use to you I can send them to you. If you donate a tenner to BuildHub that would cover P&P. The titles are:- Building Your Own Home by David Snell The Green Building Bible 4th Edition Volumes 1 & 2 by Keith Hall The Green Self Build Book by Jon Broome The Energy Efficient Home by Patrick Waterfield The New Autonomous House by Brenda & Robert Vale -
Best filler for floor joist holes
Gone West replied to DKenn's topic in General Self Build & DIY Discussion
Why not glue in a looser fitting smaller dowel with epoxy wood filler. You'll use a lot of filler otherwise. -
I would use 25mm dowel, glued in with PU adhesive. -
Yes, we didn't use any tapes or membranes, just the exterior racking OSB3 and internal plasterboard.
Another 'Cool Energy' heatpumps thread
Gone West replied to HughF's topic in Air Source Heat Pumps (ASHP)
https://cdn.shopify.com/s/files/1/2612/5402/files/Cool_Energy_CE-iH6_Pro_Inverter_Air_Source_Heat_Pump_Datasheet.pdf?v=1721657221 -
What prep on subfloor for glue down LVT?
Gone West replied to YorkieSelfBuild's topic in Wood & Laminate Flooring
We had glue down LVT laid in our bathrooms. I fitted 10mm ply to the 22mm subfloor, filled all the screw holes, sanded then sanded and sanded again. When the chap turned up he looked at it and said I'll just prep the floor. By the time he was finished it was as smooth as a mirror. Our tiles were 2.5mm thick Amtico and the installer said that any tiny imperfection on the floor will show through the tiles. He did an amazing job. -
It's not usually acceptable to use different foundation types on a house and an extension due to potential differential movement. There is an old thread about ground screws and a couple of links to Grand Designs that used ground screws. https://padstudio.co.uk/project/chestnut-farm-modern-sustainable-farmhouse/ https://www.arborarchitects.co.uk/projects/redbrook
You could use an endoscope. https://www.amazon.co.uk/SDYGDB-Endoscope-Borescope-Inspection-Waterproof/dp/B0B9T5MQ18?th=1
The Warmcel was slumping and as a result there were cold areas around the ceilings. All down to the installers I guess. What I liked about the Supafil Frame was that, at the time, they used a transparent membrane so it was possible to see how well filled it was.
Eleven years ago when I was considering what insulation to use, Supafil Frame was on my shortlist. I discounted Warmcel as a friend had used it in her house and had problems. In the end I used 350mm Icynene for the walls and roof of my timber I-beam portal frame. The only problem was trimming and cleaning up. I did use a similar product to Supafil Frame in the walls of the old bungalow I was living in, while building the house. When I dismantled the bungalow it was easy to see how well it had filled the old timber frame.
Perhaps they're trying to hurry you along. AFAIK that's not correct, with the Government increasing BUS funding to £295 million for 2025/26. https://energysavingtrust.org.uk/grants-and-loans/boiler-upgrade-scheme/
According to Wendy , that's just man cleaning, not proper cleaning! I'm keeping well out of it.
@DREG Hi and welcome to the forum. If you post details of your situation on the ASHP sub forum somebody will be along to help you. Unfortunately I'm not that person.
Yes we've got those in our wetroom, although we didn't choose them. Wendy curses them because they are so difficult to keep clean.
@BuildPentir Yes I have, and am still researching. I do have some 70s additions which are easier to deal with. I think @Roger440 has similar problems and may also be in Wales. You are not alone!!
@Big Jimbo Glad to see you're back. We've sold up and moved West, and I've got a new moniker. Formerly known as PeterStarck.
I've never used Temu, but is this what you mean? https://www.temu.com/uk/1pc-aluminum-alloy-door-handle-with-keys-heavy-duty--lever-for-hotel-bedroom-bathroom-security--entry-door-knob-set-g-601099614670529.html
At our last house we had Indian sandstone which had a honed finish, so was smooth. It wasn't sealed and we found it was affected badly by salt, so if used on a path don't put salt on to get rid of frost.
I also glued our stud walls to concrete floor using PU gel adhesive.
Another garage upgrade with breezeway.
Gone West replied to Unforgiven's topic in Introduce Yourself
A covered or enclosed space between garage and house. -
So...I'm about to do Rainwater Harvesting
Gone West replied to mike2016's topic in Rainwater, Guttering & SuDS
My Victorian underground rainwater tank only had a two stage sand filter bed and the water was crystal clear in the tank. The pump drew the water from around 300mm off the bottom of the tank. -
If you bought the unit from Modern UPVC Windows it would cost around £80 for the unit and around £80 for delivery, so to DIY it, it would be around £160. So in effect you're only paying £140 to have it fitted, so to me it's reasonable.
