I looked at using adhesive for ours, but when I thought of the weight of a double sink full of water I decided to fix it mechanically.
We fitted a Schock sink which had a flat flange about 8mm thick IIRC.
In case you don't have any luck with adhesive we used G Clips for attaching our underhung sinks to our granite worktops. https://www.gclip.co.uk/Undermount_sink_installation.html
Vat claim and sign off
Gone West replied to nod's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
I asked Wendy and she said, form D is for where invoices have VAT shown separately and form E is for where the prices include VAT and therefore VAT is not shown separately. Wendy did all our VAT refund return, she's very organised, I'm not. This was done a few years ago now though, things might have changed. -
Bosch Dishwasher Water Connection
Gone West replied to 80's Owl's topic in Kitchen & Household Appliances
We've got a similar fitting on our Miele dishwasher and that screwed onto a 3/4" washing machine tap. -
I've got a similar problem, but only a small area fortunately. I am going to use Lime Green Ultra insulating lime render base coat which can be laid up to around 30mm IIRC. Then when more or less level I'm going to skim with a ready mixed lime finishing plaster. I'm not a plasterer and have never done well plastering but I'll give it a go. https://www.lime-green.co.uk/products/lime-plaster/ultra
I didn't oversail the cladding on the side reveals, only at the top. I used the same detailing for both horizontal and vertical cladding.
In 2009 I ran our design through the PHPP and the BCO accepted the results instead of an, as designed SAP. It took me months to collect and check all the data until I was happy. IIRC the weather data was problematical. Even though my day job was mathematical modelling.
Avoiding steel wind frame with portal I-joist frame
Gone West replied to thaldine's topic in Timber Frame
Yes, we built our house in a similar way but we didn't use a ridge beam. Our house was built in 2010 and was the second construction of that type that the TF company built. The first was an art gallery which was much larger than our house. https://lowenergybuildings.org.uk/search.php?s=greendale https://lowenergybuildings.org.uk/projectPDF.php?id=255 -
Air-to-air ASHP replacing warm air heating
Gone West replied to Gooman's topic in Air Source Heat Pumps (ASHP)
We had a Genvex Combi 185 at our last house which incorporated an EASHP to heat the DHW and the ventilation air, if required. It only works in an extremely well insulated house. We heated our house to 23C with just three electric towel rails and the Genvex. https://www.genvex.com/en/products/air-ventilation---water-heat-pump/combi-185-bp-and-combi-flex -
Back in the seventies I was told a similar thing by a chemist at work. Don't wash your hands with Swarfega, use washing up liquid and cold water so the skin pores don't open. He said Swarfega was carcinogenic in those days.
How to waterproof a brick built manhole
Gone West replied to jfb's topic in General Self Build & DIY Discussion
Back in 2010 I had a problem with a high water table and the sewage treatment plant at my last place. The hydrostatic pressure was forcing water around the inlet and outlet pipe seals. When the water table dropped in the summer I sealed around the inlet and outlet by packing bentonite around the pipes about 150mm thick. It seemed to do the trick. You could uncover where all the pipes enter the manhole and do the same. -
We also stayed in a PH B&B for a few days, back in 2009, as we wanted to experience a PH before we finally decided to build one. It is cetainly a good idea.
- 1 reply
We have an old cast iron lamp post, by our drive, which I renovated a couple of years ago. I used LED filament bulbs, which have survived pretty well considering where they are fitted. https://www.ultraleds.co.uk/tear-drop-st64-squirrel-cage-led-filament-lamp-b22-400lm-2200k-extra-warm-white-easydim
- 14 replies
- external light
- light bulb
(and 3 more)
We need a chemist: Portland cement and Lime.
Gone West replied to SteamyTea's topic in Research Resources
That's what I've read, and I do hope so. I'm going to try to lime plaster the window revels in a 600mm thick stone wall. If I get on alright with that, I'll try larger areas. I find it very tricky plastering with gypsum and get on better rendering with cement. -
Is he also an arborist 😉.
The roots of Leylandii will not draw water once the trees are cut down so that there is just a stump with no greenery. The reason roots draw water is feed the tree so once the surface of the stump is dry no more water will be taken up. If they were not Leylandii, but say Yew, then the tree stump would sprout new growth and the roots would continue to draw water.
If you cut them down they will die as they are Leylandii so will not sprout from the base. The problem is that it will take at least a couple of years for the soil water saturation levels to settle.
Fixings for MF to block and beam ceiling
Gone West replied to Thorfun's topic in Bricklaying, Blockwork & Mortar
Yup, if you were using self tapping screws into metal you would drill a hole first, unless you were using Tek screws when you wouldn't have to drill a hole. -
Last year I used concrete screws to fix some timber to a concrete block wall. They are very sensitive to the hole being exactly the right size. -
Some use OSB others such as Steico use structural fibreboard. STEICOjoist and STEICOwall are natural products. The production basis for all our joists is timber. Made from slow grown spruce, the flanges are kiln dried and machine stress graded thereby guaranteeing a consistant quality and defined mechanical properties. The webs are made from structural fibreboard, jointed along the length with a V-groove profile, offering a very high shear capacity. Both the preparation and manufacturing processes of the flanges, the webs and the installation of durable adhesives are carried out using the latest automated assembly lines.
