Russell griffiths
    65
  1. If you are going with a tiled floor on a wet room former, some of the wastes are multi directional, and also have a large lift out circle in the area the waste goes. They are all different according to make, but you basically rough in a waste pipe and then fit the former, lift out the large round bit and connect on the trap, then drop the big circle back into the former, tanking needs doing to top spec. Have a look at all the formers and trays they will have some fairly detailed instructions.
  2. A friend of mine paid 60,000 Australian dollars, they flew the cable in by helicopter.
  3. Ours neither, it’s warm mixed water, outside, you haven’t actually got a washroom for the dog inside surely 🤪🤪
  4. Er, it’s outside stoopid
  5. If you have any particularly large windows get some different brackets, the standard ones are a bit poo. You can buy a multi use fixing plate, it is about 100x150 with 40-50 holes in it gives far more choice of screw location.
  6. Find a man who does mini excavation, will probably have his own mini dumper that you drive. Expect £400 a day probably plus fuel now. Will shift twice as much as you will if you hire one.
  7. Why don’t you chuck a new pole up right smack on the boundary, uncap their cable and clip it to the new pole. Then rip the old one out.
  8. Go and talk to them. I personally have pussyfooted around a boundary issue with a neighbour because I didn’t want to rock the boat, a month ago I was in a raging mood and got on the digger and ripped all the old fence out back to the correct boundary, I waited a few days for the row to happen. Never did, neighbours came out and said “ we wondered when you were going to do that “ two years I’ve been hesitating. If you believe you are 100% in the right then go and have a chat and tell them you intend removing it.
  9. Erect ladder, unclip cable, cut down pole. Wait for the shit to hit the fan. Cost zero.
  10. My Graf plant runs 6 mins on and 4 mins off, or it could be the other way around. I was told this optimised electricity usage and stops the air holes blocking with crud if the blower is off for longer.
  11. Reading all this it looks like a project for icf blocks. Can be self built, no additional help needed. One concrete pour so reasonable pump costs. Render outside, no problem. Clad the inside in 18mm osb and paint.
  12. As above, Staffordshire blues, order them and move on to the next problem, anymore than two minutes thought on this is overthinking. Only one product suitable for down there. Obviously different manufactures might have colour variation.
  13. Depends what you are looking for but I like Flemish bond with a light creamy colour mortar.
  14. I think this fad at the moment of sleek roof lines and hidden gutters is asking for trouble in years to come. I lived in semi tropical Australia for a few years and they are very realistic rather than wanting some arty fatty design. Roofs have large overhangs, a lot for shade, but it also sheds the water away from the house, gutters do not cope with the tropical storms so they don’t have them, water flys of the roof and onto the floor. Water should be encouraged to leave the roof as fast as possible and get to the drain as fast as possible. There are plenty of posts on here about wanting to not have a certain down pipe in a location because it will spoil the lines of the house. Oh FFS get over yourself and get that water off the roof. When i originally designed my place ace it was going to have hidden gutters, I soon worked out it would be a good few grand more and would be a pig to build, so I scrapped the idea and had deep wide aluminium made up. Do I look at the house now and think it looks crap with the gutters, not at all the only person who is going to notice you haven’t got gutters are the ones you point it out to when you are blowing your own trumpet.
  15. If you have ever seen an internal downpipe block and then separate at a junction you would soon realise that it’s a stupid idea.
  16. You cannot plug curling tongs or a hairdryer into a pull cord.
  17. So how come you can put an electrical socket within easy reach of a kitchen sink. I think the regs need updating for bathrooms, with fast acting breakers is there really a risk? and abroad it is always a done thing to have a socket near the sink. This country needs to get a grip of reality, how many people would die per year if you had a light switch in your bathroom, probably zero.
  18. Buy yourself an eps surform sander thing, it’s like a cheeese grater with a handle. Make your openings 30mm bigger than the window or make your windows 30mm smaller 🤪 this will allow for 5-7mm of render on both sides, then adequate room for the nozzle of your illbruck foam gun. Use the sander to put a slight slope on your blocks in the cill area. Then render cill area and reveals and head. Two coats of a waterproof coating, then fit the windows. If you can bend and stretch the peel n stick membrane around the cill area with any sort of good result, I will nominate you for a noble peace prize.
  19. Couple of points, you drawing needs enlarging a bit so the details show a bit more. The extended cill needs an upstand so it tucks up and under the upvc cill. Have you considered a piece of slate as the extended cill, I think it would fit in with your location. Then the upvc cill needs to have a very minimal down turn so it sits almost on top of the slate. Regarding render, pick a manufacturer and stick to there recommendation regarding preparation. All my stuff came from the the EWI store. Sticks like the proverbial shit to a blanket.
  20. If you are retaining the concrete frame have you considered icf, I know there’s a couple of people on here that have done this incorporating the frame into the inner core of the icf.
  21. You will need to find the right diameter.
  22. Resilient bars and get the little metal hangers so you pull them up or down as needed.
  23. You don’t need 300mm if it’s an unheated space, and you don’t have ufh.
