Exact information. Im sitting in a pub with a bunch of builders. This isn’t a house I’m building, or an extension. Builders are saying they are currently using 75mm wool type batts in a 150mm cavity with no other insulation and this is fine. Im saying it’s shite and doesn’t come up to current regs. Who's right. Beer is at stake.
Nudura - Air Brick Placement...
Russell griffiths replied to Mulberry View's topic in General Self Build & DIY Discussion
Nobody else having a go so I will stick my oar in. I would put your periscope in but make up the opening part that takes the airbrick larger than needed. If you do some sums you can work out the difference between a full brick and halfbond. So your opening letter box will be a brick and a half long, then when you put the slips on you can get the position right and cut a blank plug of eps and glue it in and put your slips over the top. -
Having a discussion with a builder. Can anybody tell me what amount of insulation is needed in a cavity wall to meet current regs. I was under the impression it has changed a lot and you now need substantial cavity insulation plus insulted plasterboard. He is saying 75mm of cavity batts in a 150 cavity is good enough, I’m disagreeing. Can i I have it for a new build as well as an extension please. Sorry to be a pain, but I might have to buy him a beer if I’m wrong 🤦🏻♂️ Anybody point me at current levels. Cheers.
Small aluminium angle piece glue it down in front of the door if you get any grief from BC.
Corrugated Asbestos Roof Options
Russell griffiths replied to OldVirgin's topic in Garage & Cellar Conversions
Depends what you want to achieve. Drafty cold building, but you don’t care as you will be weightlifting in your thong. Or nice and toasty office that your wife works in. If you want the latter then you will need to completely design the whole thing, a bit of insulation stuffed under a draughty roof won’t cut it. -
You should have your toilet choice by now and give him a pdf of the installation instructions.
Gap between door frame & floor
Russell griffiths replied to newbie282's topic in Doors & Door Frames
If you want a moody bodge then fill it with a timber filler and paint it. If you want a nice job then remove the architrave and fit 3 new bits flat to the floor. -
Time for a joiner to fit door liner / door / architrave
Russell griffiths replied to Moonshine's topic in Doors & Door Frames
Looking at this the way you are and putting these tight times on things , I think you are in for a world of hurt and disappointment. Do you think there’s a big gang of chippies out there just waiting for you to call them and offer them 45mins to cut and fit your window boards. Unless you are very lucky I think they will come in and tell you exactly what it’s going to cost. Putting a time and cost on each item you will get a site chippy who wants to run in and smash it out as fast as he can, which won’t achieve the finish you want. Window boards will depend greatly on the finish that they are going onto, flat and level timberframe with the cavity all closed then lovely. Unlevel block work, or wonky icf, then what method do you want for fixing down or levelling. If you are tight on the time they will pack them up on old bits of crap they find laying about. If you have multiple cills in one room you will want them all level with each other. I have 5 windows all in the same room that need to all be the same height, I think it took a good day to get the laser shooting nicely across them all. Ive been on a job recently where we took out two sets of patio doors and reinstalled them because they where different heights to each other, both sets in the same room. Pay peanuts you will get monkeys. Im on another forum just for builders and the going rate for an internal door hanging and furniture is about £80 a door. -
Why don’t you build the rest of the extension and pour the floor when the roof is on.
If you put the dpm in and it rains you will have a big pond, dpm and insulation is only a half day job, do it the day before you pour.
Why on Earth are you using 160mm soil pipe.
Morning peeps. I have an attached garage that needs a fire door between the garage and the living areas, I would also want this door to be as airtight as possible. So do you think it is easier to get a fire door and frame and improve on the air tightness , or try to get a good airtight door that can meet the fire regs.
Poly Steel ICF a valid option?
Russell griffiths replied to Jenki's topic in Insulated Concrete Formwork (ICF)
Yep, starter bars in footing, then a course of blocks, then pour, then floor or walls. The only drama like that is needing a pump or some way to get concrete around site probably 3 times not twice. -
I built in icf, purely for the solid lump feel, and the dampness, I’m right next to a large lake and dismissed timberframe very quickly. But don’t do it to save money, I think what you might save in one hand you will spend in the other. I built with a poly type icf and did no external covering for two years, my shell was fully airtight and watertight as soon as the roof went on, so could be good for getting on inside if the weather is crap for outside work. If going icf on a slab pay attention to slab and wall junction, I have seen this be a pour area for water Ingres. If i was remote like you I would go, strip footing, icf walls and an insulated slab internally to form the floor -
@Jenki if your at £10,000 for blocks your not going to build it under £13,000, unless I didn’t understand your comment. Concrete pump bracing, timber, labour, will put you right back up with the timberframe price. -
It’s cheaper than the metal underlay, but not cheap and nasty, I used proctor #3 I think.
