Russell griffiths
    65
  1. A funny thing happened this week, I had a lad visit my site to collect some blocks I had left over, we got chatting and he said that he has had to Change block supplier half way through his build as the quality of the blocks he was getting was so poor. This must have been a massive decision to make, and not something that was easy to achieve as the two makes where not at all compatible. So go and look at some builds that use the blocks you want to build with. Talk to the lads doing the build and get their opinion. Dont go by the crap in the brochure.
  2. If your engineer is familiar with ICF then what has he worked with previously what ones has he had dramas with who is building this ? why not ask the builder what one he wants to use if you are not building it, then tbh your opinion doesn’t count for much, ask the guys screwing it all together what they want in a system. Having just put over 2000 screws in my icf I’m glad I didn’t have to screw into metal webs.
  3. Remove the mat on inspection day and fit some off cuts of the flooring in the hole, mounted on some ply to bring up to the correct level after the busy body bc have gone put your mat back. ??
  4. Now thinking completely from a dodgy perspective who knows anything about a commercial install. We have two holiday letts is there a fit for commercial instead of residential can i I install it to feed the holiday letts, but er don’t if you know what I mean. Nod nod wink wink.
  5. So let’s say no fit at all, every penny it costs me is coming out of my pocket by the time my house is finished I won’t be working anymore, and the wife is going to only go to the office once a week and spend the rest of the time working from home. So, I can run the dish washer during the day and the washing machine, computer will be on most of the time how do we calculate how much electricity we will use and how much we can generate i have an immense area of south facing roof with no overshadowing, so that would be my preferred location. Come on help this thicko out.
  6. Are you doing a full renovation and adding extra insulation everywhere. If not my opinion would be that putting that good a window on top of solid 9inch brickwork is a bit overkill.
  7. Where are you measuring your 6.5 m ridge from is it from finished floor down stairs or external ground level will make a big difference if from FFL then that looks loads to get an increase in room height with a low pitch roof. What am I missing.
  8. I don’t think any trades get the recognition they deserve, or the wages i would not recommend being self employed anymore to any young person.
  9. Evening all, need to start the ball rolling on how we run this house we are building so going to be a big load of questions, starting with DO WE FIT SOLAR PANELS. being that im a complete Luddite and prefer messing with concrete and wood I don’t really understand all this fancy wizardry so I’ve enlisted the help of the wife in sorting the technology side of the house out. Im led to believe from the misses that any grants or payback schemes are all finishing, so tell me should we fit solar or not. Let the great debate begin. Cheers the Griffiths mob.
  10. I think you need someone to specify the fitting of the pole plate on the wall, bolt size and spacing is very important if it’s a floor.
  11. Having been using this exact product today I can add some absolutely essential information when using this product if you are not wearing gloves and you get a fair bit on your fingers, do not then decide to put your gloves on it does make it a fair bit awkward to remove your gloves later in the day. ??????
  12. Coming in at a tangent, have you had this priced by some builders you may find it to be cost prohibitive, and for the money you could move up to one of the detached ones in the street. I used to live in nw London and I now you could easily spend a lot of money getting that how you want it.
  13. We are having sloping soffits, as it will follow the same lines as the soffit on the gables, personal choice I think.
  14. They don’t really work like that they don’t need to conform to the slate at all. What thay basically do is put a right angle on your slate. Imagine you where hand forming fake slates out of tin, you would bend a right angle in the ones that sat against the wall to prevent water running down the gap, well that’s what the soaker does it sits on top of the slate to make a right angle, the next slate sits on top so the soaker is not visible, you then place another soaker, they are laid in a bond type configuration just like your eaves slates, by having one below another you create a bond pattern and remove the straight gap that you would have hope that made sense.
  15. I think bc turn a blind eye to the upstand height, but be aware of the render discolouration if you have it to close to your roof, as rain bounce will splash up on to it.
  16. Are you not looking at this to critically it looks like there is a sink in that corner, if so you will only see the top 300mm of that corner.
  17. Should there not be a 150mm upstanding to the roof before any render board to allow for rain bounce not sure on current regs but a lead upstand always had to be that high, just the same as distance from ground to damp course.
  18. Are you using nudura, if so you need to more or less disregard everything you read on the subject and do your own details Most of the information you find on the net regarding icf is not appropriate. Its all American and has very little in comparison to here. Also so if you are using any of the eps type of blocks YOU WILL NOT get a dpm to lap into the blocks, bloody impossible won’t happen, not unless your names Paul Daniels have a look on @Stones blog he has some detailed pics of how his slab foundation and blocks marry up stones had to use a liquid dpm because of radon, I had to use a liquid because of methane. If you have neither I would just specify waterproof concrete for first truck load and then normal concrete after that.
  19. So I’m sitting in the bath. STEADY LADIES. and thought I would see what I could find to help our ol mate @recoveringacademic Out off out later to practice my John travolta moves, so check that out and get that wall set out.
  20. @PeterW is with me, you also need to do something similar at a corner, you can look it up on YouTube, look up framing. If you look up California corner that might help with a corner you need to make sure you can support your boards on the external corner as well as internal corner. That one will mess with your head.
  21. @recoveringacademic what you need to do is mark out on the floor ALL YOUR WALLS, don’t build one wall and then add another this will bite you later layout your sole plate and mark all junctions, corners. Then mark them on your sole plate. The distance between studs is completely irrelevant, apart from the studs your plasterboard joins on i couldn’t give a hoot if there 457.5mm apart, it is only the corners and junctions and board joins that are important. Think about these 3 points and do not worry about the other being out by 10-20 50mm it is not important.
  22. Tbh @Onoff corner is wrong, you need to construct a 3 stud corner i will try to explain the first straight wall will have another wall that intersects it, like a T, you need to know this point at this junction of the two walls you put 2 studs with a gap in between equal to the width of the wall that will be intersecting so your studs come along all nicely at 600 centres then you have 2 studs with a 90mm gap between them, turn a couple of off cuts of stud sideways between the 2 studs that are set 90mm apart this makes your 3 stud corner. Pic to follow.
  23. The eps boards you use under your dpm aren’t wasted, you just subtract the amount from your final insulation layer so if you are having 150mm for arguments sake, you still use 150 mm but 25mm under the dpm to protect it then another 25mm on top of dpm then another 100mm. So total 150mm you have just trapped the dpm in between the bottom two layers. Minimal sand, just a very light dusting to take out any undulations, then lay your first board.
  24. Stand it on what ever you want when the house is signed off, stick it on e bay for the next poor bloke who has to deal with such a thing.
  25. Why not use 100mm ducting instead of underground pipe and bends, cheaper and it’s what it’s meant for. ?‍♂️ I found a heavily insulated 32 mm pipe fitted nicely in a 65mm duct, even cheaper than 100mm.
