Air bricks, weep holes and cavity trays
Russell griffiths replied to Mr Punter's topic in Brick & Block
Oh if that’s the case 10mm drill and a couple of hours work to keep the retard happy. -
3 metal silos and one new build and one conversion
Russell griffiths replied to hallega's topic in Introduce Yourself
Pictures, pictures. -
If he wants a weep hole, he should say it needs a cavity tray above them to deflect any falling moisture to the outer face. In theory he’s sort of right, but in reality it’s never going to get any water coming out of them. You might as well say every single wall tie needs a weep hole above it in case moisture drops on the tie and doesn’t drip of. -
Kwikstage scaffolding questions
Russell griffiths replied to Vijay's topic in General Self Build & DIY Discussion
I think we might have covered this before, but is there a reason you need to scaffold all the way around i just brought as much as I wanted to pay for really £4000, we do spend a lot of time moving it about, but paying out £12000 would be a bit painful i suppose you can sell it as it comes down so you can do your internal fit out. I think i have just convinced myself to buy some more. -
That Roofers Been Signed Off Sick
Russell griffiths replied to Triassic's topic in General Self Build & DIY Discussion
Pay for him to go private it could be the best grand you’ve spent. -
M4 junction 15, you can play with mine anytime. -
Can you go somewhere and have a mess with it, -
I think Pinterest is the place to look.
The 150x10 flat would flex to much, must have some form of angle in it. Channel, angle, box,
If you are on a tight budget you can forget the wood fibre insulation, have you priced it up? are you building the frame yourself or getting a company to supply. Your more cost affective method will be a mineral wool inbetween the studs with a mineral wool slab over the studs on the inside inbetween counter battens. Why cant you get a price for the vapour shield osb, just a phone call away.
Why use that bracket by Simpson when you could cut and weld some flat bar on, the Simpson one will not match the finish of the stringers.
Och it’s all worthwhile in the end
Russell griffiths replied to Tennentslager's topic in General Self Build & DIY Discussion
Do you normally keep a gas cylinder near the wood burner i couldn’t give a monkeys, just curious. -
Spans - Precast Flooring or intermediate support
Russell griffiths replied to Moggaman's topic in RSJs, Lintels & Steelwork
Send your drawings to a precast company they will have all the software to run the numbers not it the same but my block n beam floor came in at 5m and they just enlarged the beam size. Any reason you need to stick to 150mm. -
That’s it perfect whack a shelf up with a squirty soap on it, and a tub of hand cleaner keeps the troops happy. I also have a big first first aid box, emergency eye wash, needle and a pair of tweezers oh and soft bog roll.
Soundproofing 95mm bathroom stud wall
Russell griffiths replied to oranjeboom's topic in Sound Insulation
If your not bothered about the extra width then do it properly and use an isolation stud against the existing studwork, I can’t for the life of me remember what it is called, but it works by having a gap between the two studs sound transfer is best avoided by having the two areas of whatever material not touching each other, so a void between the two walls is best. It could be called a resiliant bar. ???? -
I e mailed our case officer stating that the choice of materials won’t make any difference to my foundation work starting and that we would provide samples ASAP, but wished to start work, he agreed in writing so we started we are just up to wall plate height and still haven’t discharged that condition. He didn’t think it was a problem as long as we don’t fit anything without sign off.
Your ledger board should be the same depth as your joists, your hangers and joists must have full surface contact, you can’t have a 200mm ledger and a 245 joist as the bottom will hang lower and not provide support as the joist deflects.
That’s the one up model from mine, lovely machine. Couple of things to think about can you insure it, this may sound like a silly question, but try to insure it before you buy one i did and I couldn’t insure a digger WITHOUT it being connected to another type of policy for example, tool and plant insurance needed to be connected to a public liability policy. Your house insurance won’t touch it. Its ok now as it’s covered by my site insurance second thing that is perfect size for stealing, drive in with an hiab and it will be gone in seconds, i would think with your plot a 3 tonne one around 7-10 years old would be good, far harder to steal. I wanted somthing cheaper £7500 as I probably won’t sell it after,
Help with my noggins please
Russell griffiths replied to ToughButterCup's topic in General Construction Issues
Work out how you are going to board it, and put them in according to your board sizes.
